Front Trd sway bar.....
Discussion in 'Suspension' started by JerseyTundra1260, Nov 17, 2017.
  1. Jan 25, 2018 at 1:40 PM
    showtime240
    showtime240 New Member
    The front bar is about 29lbs compared to about 17lbs for the front.
    It is beefier than the Sequia front sway bar as well.
    Now if it is needed or not, I'm not sure.
    The rear definitely helped.
  2. Jan 27, 2018 at 5:25 AM
    racin
    racin zmr
    Tampa, FL
    2015 Met.Gray 4x4
    Work at Toyota here's a close up 2018 trd front sway on tundra..will be installing on my 2015 soon
  3. Jan 27, 2018 at 7:14 AM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    No sway bar is the best sway bar
    95_BPmedic, d0zer, SoCal619 and 3 others like this.
  4. Jan 27, 2018 at 6:43 PM
    torkeyvr6
    torkeyvr6 New Member
    Just ordered the rear sway I think I will be buying the front soon. If @Roman gives me a good price I will do a
    write up on the front and of course purchase from him.
    racin and 4x4_Angel like this.
  5. Jan 27, 2018 at 7:45 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    :thumbsup:
    joonbug and BlueFalconActual like this.
  6. Jan 27, 2018 at 7:46 PM
    Eclipsed & Floating
    Voluptuous Whitey
    What could this do that’s any better than the already installed stock one?
    joonbug and JoshuaA like this.
  7. Jan 27, 2018 at 8:46 PM
    TheBeast The Beach
    not sure..but it's heavy duty...and red..and has a TRD sticker...:spy:
    TundraTXTSS, GarTX526, focal and 11 others like this.
  8. Jan 27, 2018 at 8:53 PM
    Gibzki
    Gibzki New Member
    14 White Tundra DC TRD 4X4
    Bakflip Tonneau Cover Fibermax Amp Power Step Moto Metal M0961 Pro Comp Xtreme M2 295/55R20 2 8" Rockford Fosgate Punch Alpine MRP-M500 Mono Power Amplifier LED headlight, foglight, reverse light, license plate light, cargo light, map light, dome light, vanity and footwell Magnaflow 15304 with black tip
    Is this going to be an issue for off roading like the rear sway bar?
    Sunnier and TheBeast like this.
  9. Jan 28, 2018 at 4:06 AM
    skyheli
    skyheli New Member
    I already had the rear sway bar on the CMax. I added the Sequoia sway on the front. This was like sort of icing on the cake. The wallowing stopped with the rear sway.... The front mad the turns more predictable. Yes all this sway stuff affects the off roading.... I barely off road to care. I am more highway miles.
    Vector W8 and AxelsHumanDad like this.
  10. Jan 29, 2018 at 1:56 AM
    Stuffs
    Stuffs New Member
    Anyone have a part number for the front bar yet?
  11. Jan 29, 2018 at 2:14 AM
    Stuffs
    Stuffs New Member
    The rear was an issue because you're going from no bar to having one. So the articulation was def affected.
    For the front tho, I think articulation shouldn't change much regardless of how stiff the bar is since the droop wouldnt be under load. So if you already running a stock FSB, going to a stiffer one shouldn't effect your OR capabilities.
  12. Jan 29, 2018 at 4:03 AM
    midnight
    midnight IXLR8
    Todd
    GPT MS
    2024 Toyota Tundr TRD Pro
    Color matched mirror covers Color matched door handles Added TRD Performance package Changed the OEM fog lights to Rigid Industry Added AFE tow points TRD Performance Package
    I went from a 2016 with a rear bar that definitely helped to a 2018 TRD Sport and the responsiveness was immediately noticeable. Well worth it24C33D1B-0330-408A-84FD-289CB4751912.jpg
  13. Jan 29, 2018 at 1:22 PM
    Stuffs
    Stuffs New Member
    Awesome. How was the ride quality between the two since they have different shocks? Is the Sport a firmer ride?
  14. Jan 29, 2018 at 1:27 PM
    midnight
    midnight IXLR8
    Todd
    GPT MS
    I had Bilstiens 5100s on old truck and yes it is a little sportier. I definitely handles better
    Stuffs[QUOTED] likes this.
