FS: 3 switch panel insert plate
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by CorpsTundra, Aug 24, 2021.
Thread Status:
Not open for further replies.
  1. Aug 24, 2021 at 5:03 PM
    CorpsTundra
    CorpsTundra [OP] New Member
    Michigan
    2021 Tundra CrewMax SR5-TRD OR - Cement
    For Sale by abomb60: 3 switch panel insert plate that installs in the recessed change holder area behind the shifter.
    -$25 Shipped
    -PM abomb60 to purchase
    Hardware needed to install plate:
    -(4) M3x20mm socket head cap screws
    -(4) M3 nuts
    -(4) M3 washers
    Accessorides rear window switch relocation plug & play wiring harness - 44” (says 2011-2017, but works up to 2021) - $39+ shipping:
    https://accessorides.com/products/r...ra-2010-2017-plug-play?variant=32416113524782
    Spare switch hole cover part number:
    55539-06090-C0
  2. Aug 24, 2021 at 5:19 PM
    I'll try to find the thread but I thought someone else on here 3D printed one that worked well for them.
  3. Aug 24, 2021 at 5:22 PM
    CorpsTundra
    Michigan
    Thank you George!
    Tundra234 likes this.
  4. Aug 24, 2021 at 5:26 PM
  5. Aug 24, 2021 at 5:29 PM
    @jefroshm0 didn't you have some luck finding one of these?
    CorpsTundra[OP] likes this.
  6. Aug 25, 2021 at 8:02 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  7. Aug 25, 2021 at 9:14 AM
    CorpsTundra
    Michigan
    Thank you gentlemen for the print file. I don’t have a printer.
    If anyone is willing to print one of these parts for me I will gladly pay you.
  8. Aug 25, 2021 at 12:11 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I have a carbon fiber printer.
  9. Aug 25, 2021 at 12:36 PM
    CorpsTundra
    Michigan
    I plan on replacing the shifter and cup holder surrounds with the black AJT inserts, so I am hoping to match the 3 switch panel to those.
    I don’t know much about the printers or carbon fiber. Does carbon fiber always print out in that checkered pattern or is that done for aesthetics?
  10. Aug 25, 2021 at 1:09 PM
    Tonkatoytaco
    Tonkatoytaco New Member
    Louie
    Maryland
    2017 Platinum XP MGM
    LRO 3/1 Leveling Kit, Dirty Deeds 10" exhaust, Bully Dog Programmer, AFE Super stock Intake with TB Spacer, Custom Rough Country Grill, Andres Devil Horns, Caliraised Fog lights, Morimoto XB Headlights, HRS taillight, Boost Auto tow mirrors, LED interior lights and Reg, light, Trail edition bed compartment, TRD rear sway bar, weathertech floor mats and window visor, Nitto Ridge grappler.
    Yeah if someone with a 3D printer can print these I would be down for 1 as well.
  11. Aug 25, 2021 at 1:10 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    You can upload stl files to sites like shapeways and get a quote on printing it out
  12. Aug 25, 2021 at 2:30 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I think @Rocfrog is getting back to printing, or is pretty close. I'll try to check his FB page and see what the latest is.
  13. Aug 25, 2021 at 2:49 PM
    CorpsTundra
    Michigan
    I checked with him before I posted this and he is not ready to start printing. I was hoping that I would find someone that has one that they decided not to use.
    TRDFerguson[QUOTED] likes this.
  14. Aug 25, 2021 at 3:20 PM
    crewmaxlmt
    scott
    This pattern is from the surface of the printing table.
  15. Aug 25, 2021 at 4:18 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Printed carbon fiber and woven carbon fiber are different.
    The "checkered pattern" is from carbon fiber that is woven and cured with resin into a shape (like fiberglass, only the carbon is extremely strong in the long axis of the fiber, and by weaving the fibers in different directions you get strength along each axis).
    Printed carbon fiber is a polymer (plastic) base material with short pieces of carbon fiber embedded in it. When 3D printed, the strands do offer some added strength over regular FDM printed materials like ABS or PLA, but not to the degree that woven carbon fiber does. It can also be a bit of a pain to print because sometimes the fibers can make the print have a rougher surface or even a "hairy" look (which can be remedied by some wet sanding and other steps).
    And both of these should not be confused with the fake plastic "carbon fiber" that is typically used for overlay pieces, which is really just a pattern printed on ABS plastic and covered with a glossy clear coat.
