Front sway bar part number?
Discussion in '2.5 Gen Tundras (2014-2021)' started by myfirsttundra1, Jan 7, 2023.
  1. Jan 7, 2023 at 11:28 AM
    myfirsttundra1
    myfirsttundra1 [OP] New Member
    2023 Platinum crewmax
    Hey everyone!
    my factory front sway bar is rusting through and want to take the opportunity to install a TRD bar. However, any Toyota parts site I come across says that my 2016 crewmax sr5 off road is not compatible:
    PTR62-0C180
    Is this true? Also, would these end links and bushings work?
    48815-0C050
    PTR11-34093
    Thanks so much for your time!
  2. Jan 7, 2023 at 12:07 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I bought mine from Sparks (for the truck that is in my avatar). My memory says that I bought it as a complete kit. Below is the packing list that came with it with all of the parts numbers. I thought I bought it as a "kit" (think: single click type of purchase). I doubt that I figured out all of these parts and their numbers. But it is everything that was needed and there certainly was nothing left over.
    Good luck.
    myfirsttundra1[OP] likes this.
  3. Jan 7, 2023 at 12:09 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
  4. Jan 8, 2023 at 6:15 AM
    myfirsttundra1
  5. Jan 8, 2023 at 8:22 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    My apologies. I just looked at the packing list and see that it includes windshield wipers, filters and a gasket for something (can't recall). I'm thinking that just the sway bar part number was the complete "kit" because I think that the actual bar itself is all you need for the front. You then use all the existing parts for hooking her up. Be sure and get all your fastener torque numbers noted in advance. There's a couple very burly ones.
    MedCityMoto likes this.
  6. Jan 8, 2023 at 9:18 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    111 ft lbs for the inside nut, 89 for the axel bolts and 51 for the frame mounts (rubber boots)
    I wrote this down in my spreadsheet of "to do" items for when I do it myself, probably in the spring.
    Y0TA PR0 likes this.
