Frustrated...
Discussion in 'General Tundra Discussion' started by JROCK915, Mar 14, 2015.
  1. Mar 14, 2015 at 4:36 PM
    JROCK915
    JROCK915 [OP] Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    Can anyone give me some guidance?
    I'm trying to plasti-dip my grille housing. However, I can't get the thing off the rig.
    I removed all screws, that are visible. There's some area around the hood line, that is actually keeping it attached.
    Help!
  2. Mar 14, 2015 at 5:23 PM
    MotoTundra
    MotoTundra The Ocho
    Don
  3. Mar 14, 2015 at 5:27 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    @JROCK915
    I bet the only step you are missing is to pull the grill directly toward you.
    Review all the steps to make sure though!!
    JROCK915[OP] likes this.
  4. Mar 14, 2015 at 5:48 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    I tried, it was flapping back & forth. Like it was all loose. It just wouldn't budge. Then I heard a crack. Stopped immediately, and tightened it all back up. Maybe I'll try a pry tool, and wedge it in there, as I pull it straight out. Thanks.
  5. Mar 14, 2015 at 8:34 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    It's common to break the outside two plastic clips. I did. Just pull hard.
  6. Mar 14, 2015 at 8:50 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Not what I was hoping to hear.. I followed those directions when I replaced my grill and didn't have any issues. If you want, I can email you some pictures I have of the backside of my grill, maybe it will give you a better picture of how it goes together/apart.
    JROCK915[QUOTED][OP] likes this.
  7. Mar 14, 2015 at 9:50 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Honestly, I think this is quite common. Did it myself as well.
  8. Mar 15, 2015 at 10:13 AM
    JROCK915
    Jeremy
    Palm Desert, CA.
    jpink0877@yahoo.com
    Thanks
  9. Mar 15, 2015 at 2:02 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    @JROCK915 I figured I would post it up here in case anyone can use it in the future...
    I forgot that I had the protective pieces for shipping on the ends, which is a pretty important part of the assembly/disassembly.
    I have since sold the grill so I can't take any extra pictures..
    Here is a video I found that may help...
    https://youtu.be/PKbrFNxcJ6E
  10. Mar 15, 2015 at 6:43 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    major difference. I'm a 2nd Gen. The grille comes off the hood.
  11. Mar 15, 2015 at 7:10 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    :facepalm:for some reason I thought you had a 3rd gen.... Sorry!
  12. Mar 15, 2015 at 7:24 PM
    2nd gen wasn't that bad. It should just pull right out when you pull it towards you.
  13. Mar 15, 2015 at 8:24 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    no worries.