  16. Aug 25, 2021 at 4:24 PM
    CorpsTundra
    Michigan
    Thank you for the explanation. You’ll notice several “likes” from me recently, which started out as me searching your posts to verify whether your credit card slot is the same as mine. It turned into hey this Casey guy just spent more of my money haha! Your truck is looking prime and your upgrades are too.
    RainMan_PNW[QUOTED] likes this.
  17. Aug 25, 2021 at 4:24 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Post up a file to Shapeways and you can get them to quote that STL in a variety of materials.
    Use PETG or ABS for the hot interior of a car.
    https://www.shapeways.com/
    I am able to print them, but don't want to make a business of it and also am not interested in spending a bunch of time bundling hardware or sanding/prepping/painting these things for people.
  18. Aug 25, 2021 at 4:25 PM
    RainMan_PNW
    Casey
    Clark County, WA
    All the Gen 3 "credit card" slots are the same...except the Platinum and (maybe?) 1794, which don't have one there.
  19. Aug 26, 2021 at 10:18 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Correct 1794 does not have this slot it's just leather. If anyone wants I can print them for you just PM me and we'll work out the details. These will be PETG (same stuff as water bottles) so they won't warp and distort in the heat. I won't sand or prep them but I will print them for you and you can clean it up, paint it, bedazzle it .. whatever :)
  20. Aug 26, 2021 at 11:56 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I am looking for the switch insert for the credit card slot as well; happy to pay someone for it since I don’t have the printer. Looking to relocate my window switch.
  21. Aug 29, 2021 at 10:36 AM
    abomb60
    Massachusetts
    Printing one today out of PLA for testing. Unfortunately I can't test this myself as the 1794's & Platinum's don't have that opening so I'll need a guinea pig to test (I'm sure it'll work fine). I used the file from @RainMan_PNW but my slicer had an issue with the top missing for some reason .. luckily was able to fix it up and looks like we're good.
    If you want to test this out let me know. Price will be $25.00 shipped to CONUS and currently these will be black PETG as that's what I have. If someone wants a different color for some reason, let me know and we'll work it out.
  22. Aug 29, 2021 at 10:42 AM
    shawn474
    MoCo, Maryland
    PM sent- I will take it! Please pm me payment info
  23. Aug 29, 2021 at 10:47 AM
    abomb60
    Massachusetts
    Thanks! Looks like you're close so we won't have to wait a week for USPS to deliver so hopefully we can get this tested out mid-week and be ready to make these for others.
  24. Aug 29, 2021 at 10:50 AM
    shawn474
    MoCo, Maryland
    Thanks so much; payment sent
  25. Aug 29, 2021 at 10:55 AM
    CorpsTundra
    Michigan
    Editing title and first message to remove vendor name.
    abomb60 likes this.
  26. Aug 29, 2021 at 11:03 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Adam - that’s really cool of you. Odd the top was missing - must be the difference in software (I use Cura with my Ultimaker S3).
    I’d make two recommendations for tweaks based on my personal experience:
    1. Scale up to 101% for PETG. This will ensure a perfect fit on the switch blanks, because PETG seems to shrink a touch more than PLA
    2. Upsize the through holes to a full 1/8” (or 4mm). This eliminates the need of the end user to have to either drill out the hole or have to tap the hole for M3 screws. If the hole is opened up to 1/8”, then an M3x20mm long socket head cap screw will go through from the top and then a nut and star washer underneath to lock it in place.
    Other than that, mines been working great!
    HulkSmurf14 and AZTundra like this.
  27. Aug 29, 2021 at 11:06 AM
    abomb60
    Massachusetts
    Thanks appreciate the help! I was planning on 101% since there's a tiny bit of shrinkage (hehe) with PETG. For now open the hole to 1/8" with the drill press since I'd need the original cad file to change the hole.
    PS: Yes the top/bottom missing was odd. I'm using Simplify3d and it's been great. The object looked fine but when I sliced it the top & bottom layers and some infill were missing. Ran your file through an online STL fixer and all seems to be good. Other odd thing is I downloaded Cura and it looked fine there after slicing.
  28. Aug 29, 2021 at 11:07 AM
    biebs96
    PA
    Add me to a potential list. I am interested in one as well.
  29. Aug 29, 2021 at 11:09 AM
    abomb60
    Massachusetts
    Thanks! I'll post here when I'm ready to take orders ... hoping by the end of the week. I don't want to make a bunch just to realize they were slightly off ... done that before!
    biebs96[QUOTED] likes this.
  30. Aug 29, 2021 at 11:10 AM
    RainMan_PNW
    Casey
    Clark County, WA
    I used Shapr3D on my ipad to make the original. I can update the file this week and send it over to you
Thread Status:
