Front suspension suggestions
Discussion in 'Suspension' started by mbn225, Sep 24, 2020.
  1. Oct 2, 2020 at 2:55 PM
    mbn225
    mbn225 [OP] New Member
    Louisiana
    2008 Tundra Crewmax TRD
    Rock Warrior Bits Flowmaster exhaust 3/1 Lift
  2. Oct 2, 2020 at 3:19 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    That's so weird. Get rid of those and use the adjustable clips on the 5100s to lift it and you won't believe it's the same truck. Spacers upfront make it ride really rough.
  3. Oct 9, 2020 at 12:39 PM
    DanielsTrundaSlow
    DanielsTrundaSlow New Member
    2012 tundra
    I have the maxtrac lift on and want a smoother ride do I go with the 3.5inch lifted strut or 6inch lifted strut? Also would I have to get tubular control arms or are the stock ones fine?
  4. Oct 9, 2020 at 2:58 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    The Rough Country 6" N3 coilovers are designed to replace the OEM coil/spacer coilover assembly that several spindle/block 6" lifts utilize. If your lift is a 6" lift using your OEM coilovers with a lift spacer on the top, then the 6" N3 coilovers is what you would go with. My Tundra has the Pro Comp Stage 1 6" lift. The OEM coilover/top spacer lasted less then a year and the handling was sub par. Once I installed the 6" N3's, problems solved. I am very happy with them so far.... and the price is really nice.
  5. Oct 9, 2020 at 8:52 PM
    DanielsTrundaSlow
    2012 tundra
    Thanks for the help? And it will also maintain that same ride height correct?
  6. Oct 9, 2020 at 11:32 PM
    preacher35
    Yes.
  7. Dec 20, 2020 at 9:27 PM
    mbn225
    Louisiana
    Does anyone have experience with the rough country 3.5 lift coilovers?
