FS: 2018 Tundra LED Headlights Plug N Play wire Harness for 2014-2017 models
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Oct 14, 2017.
Thread Status:
Not open for further replies.
  1. Apr 24, 2018 at 6:09 AM
    #661
    iHacker
    iHacker [OP] SW TRD PRO
    Mario
    AR
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    No, I thought you had the anytime fogs mod so not the case then?
  2. Apr 24, 2018 at 6:11 AM
    #662
    iHacker
    Mario
    AR
    I guess you have the correct functionality, fogs can’t be used without low beam
  3. Apr 24, 2018 at 6:19 AM
    #663
    iHacker
    Mario
    AR
    In previous messages is this video you can see how they behave
    https://youtu.be/yFHrj2A8AbU
  4. Apr 24, 2018 at 6:36 AM
    #664
    harrydunn
    harrydunn New Member
    Columbia, MO
    Because I was inverted.
    Call it, Friendo.
    In my video above, I have the easy fog light mod where I just ran a ground wire off the large fuse under the hood. I can't turn them off with the headlights on but I didn't need that functionality.
    iHacker[OP] likes this.
  5. Apr 24, 2018 at 7:28 AM
    #665
    iHacker
    Mario
    AR
    Ok sorry for the confusion, if you don’t have the anytime fogs mod then, all you mentioned is the correct functionality
    Truck off, everything off
    Truck on parking brake on all lights OFF
    Parking brake OFF DRL bright ON
    LOW beam and FOGs ON DRL dim
    High Beam ON DRL still dim FOGs off
    This is stock functionality, I remember my fogs never turned ON without Low Beam with stock headlights
  6. Apr 24, 2018 at 7:36 AM
    #666
    harrydunn
    Columbia, MO
    Call it, Friendo.
    This is correct.
    iHacker[QUOTED][OP] likes this.
  7. Apr 24, 2018 at 7:52 AM
    #667
    wnoble
    wnoble New Member
    2017 Megnetic Grey Tundra LTD Crewcab
    Ok, so @iHacker, I am confirming your last post. Let's forget about parking brake to simplify things - so assuming parking brake is off and flog light switch is always set to ON position. BTW, I forgot to mention I did not cut the grey wire, i.e. my amber DRL are still active and working in conjunction with the LED DRL
    My situation:
    1. Truck off, everything OFF
    2. Truck on, headlight switch set to OFF position: DTL ON, Fog lights OFF
    3. Truck on, headlight switch set to Parking light position: No change from above, DTL ON, Fog lights OFF
    4. Truck on, headlight switch set to Auto light position (daytime): No change from above, DTL ON, Fog lights OFF
    5. Truck on, headlight switch set to lights ON position (night scenario): Headlights ON, DTL DIMED, Fog lights ON
    It's #3 above I am questioning. Before this mod I could use my fog lights with the headlights off if the headlight switch set to Parking light position, but now they only come on when the main headlights are running. Is this expected?
    In the video, you showed in your previous post (red truck) it appears the person could operate his fog lights on and off with only the DRL on which doesn't seem to be the case for me. Is this a by-product of me keeping the amber DRL, because I believe in the video he does not have the amber lights running as DRL?
    @harrydunn Thanks for the post on the grounding. I'm wondering if this would solve my problem of not being able to run the fog lights independently of the headlights. Do you know if this would work if you have your amber lights enabled as DRL as well?
  8. Apr 24, 2018 at 7:55 AM
    #668
    wnoble
    wnoble New Member
    Sorry, I'll save everyone another post. Sounds like what I'm describing is consistent with what should be happening.
    So what is the "anytime fogs mod"? Is it what @harrydunn posted? Will this work even if your amber lights are enabled as DRL?
  9. Apr 24, 2018 at 7:55 AM
    #669
    harrydunn
    Columbia, MO
    Call it, Friendo.
    For clarification, I cannot run the fog lights with only the DRL's on. When the fog lights kick on in my video, I am actually rotating the stalk one notch forward to turn on my side marker lights, etc. You just can't tell that in the video. Is that what you're asking?
  10. Apr 24, 2018 at 7:56 AM
    #670
    harrydunn
    Columbia, MO
    Call it, Friendo.
    The way I did it is the quick and easy way. I believe there is another, more involved method floating around.
  11. Apr 24, 2018 at 7:58 AM
    #671
    iHacker
    Mario
    AR
    Yes your functions are normal, if you want the fogs ON without headlights definitely is another mod but don’t have experience doing such thing, and yes the ground shown in @harrydunn picture can do that, an also a jumper jumper under dash of pink wire and a gray wire.
