Front suspension question
Discussion in 'Suspension' started by ccam, Aug 13, 2018.
  1. Aug 13, 2018 at 8:00 AM
    ccam
    ccam [OP] New Member
    chris
    Fishers IN
    2011 Tundra Crewmax TRD
    1 in spacer lift on top of the coilovers and in rear, k&n cold air intake, toytec tunebcs coilovers up front, toytec boss 3in lift rear shocks, trd rear sway bar, straights from the cat. back (She purrs a little)
    First off my truck has toytec boss rear shocks for 3 in lift and spacer blocks in back. The front was stock I believe. With the yellow Goldstein struts with leveling spacer in front.
    2 weeks ago I was on vacation and blew a front strut. I was stuck on vacation on an island with limited time. I took the truck to meineke and had front struts replaced they told me it was cheaper to get all new coilover assembly. They put monroe easy struts on the front. They put the leveling kit back on and the truck sits an inch or so lower now in the front. They are claiming they put everything together correctly.
    However the front end sags quite a bit now. Any suggestions? I have a 2011 Trd crewmax. Are the coilovers for trd and regular tundra different lengths?
  2. Aug 13, 2018 at 8:01 AM
    ccam
    chris
    Fishers IN
    Bilsteins not Goldstein lmao
