Front, Rear, or both Sway Bars?
Discussion in 'General Tundra Discussion' started by Vegeta7, Mar 10, 2019.
  1. Mar 10, 2019 at 1:49 AM
    Vegeta7
    Vegeta7 [OP] New Member
    2019 Tundra SR5 Crewcab 4X4
    I have a dilemma about the sway bar. What do you guys recommend to install? Front, Rear, or both Sway Bars?
    Mountun Goat likes this.
  2. Mar 10, 2019 at 3:07 AM
    Vegeta7
    Thanks for your advice. I believe the one with the sway bar is the TRD PRO, I have a SR5 TSS.
  3. Mar 10, 2019 at 3:39 AM
    Vegeta7
    I'll check it out, thanks.
  4. Mar 10, 2019 at 4:06 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Every truck has a front sway bar. The TRD front sway bar is just an upgrade. It’s big and red and you would know if you have it.
    You currently have no rear sway bar, so adding one here would be more beneficial. Upgrading to the larger TRD bar in the front is up to you.
    Here’s the front TRD bar on my Sport.
    Mr Swervlin and Trooper2 like this.
  5. Mar 10, 2019 at 5:20 AM
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    The rear TRD swaybar will give you a noticeable handling improvement. The stock front swaybar is tubular, lighter and can flex.
    The front TRD swaybar is solid hunk of steel and strong as hell. It will improve the performance of your truck but not as noticeable as the rear. If you can only put one on, then go with the rear swaybar first.
    Wynnded and Trooper2 like this.
  6. Mar 10, 2019 at 5:23 AM
    Yes the rear sway bar is a great add on.
  7. Mar 10, 2019 at 5:26 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Rear sway bar :spending:
  8. Mar 10, 2019 at 5:27 AM
    I run both TRD's as well.
  9. Mar 10, 2019 at 5:57 AM
    dp0031
    dp0031 New Member
    David
    Corpus Christi TX
    2013 SR5
    AMP Research power steps Black Rhino Traverse 20x9.5 Toyo tires Undercover Lux TRD rear sway bar TRD skid plate Bilstein adjustables Icon leaf springs Alpine iLX-207 JBL speakers and 10 in sub in custom box
    Where is the best place to get the front TRD sway bar?
    I know Sparks has a disclaimer about the bar already having paint damage from Toyota. Don't want a damaged one.
    Prostar 190 likes this.
  10. Mar 10, 2019 at 6:01 AM
    Omohundro
    Jody
    McMinnville TN
    I think it’s hard to not get a damaged one. Toyota doesn’t put them in any kind of box or even wrap them with anything.
  11. Mar 10, 2019 at 6:08 AM
    dp0031
    dp0031 New Member
    David
    Corpus Christi TX
    2013 SR5
    Wondering if I order one locally will it be in better condition than getting one shipped to me.
  12. Mar 10, 2019 at 6:12 AM
    Omohundro
    Jody
    McMinnville TN
    It might help, I wonder where they come from?
  13. Mar 10, 2019 at 6:22 AM
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    I ordered one locally because I got a coupon in the mail from the dealership. I went to pick it up and it was all scratched up. The parts manager gave me an extra discount because it was `damaged`. Paint scratches are nothing. You wont be able to see the sway bar with the skid plate on.
    Omohundro likes this.
  14. Mar 10, 2019 at 6:23 AM
    Omohundro
    Jody
    McMinnville TN
    That’s kinda what I was thinking, even if its scratched up a bit big deal.
  15. Mar 10, 2019 at 6:28 AM
    dp0031
    dp0031 New Member
    David
    Corpus Christi TX
    2013 SR5
    My OCD won't allow it. Lol
  16. Mar 10, 2019 at 6:30 AM
    Omohundro
    Jody
    McMinnville TN
    You could get it and have it powder coated
  17. Mar 10, 2019 at 6:32 AM
    dp0031
    dp0031 New Member
    David
    Corpus Christi TX
    2013 SR5
    Yup, that's what I'm thinking.
  18. Mar 10, 2019 at 8:19 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I have both TRD swayers on my 2017.
    I would note that the front TRD swayer will not only tighten things up up front but will make the Tundra kind of "skip" off of small bumps in the road and not really "absorb" them. If you're at highway/interstate speed you want to know that. Especially if you're in the process of changing lanes and likely hitting the "bump" at an angle. Just be aware.
  19. Mar 10, 2019 at 8:21 AM
    Get a Hellwig one than.
    Black Wolf likes this.
  20. Mar 10, 2019 at 8:21 AM
    Vegeta7
    So? you guys recommend them?
  21. Mar 10, 2019 at 8:42 AM
    charliebison
    charliebison New Member
    I’ve got both and the truck handles great. You’ll be hard pressed to find a front one that isn’t a little scratched.
  22. Mar 10, 2019 at 9:02 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I have no sway bars front or rear cause they’re for cars :anonymous:
    I actually have a stiff spring rate on my lift and enjoy the flexibility of sans sway bar. On road feels good still even while towing. This is of course without any harsh highway speed crash avoidance- I’m sure in that cause I’ll flip uncontrollably into the ditch ;)
  23. Mar 10, 2019 at 9:28 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I had both and got rid of both. If you wheel your truck you're better off w/o 'em. I agree with @2ndgenny, they're for cars, they limit body roll but make the ride harsher.
    TheBeast likes this.
  24. Mar 10, 2019 at 10:44 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I have both and like them a lot. And I drive a truck! :thumbsup:
    charliebison likes this.
  25. Mar 10, 2019 at 11:03 AM
    kgb4187
    kgb4187 New Member
    He doesn't want any scratches under his truck, I'm sure he doesn't go offroading at all.
    mtntop, DiegoC and 831Tun[QUOTED] like this.
  26. Mar 10, 2019 at 8:07 PM
    dp0031
    dp0031 New Member
    David
    Corpus Christi TX
    2013 SR5
    I have been know to occasionally go over some curbs in the grocery store parking lot does that count?
    10TundraSR5, DiegoC and 831Tun like this.
  27. Mar 10, 2019 at 8:09 PM
    TheBeast The Beach
    depends on the use.
    I added the rear sway bar first and it tightened the rear end...however when switching to extended bypasses and HD leaf pack, it started binding and I wasn't getting full benefit of the suspension upgrade. so now the rear sway bar is gone.
    831Tun likes this.
  28. Mar 10, 2019 at 8:15 PM
    dongkatsu
    dongkatsu New Member
    Dong
    2017 Black Tundra Platinum
    7" bds gone due to issues and switched out the kit to Readylift 6" and up to 7"
    you'll see big difference in the rear. not so much in the front
  29. Mar 10, 2019 at 8:16 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yep, depends on use. That rear sway bar can become a rock rake off road. Had a guy that used to wheel with us, kept telling him to pull that thing off. Surenuff leaving Buck lake he drags not 1 but 2 HUGE boulders out into the middle of the trail, right in front of me, effectively blocking the trail for half an hour
    TheBeast[QUOTED] likes this.
  30. Mar 12, 2019 at 7:07 AM
    DiegoC
    DiegoC New car smell
    Diego
    2016 White Tundra Limited
    ReadyLift SST 3/1 Level Lift W/ sum 35's
    Guilty:muscleflexing: Hahahahaha
