FS: 2018 Tundra LED Headlights Plug N Play wire Harness for 2014-2017 models
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Oct 14, 2017.
Thread Status:
Not open for further replies.
  1. Oct 27, 2017 at 3:42 PM
    #61
    Black2014Tundra
    Black2014Tundra New Member
    Rogelio
    2014 Black Toyota Tundra 1794 Edition 4X4
    Chromed the original OEM rims
    Nice and clean truck. The LED headlights make big difference. Thank you iHacker for your help.
    iHacker[OP] likes this.
  2. Oct 27, 2017 at 3:47 PM
    #62
    vila251
    vila251 New Member
    Truck Looks Great iHakcer!
  3. Oct 27, 2017 at 6:42 PM
    #63
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    Truck looks awesome
  4. Oct 27, 2017 at 6:44 PM
    #64
    mesaboogieman
    mesaboogieman New Member
    Joe
    Black 2014 Toyota CM Limited
    Looks fantastic!
    iHacker[QUOTED][OP] likes this.
  5. Oct 27, 2017 at 7:02 PM
    #65
    iHacker
    iHacker [OP] SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Thank you guys
  6. Oct 28, 2017 at 8:29 AM
    #66
    Judd1980
    Judd1980 New Member
    Judd
    2014 Tundra Platinum
    Pictures look great guys! Coming from factory Platinum lights there sure has been a big difference in output. Thanks to iHacker for the harness. Has anyone had to adjust their 18's? My right light is higher than the left, but when I go to make adjustments the screw barely moves one tick before feeling like anymore would break or strip it.
  7. Oct 28, 2017 at 9:43 AM
    #67
    vila251
    vila251 New Member
    I believe the right side is suppose to be higher than the left side. The driver side is lower so you don't blind the incoming cars. And the right side is higher so you can see further without blinding incoming cars.
  8. Oct 28, 2017 at 2:04 PM
    #68
    Black2014Tundra
    Rogelio
    Here are my pics. Pic 001.jpg Pic 002.jpg Pic 003.jpg Pic 004.jpg Pic 005.jpg Pic 006.jpg Pic 007.jpg Pic 008.jpg
  9. Oct 29, 2017 at 12:36 AM
    #69
    Black2014Tundra
    Rogelio
    Has anyone had a problem with the headlights low beam. It was just fine, but out of the sudden the low beam went off. I had to turn the light switch to high beam, so I could have both the high and low beam on at the same time. If I switch it back to low beam it would stay on for one second and then turns off. All wiring and harnesses are properly connected. Any ideas or suggestions. Please assist. It's really uncomfortable driving at night with the high beam on.
  10. Oct 29, 2017 at 5:44 AM
    #70
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Sounds like a bad motocontrol if the lows work fine with high beams on.
  11. Oct 29, 2017 at 6:43 AM
    #71
    vila251
    vila251 New Member
    i would turn on the light and wiggle every pin connector to see if any of them is loose. Hope you figure it out.
  12. Oct 29, 2017 at 7:29 AM
    #72
    iHacker
    Mario
    Check your ground and all the connections in the motocontrol.
    If everything seems to be OK then must be a bad motocontrol, I had a flickering problem when installed my retrofit headlights time ago before the 2018 LEDs and was a bad ground in the motocontrol.
  13. Oct 29, 2017 at 8:03 AM
    #73
    Black2014Tundra
    Rogelio
    Thank you iHacker, vila and inferno for your quick response and concern. I really appreciate your help and guidance. I found blown left headlight low beam 15Amp fuse in the fuse box. Replaced it and back to normal for now. I hope it won't blow again. All my ground and wire connections are good according to the motocontrol and iHacker harnesses specifications. I don't know what went wrong. Thank you guys once again for being such a good and helpful team.
    vila251 and iHacker[OP] like this.
  14. Oct 29, 2017 at 9:10 AM
    #74
    iHacker
    Mario
    I'm glad you got it fixed, and if you got a chance I recommend you to double check the grounds, that blown fuse isn't normal, did you disconnected your battery when installing all your wiring?
  15. Oct 29, 2017 at 10:39 AM
    #75
    Black2014Tundra
    Rogelio
    Yes, I did disconnect my battery and it worked ok for several hours after the lights were installed. I checked the ground connections, but they look ok., nothing is loose. Also the DRL lights and the high beam were ok. Really strange.
  16. Oct 30, 2017 at 4:59 PM
    #76
    Silverplatinum
    Silverplatinum New Member
    2017 platinum tundra
    So just making sure I get this right. So in order to connect the new 2018 headlights to my 2017 platinum I will need a harness from Ihacker and 2 motocontrols?
    I’m planning to do a full 2018 conversion so new headlights, grille, and emblem.
  17. Oct 30, 2017 at 5:18 PM
    #77
    vila251
    vila251 New Member
    Only 1 motcontrol.
