Front/rear diff, xfer case, & trans fluids..
Discussion in 'General Tundra Discussion' started by Spvrtan, Jun 5, 2017.
  1. Jun 5, 2017 at 11:21 AM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    Diffs/case
    Toyota recommends 75w-85 but I hear it's better to go with 75w-90 for our trucks if you use it heavily. Since AMSOIL is so hard to find and expensive, I'm thinking about going with one of these..
    https://www.amazon.com/Red-Line-579...&qid=1496687141&sr=8-1&keywords=amsoil+75w-90
    https://www.amazon.com/Mobil-104361...000ONZXPK/ref=cm_cr_arp_d_product_top?ie=UTF8
    Transmission
    I'll probably lean toward sticking with OEM fluid unless someone knows of a better alternative but I saw two Toyota fluids out there..
    Do I go with this:
    https://www.amazon.com/Toyota-Genui...&qid=1496686378&sr=8-1&keywords=toyota+75w-85
    ..or this:
    https://www.amazon.com/dp/B004SKRLGE/ref=psdc_15719351_t3_B004SL9HP6
    I'm at almost 55k and am going to do a drain/fill maintenance on it.
    GiantsFanDan and Black Wolf like this.
  2. Jun 5, 2017 at 11:54 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Just a heads up if you do your 4.88 gears soon. When I spoke with Auburn gears they recommend Non synthetic oil
    80-90 Weight oil with additive. They also said not to use Aimsoil on the gears.
    ColoradoTJ likes this.
  3. Jun 5, 2017 at 11:57 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I'm curious, when does Toyota recommend transmission service?
    I do my diffs every 10k because I'm so hard on them
  4. Jun 5, 2017 at 11:58 AM
    1UPPER
    TEXAS
    Flux capacitor!
    If you look at the back of your service manual it gives you the mileage points for different services.
  5. Jun 5, 2017 at 11:59 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Masshole likes this.
  6. Jun 5, 2017 at 12:02 PM
    Spvrtan
    Kris
    San Diego, CA
    I'm most likely going with an ARB air locker instead of Auburn LSD -- does that change things (with Nitro gears)?
  7. Jun 5, 2017 at 12:03 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    jeezuz man I know this. I was just wondering if I could get a quick answer to satisfy my curiosity instead of driving all the way home and digging through my manual.
    but thanks anyway :rolleyes:
    Luke_Skywalker and Ps3udonymous like this.
  8. Jun 5, 2017 at 12:11 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Sorry bro misunderstood your question. I called Toyota service and they said any Tundra 2006 to current the transmission oil change is at 100k miles. They said differential fluid change is every 30k miles.
  9. Jun 5, 2017 at 12:13 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I don't want to mislead you on this one. I'm not completely sure. I would suggest you call ARB and ask them what they suggest then. That way you don't void any warranties or cause excessive wear to your gears.
  10. Jun 5, 2017 at 12:14 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Thanks man (for reals this time lol) that's what I remember. Just wanted to verify
    1UPPER[QUOTED] likes this.
  11. Oct 26, 2017 at 2:56 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Has anyone used RAVENOL J1C1003 SAE 75W Manual Transmission Fluid - MTF-3 Full Synthetic in place of the OEM 75W transfer case oil #08885-81080? The Ravenol is supposed to be the equivalent to Toyota 08885-81081, which is supposedly the same as 08885-81080, but packaged for Euro/Asian markets according to some Tacoma and 4Runner forums. The Ravenol is $15 on Amazon, as opposed to $55 for the Toyota fluid. Amazon reviews claim it is an exact match for 2014+ Tundra transfer case fluid.
  12. Oct 26, 2017 at 3:12 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Apparently there are a couple postings in Russian forums showing that 08885-81081 is actually a can of 08885-81080 with a new label slapped on for Toyota Motor Europe.
    The Ravenol application guide on their website recommends their SAE 75W Manual Transmission Fluid - MTF-3 for 2014+ 5.7L (3UR-FBE) transfer case. http://www.ravenol.de/en/oil-guide.html
    15whtrd likes this.
  13. Oct 26, 2017 at 5:58 PM
    BIGUGLY
    Paul
    2018 Limited
    Have you tried royal purple.
    UTTundra likes this.
  14. Oct 26, 2017 at 6:24 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
  15. Mar 14, 2018 at 1:41 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I did use Ravenol about 6000 miles ago. Have not noticed any difference from the OEM fluid. I know there's been a few other guys running Ravenol as well.
    15whtrd likes this.
  16. Mar 14, 2018 at 7:01 PM
    15whtrd
    15whtrd Mr. Blonde
    What did you run in your diffs?
  17. Mar 14, 2018 at 7:08 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I use Redline 75w85. You can usually find it online for $13-15 per quart.
    15whtrd[QUOTED] likes this.
  18. Mar 14, 2018 at 7:14 PM
    15whtrd
    15whtrd Mr. Blonde
    I used royal purple about 17,000 miles 75w90 in everything.
    I’m thinking of ordering that ravenol for the TC. Because now I’m worried. I went off an old thread a couple years ago when I did it.
    Figuring the 07 through 15 we’re all the same. I’m pretty sure the royal purple was probably OK in the diffs. But I’m thinking of changing them again too. I wonder how critical it is to use 75w85?
  19. Mar 14, 2018 at 7:25 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Have you noticed anything running the Royal in the TC? I’ve heard the RP Synchromax is suitable for the TC, but still thicker than a 75w. Sounds like many dealers are still using 75w-90.
  20. Mar 14, 2018 at 7:33 PM
    15whtrd
    15whtrd Mr. Blonde
    No it seems fine engages quickly. Disengagement is quick unless I continue straight, then the 4hi flashes until I make a turn. I changed the fluids so early in the life of the truck (3k) that I honestly don’t remember how it was before. Im at 20k now.
  21. Mar 14, 2018 at 7:35 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