  15. Feb 5, 2018 at 9:46 AM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    Anyone?
  16. Feb 5, 2018 at 11:04 AM
    midnight
    midnight IXLR8
    Todd
    GPT MS
    Look at cool springs Toyota parts website. Like 220$
  17. Feb 7, 2018 at 3:41 AM
    racin
    racin zmr
    Tampa, FL
    2015 Met.Gray 4x4
    If your doing modest rock climbing you can have upgraded rear and front sway bars..even mudding its fine, I do it all the time...My truck lives on blacktop and dirt majority of times....BUT if I personally was doing extreme rocking maneuvers with my truck frequently I would never install rear sway bar...theirs always going to be noticeable improvements when upgrading sway bars...been installing/upgrading them on almost every vehicle I ever owned..I took very inexpensive but functional route with my 2015 sr5..I reused my stock front springs on used set of yellow blisteins(came off trd sport models 2014-2017?) people are practically buying the trucks and taking these yellow blisteins off immediately and selling for dirt cheap full set $40-$50(have 3 sets for backups)..these gave the truck extra lift and drives stiffer than the new trd sport 2018 trucks with red trd shocks...I drive the new trucks almost everyday and my truck.. I'm constantly comparing issues..I have my front trd sway bar now will be installing when I have time then give full write up of my complete suspension and lift..all under $500.. and thats including both front and rear trd sway bars, yellow blisteins struts/shocks, 3.5/1 lift and differential drop.
  18. Feb 7, 2018 at 7:17 AM
    Gibzki
    Gibzki New Member
    I really like how the rear sway bar improved how the truck handles corners. What I don't like is how they designed it where it reduces the ground clearance by around almost 3". I have seen rear sway bars from other trucks/SUVs where it was level with the bottom part of the differential thus not affecting ground clearance at all.
    racin[QUOTED] and Smiley like this.
  19. Feb 7, 2018 at 11:02 AM
    #49
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's to drop the center of mass....:rofl:
  20. Feb 7, 2018 at 3:26 PM
    #50
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    Some folks install them rotated 90degrees around the axle and it doesn’t hang down as much. Check out the rear sway bar threads and you’ll see what I’m talking about.
    JoshuaA likes this.
  21. Feb 7, 2018 at 10:17 PM
    #51
    Stuffs
    Stuffs New Member
    So still no one has word on how we can get a hold of one of these TRD front sway bars? I was going to get the Sequoia ones but if this is that much heftier, I'd really like to get one.
  22. Feb 8, 2018 at 12:50 PM
    #52
    showtime240
    it seems they are still on back order at SparksParts
  23. Feb 8, 2018 at 1:00 PM
    #53
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    still nothing from @Roman ?
  24. Feb 8, 2018 at 2:22 PM
    #54
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    They're not pulling up as a good number yet. The part number for them is PTR62-0C180, but the catalogs don't have them listed yet. Toyota has a stop sale on them now and isn't releasing them just yet.
    showtime240 and Wynnded like this.
  25. Feb 12, 2018 at 8:03 PM
    #55
    manguy
    manguy New Member
    2017 TRD PRO Barcelona Red
    I received mine today...just need to find time to install it!
  26. Feb 12, 2018 at 8:26 PM
    #56
    showtime240
    Which vendor did ya get it from??
    It seems they are either back ordered or not available yet.
  27. Feb 12, 2018 at 8:36 PM
    #57
    manguy
    manguy New Member
    Ordered it from trdsparks a couple weeks ago
    showtime240 likes this.
  28. Feb 12, 2018 at 10:03 PM
    #58
    Tundra1078
    Tundra1078 New Member
    Peter
    Los Angeles
    2018 White Platinum 4x4
    TRD dual exhaust, sway bar, TRD skid plate, grab handle (future), husky liners
    Let us know how it rides compared to stock.
    TheBeast likes this.
  29. Feb 19, 2018 at 9:38 AM
    #59
    Borgs
    Borgs New Member
    PA
    @Roman - can you let us know when you get them in? I'd be interested.
  30. Feb 19, 2018 at 10:16 AM
    #60
    Roman
    Roman
    Franklin, TN
    Will do.