  18. Oct 31, 2017 at 8:42 AM
    #78
    Silverplatinum
    @iHacker I’ll take one. Front end conversion is ordered. I’ll order a motocontrol as well.
  19. Oct 31, 2017 at 1:29 PM
    #79
    Iraqsucks
    Iraqsucks New Member
    Danny
    2016 DC SR5 TRD off-road package MGM
    So far just window tint, components sets front and rear, JL 13TW5, JL 500/1, JL 300/4, link 8. Soon to be: 35's, 17" method grids, ome lift, cb shackles, leather, trd grill, bhm.
    In for a set when you make them for a 2016 sr5
  20. Nov 1, 2017 at 11:41 AM
    #80
    Silverplatinum
    @iHacker Any idea when you’ll be sending these out?
    Thanks
  21. Nov 1, 2017 at 3:45 PM
    #81
    Cedtal1964
    Cedtal1964 New Member
    Cedric
    Cedar Hill,Tx
    White2015-1794 tundra
    None
    I have a 2015,1794 Edition Toyota Tundra and would like to get a harness if you’re still making them
  22. Nov 1, 2017 at 5:10 PM
    #82
    raysmith925
    raysmith925 New Member
    I also have a 2015 1794 Edition Toyota Tundra, and am interested in your harness.
  23. Nov 1, 2017 at 5:56 PM
    #83
    iHacker
    Mario
    PMed
  24. Nov 1, 2017 at 6:01 PM
    #84
    iHacker
    Mario
    PMed
  25. Nov 1, 2017 at 11:04 PM
    #85
    bgrand480
    bgrand480 New Member
    2017 platinum..interested in the harness.
  26. Nov 4, 2017 at 2:11 PM
    #86
    iHacker
    Mario
    Been very busy, finishing some of my harnesses in order for TRD PRO, is 90% plug n play harness, I think I will have to stick with this now since ballenger didn’t want to sell me all the 8 way connectors they get in stock this guy started making the harnesses at their own 2 weeks ago they been very insistent in how to wire the SR5 but of course I’m not sharing anything more with them hahaha, successfully trying to switch supplier they are ordering the 8 way connector and more parts directly from Yazaki which manufacture all the OEM connectors for TOYOTA.
    TRD PRO/SR5/LIMITED models work as factory and dim with headlights ON, all the Relay wiring is soldered for more durability and reliability, PMe for pricing and availability.
    9f346e534aa62ff038a7a918c6dda475_05c9ea392ae32b94c67d8000a4d1a828d30d5c77.jpg95d3ae49e17cb625c969deef781ca4b3_b112732d853d326e198d40c7daf6d6ae1877f39c.jpgb82799e984b5efda4252818b3f5a42ff_7c9be6f03c6fd9dba40f4ff85f09b68c4f8dcd61.jpg8e94b92d7c8ef032d731181e46554161_0f40e36cae56fcfdb34501814eefb54c933ed0a2.jpg52db73b4878c00ef64a8f2f5e15ebe85_cb46bcadf25afb7d36affe2eb0ce2335f5a0ddfe.jpg
    blue16, mesaboogieman and BlueBottle like this.
  27. Nov 4, 2017 at 2:14 PM
    #87
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yup I seen where they started selling them also.
  28. Nov 4, 2017 at 2:41 PM
    #88
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Your harnesses are the best I seen on here. That includes comparing them to some “businesses”!
    I see what you did here. Looks great and looks like it will work perfectly w drl hi/low. If anyone should buy a harness it should be from @iHacker
    The fact that he solders his relay connection shows his quality.
    ncmtnman and iHacker[QUOTED][OP] like this.
  29. Nov 4, 2017 at 3:12 PM
    #89
    iHacker
    Mario
    :) Thanks for your compliment @BlueBottle I'm very picky in my mods and want everything perfectly done, that's why I'm making this harnesses the best way possible but the problem here is to get the 8 way connector and from a trusted manufacturer, several Toyota dealerships cancelled my orders becuase the part is backordered in the USA. I prefer to stay away from the ones for sale in Alibaba and other Chinese sellers, but in a week or 2 I'm expecting a few of them from Yazaki with my new parts supplier this Ballenger guy was very fishy and I knew he was planning something, but I'm still here to help that's why I shared their link with some guys asking me for harnesses, if they have their headlights at home home already I don't want to delay the install for them due to my lack of parts to make more harnesses.
    blue16 and BlueBottle[QUOTED] like this.
  30. Nov 4, 2017 at 3:13 PM
    #90
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Thanks to you? They were already researching the parts needed to put these together in the middle of September.
    I noticed that they list/sell all the parts that are used in making them except the 8 pin plugs. I will say that I like the gray Delphi 9006 plugs better than the black ones other people are using. The Delphi plugs have the blue TPA locks on the end which hold the terminals tighter in the connectors.
Thread Status:
