Front tow hooks w/TRD skid plate
Discussion in '2.5 Gen Tundras (2014-2021)' started by Medic343, Aug 10, 2018.
  1. Aug 10, 2018 at 11:30 AM
    Medic343
    Medic343 [OP] 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Afternoon everyone,
    I recently acquired some stock tow hooks off the forum as my truck did not have them. Well I went to look at the truck today to prep for the installation and it appears that with the TRD skid plate I installed when I purchased the truck I will not be able to mount the tow hooks without modifications.
    My question is which tow hooks will work with the TRD skid plate or is there an adapter or bracket out there I can use to make the factory ones work?
  2. Aug 10, 2018 at 11:38 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    They should fit with the skid plate. You have a picture?
    Medic343[OP] likes this.
  3. Aug 10, 2018 at 11:51 AM
    They should fit
  4. Aug 10, 2018 at 11:55 AM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    Reference picture....
  5. Aug 10, 2018 at 11:59 AM
    Medic343
    Kenny
    New Mexico
    There seems to be about a 1 inch gap in between the skid plate and the frame rail. Is there a spacer I need to fill that gap? I'll snap a picture in a bit.
  6. Aug 10, 2018 at 12:02 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    There shouldn't be a gap...I added a TRD Pro skid to my TRD Limited and the tow hooks fit...sounds as if something isn't right...
  7. Aug 10, 2018 at 12:04 PM
    Crunch527
    Iowa
    Check the front two bolts and make sure they are in the threaded holes...if they aren't seated and tight, then that could keep the front of the skid plate from fitting properly...otherwise, I can't think of why you would have a gap...
  8. Aug 10, 2018 at 12:29 PM
    Medic343
    Kenny
    New Mexico
    I'll have to check it out from underneath when I get off work. Sounds like something isn't right then if there shouldn't be a gap...I should have known
  9. Aug 10, 2018 at 12:30 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Here’s a couple of pics on my phone.
    Medic343[OP] and NewImprovedRon like this.
  10. Aug 10, 2018 at 12:54 PM
    Medic343
    Kenny
    New Mexico
    My skid plate is like @TRD423 I'm guessing I'm going to have to unbolt the whole thing to find out why there is a gap.
  11. Aug 25, 2018 at 4:19 PM
    Medic343
    Kenny
    New Mexico
    So I finally got around to it. Looks like whomever installed the skid plate made some spacers for it for reasons unknown.
    Anyone know where I can get the TRD hardware kit to mount it the way it's supposed to be?
  12. Aug 25, 2018 at 4:24 PM
    Medic343
    Kenny
    New Mexico
    I'm assuming these should not be on here right?
  13. Aug 25, 2018 at 4:45 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    No, you definitely need those. Take a look at the instructions and the source of your problems may be that differential drop you have installed.
    Medic343[QUOTED][OP] likes this.
  14. Aug 25, 2018 at 7:30 PM
    Medic343
    Kenny
    New Mexico
    If those belong there how does that explain the gap in the front that everyone says shouldn't be there? I'm a little confused now
  15. Aug 25, 2018 at 9:42 PM
    computeruser6
    Dirk
    Escondido
    Those spacers were placed there because of the differential drop the previous owner installed. Do you see the spacer pieces between the frame and differential bracket? That is why you are having this problem.
  16. Aug 26, 2018 at 4:54 AM
    computeruser6
    Dirk
    Escondido
    Here are some photos of mine that show the skid plate and illustrate the difference:
  17. Aug 26, 2018 at 5:56 AM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    Did you buy the correct tow hooks? I think the 2wd is different than the 4wd. Im basing that purely on comparing mine to others, so I could be wrong.
  18. Aug 27, 2018 at 8:43 AM
    Medic343
    Kenny
    New Mexico
    Well that makes a lot more sense now. I appreciate you. So with this differential stop kit there is no way to avoid the gap in the front, therefore I'm going to have to figure out a different option for the tow hooks then...
  19. Aug 28, 2018 at 2:43 AM
    computeruser6
    Dirk
    Escondido
    You could probably have a machine shop make some steel blocks with two holes and get some longer bolts.
