FS: Factory Platinum 20” Wheels and Tires
Discussion in 'Marketplace - Wheels & Tires' started by captain_bij, Sep 10, 2018.
Thread Status:
Not open for further replies.
  1. Sep 10, 2018 at 6:04 PM
    captain_bij
    captain_bij [OP] New Member
    Bijan
    15’ Tundra Crewmax Platinum 4x4
    Came on the truck, but I don’t think the previous owner had them on that long.
    Comes with lugs and TPMS still installed.
    No plugs that I can see
    Came off of a 2015 platinum.
    Location
    Riverside, CA
    Price
    $700
    Local pick up only
    Will not separate wheels and tires
  2. Sep 15, 2018 at 6:51 AM
    captain_bij
    Bijan
  3. Sep 17, 2018 at 6:30 PM
    captain_bij
    Bijan
    Bump $700
  4. Nov 1, 2018 at 3:10 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Whats the size on these tires??
  5. Nov 1, 2018 at 3:17 PM
    captain_bij
    Bijan
    275/55/20
  6. Nov 1, 2018 at 3:19 PM
    Jpagansr
    Jpagansr New Member
    Joel
    2018 tundra Trd Sport
    should be P275/55 R20 I have the same ones on mine
  7. Nov 1, 2018 at 3:35 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I dont have thise kind of numbers on my tires...prob too small
  8. Nov 1, 2018 at 4:53 PM
    eiraved
    eiraved Plane Whisperer
    Palmdale, CA
    2018 MGM Tundra Crewmax Platinum 4X4
    Looks like your tire's metric equivalent is 318/60R20, which is almost an inch larger in diameter than a 275/55R20.
    Pinay likes this.
  9. Nov 1, 2018 at 4:55 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Thanks! I will keep looking..
    eiraved[QUOTED] likes this.
  10. Nov 1, 2018 at 5:04 PM
    eiraved
    Palmdale, CA
    This size would fit, unless you just want similar tires to what you got now.
  11. Nov 1, 2018 at 5:06 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I’m trying to find full size spare, prefer 2 but if it’s a set, I can work with it
  12. Nov 1, 2018 at 5:07 PM
    captain_bij
    Bijan
    Compairison
    eiraved likes this.
  13. Nov 1, 2018 at 5:16 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    So they won’t fit..
  14. Nov 1, 2018 at 5:20 PM
    captain_bij
    Bijan
    Not sure what you mean? They will fit, however they won’t be a full size spare for you.
    For a true full size you will need the exact same tire size you already have, but you won’t want to run one different size spare if you get a flat due to tires rotating at different speeds. For example if your rear driver side tire is flat you would at least want to change the driver and passenger rear so they rotate at the same speed.
    Not an expert just based off of what I’ve read on the forums
  15. Nov 1, 2018 at 5:22 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Ok. I understand.
  16. Nov 1, 2018 at 5:41 PM
    eiraved
    Palmdale, CA
    I know you've seen the donut spares used on passenger vehicles. This would be "somewhat" the same. A tire that'll get you home until you buy a replacement spare.
    Pinay[QUOTED] likes this.
  17. Nov 1, 2018 at 6:03 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Yeah, im not sure how close i can get to my tire size outside of buying rims and then get my same tire, not sure if these will be good alternative
  18. Mar 11, 2019 at 7:29 PM
    Caliboose
    Caliboose New Member
    local? where is that?
Thread Status:
