Front Tow Hook Bolt Removal & Re-Install
Discussion in '2.5 Gen Tundras (2014-2021)' started by d_kinneyjr, Jan 4, 2021.
  1. Jan 21, 2021 at 12:06 PM
    TheBubbaDude
    TheBubbaDude New Member
    2020 Tundra TRD Pro
    AJT Blackout Kit 1.25" Wheel Spacers NRG 285/70/18 Meso Customs TRD Start Button
    I did it with a standard socket so it wasn't very tight to start. What's the torque rating for reinstallation?
    BravoDeltaRomeo likes this.
  2. Jan 21, 2021 at 12:23 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I went with 43. There are few numbers floating around the below thread.
    TheBubbaDude[QUOTED] likes this.
  3. Jan 21, 2021 at 12:41 PM
    TheBubbaDude
    2020 Tundra TRD Pro
    Thanks. I didn't use the torque wrench but they're definitely more than 43
  4. Jan 21, 2021 at 12:49 PM
    ZPMAN
    Minnesota
    Put a dab of silicone on the threads so they don't rust up next you take them off.
  5. Jan 21, 2021 at 1:37 PM
    jefroshm0
    jefroshm0 New Member
    Elk Grove, CA
    2018 Cement Tundra Crew 4x4 SR5
    Did it with standard wrench. 17mm I think socket. No problem.
    TelemarkTumalo likes this.
  6. Jan 22, 2021 at 10:57 AM
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    What did you do to “shadow-out” the oval Toyota grill symbol? Looks awesome.
  7. Jan 22, 2021 at 11:22 AM
    d_kinneyjr
    d_kinneyjr [OP] New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    I used a 17mm with extension and a 24" breaker bar
  8. Mar 15, 2021 at 7:17 AM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    Anybody got some advice. The tow hooks that I took off, painted red and reinstalled are starting to chip. I believe that it is because of the salt and sand here in the North East. I just noticed it over the weekend. I was going to repaint them and then put some clear coat on them (something I did not do the first time). I wanted to see if anyone else had this problem and what you did to fix it. Thanks in advance.
  9. Mar 15, 2021 at 7:27 AM
    Those are small enough that I bet you can get them powdercoated for cheap.
  10. Mar 15, 2021 at 7:29 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    If the paint is chipping (and you haven’t been hooking cables to them) it probably has more to do with poor adhesion. Most likely due to an issue with surface prep or possibly with the type or quality of paint used.
  11. Mar 15, 2021 at 7:31 AM
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    Mine have only been painted a few months and I'm in the south so they haven't seen salt yet. How well did you prep them? I sanded mine with a dremel, primed, painted, then clear coated them. Stretched it out over 2-3 days. No issues what so ever.
  12. Mar 15, 2021 at 8:05 AM
    RobertD
    Robert
    DFW, Texas
    @d_kinneyjr as others have said, it could be your prep. Also, clear will give you some protection but if you are on roads that kick up a lot, it might be worth spraying them in bedliner or getting them powder coated as mentioned above.
  13. May 21, 2021 at 11:15 AM
    KatoK
    KatoK 2021 Super White 4X4 TRD Pro
    Jeff
    N. Texas
    Just did mine but didn't clear coat. Wet sanded, degreased, sanded again, degreased, then 4 coats of spray paint. I'm going to see how far that gets me but might go the powder coated route if that doesn't stand up to the Texas summer and roads! Thanks for all the tips.