  12. Apr 24, 2018 at 8:00 AM
    #672
    wnoble
    wnoble New Member
    Yes, this is the functionality I am looking for. I don't necessarily want the fog lights to be on all the time, but I want to be able to run the fog lights by keeping the fog light switch ON and rotating the main headlight switch to the "parking lights" mode or side marker lights on as you mention - (headlights still off).
  13. Apr 24, 2018 at 8:02 AM
    #673
    harrydunn
    Columbia, MO
    Call it, Friendo.
    The method I used above will work just fine for that. The fog light switch can be turned off actually and the fogs will still be turned on when you rotate the stalk to just the parking lights. It takes away manual control of the fog lights.
  14. Apr 24, 2018 at 8:04 AM
    #674
    wnoble
    wnoble New Member
    Thanks @iHacker, I'll try and search for a mod that references "jumper under the dash of pink wire and a gray wire" now that I know this will work with the amber DRL option enabled. I appreciate @harrydunn's example, but I would love a cleaner approach that's under the dash as I know when I take it back in for service they will give me grief over that implementation.
  15. Apr 24, 2018 at 8:06 AM
    #675
    iHacker
    Mario
    AR
    Yes @harrydunn picture is the easy way to do the anytime fogs mod
    But here’s is the not so easy way to do it and is under dash
    Read the attached PDF file
  16. Apr 24, 2018 at 8:06 AM
    #676
    harrydunn
    Columbia, MO
    Call it, Friendo.
    Keep in mind, I'm putting the box back on over the fuses. It fits just fine. I've never received grief from my Toyota dealer when in for service but I suppose you could. I prefer to not mess with the under dash wiring. That's where you can really jack some stuff up! Ha.
  17. Apr 24, 2018 at 8:11 AM
    #677
    harrydunn
    Columbia, MO
    Call it, Friendo.
    After reading that pdf, I'm starting to remember why I decided to do it the easy way without snipping any wires. Ha!
  18. Apr 24, 2018 at 8:12 AM
    #678
    wnoble
    wnoble New Member
    One last thing, when I shot video of the lights on they appeared fine with the naked eye but in the video, they appear to be streaming LED's.
    Anyone else experience this? Maybe its just my phone?
  19. Apr 24, 2018 at 8:13 AM
    #679
    harrydunn
    Columbia, MO
    Call it, Friendo.
    Yah, that's just a by-product of the video.
  20. Apr 24, 2018 at 8:15 AM
    #680
    wnoble
    wnoble New Member
    Pics of my installation - sorry for mutiple
    THanks @harrydunn.
  21. Apr 24, 2018 at 8:15 AM
    #681
    iHacker
    Mario
    AR
    Yes but function a bit different, they will turn ON automatically with DRL not switched
  22. Apr 24, 2018 at 8:22 AM
    #682
    wnoble
    wnoble New Member
    Here are the photos.
    Good point about messing with wiring @harrydunn.
    "fun" fact: My dealership ripped out my ad-on aux power I ran to the bed last year when they were replacing a quarter panel due to an accident because they said it wasn't done correctly. I had to fight with them to take it to an electrician to replace and have them pay for it. FYI, the auto electrician did it the same way I did.
  23. Apr 24, 2018 at 8:23 AM
    #683
    wnoble
    wnoble New Member
    Thanks @iHacker! I'll take a look.
  24. Apr 24, 2018 at 8:23 AM
    #684
    iHacker
    Mario
    AR
    I have that pdf saved, just in case someone needs the info but for me I’m ok with my fogs and how they work from factory
  25. Apr 24, 2018 at 8:26 AM
    #685
    harrydunn
    Columbia, MO
    Call it, Friendo.
    Now that I have the much brighter LED headlights, I'll probably remove my anytime fog light jumper wire from the fuse box.
  26. Apr 24, 2018 at 8:29 AM
    #686
    wnoble
    wnoble New Member
    Here are my pics in case anyone is interested. Thanks, guys for all the help!
    Ortho281, LKSR5-14 and iHacker[OP] like this.
  27. Apr 24, 2018 at 8:33 AM
    #687
    harrydunn
    Columbia, MO
    Call it, Friendo.
    Nice! Going to add the LED fogs?
  28. Apr 24, 2018 at 8:34 AM
    #688
    harrydunn
    Columbia, MO
    Call it, Friendo.
    Does anybody know how the factory 2018 LED fogs compare to the XB's I have?
  29. Apr 24, 2018 at 8:34 AM
    #689
    iHacker
    Mario
    AR
    Is a most, I have the Morimoto XB Fogs they work nice and have better output than stock 2018 LED fogs
  30. Apr 24, 2018 at 8:37 AM
    #690
    iHacker
    Mario
    AR
    I don’t have pictures but they are completely different, 2018 LED Fogs have good output but not defined like the XB fogs that’s why I’m keeping my XBs
Thread Status:
