Front locker on 1st Gen
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Apr 4, 2021.
  1. Apr 6, 2021 at 7:18 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Harrop's been mentioned...:thumbsup:
    https://www.harrop.com.au/shop/products/elocker
    "In collaboration with Eaton Corporation we have developed the Harrop Eaton ELocker Differential for a range of popular 4WD vehicles."
    CS_AR, KarmaKannon and Voss[OP] like this.
  2. Apr 6, 2021 at 8:09 AM
    Voss
    Voss [OP] Not a new member
    2003 AC TRD 4x4
    Eaton and Harrop are the same locker?...
  3. Apr 6, 2021 at 8:15 AM
    Voss
    2003 AC TRD 4x4
    Question... if you wanted to install a true locker and regear at the same time, would the locker be specific to the new gear ratio? Say if the Harrop fits our trucks front end, would it no longer fit if we went from the 3.91 to the 4.56 gears?
    As always, appreciate you all!
  4. Apr 6, 2021 at 8:20 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Warning....conjecture incoming....
    Eaton does not sell an e-locker for any Toyota product. I'm guessing that the statement above means that Harrop licensed Eaton's technology and used it to create e-lockers for Toyota products that are very popular in Australia. That licensing fee would also help explain the high $$$$ cost of the Harrop which, IMHO, seems a good 40+%+ too expensive for what it is....
    I'm not sure why Eaton doesn't make one for Toyotas....:confused:
    Voss[QUOTED][OP] likes this.
  5. Apr 6, 2021 at 8:30 AM
    speedtre
    speedtre New Member
    Inland Northwest
    The locker is generally independent of the ring/pinion gears...generally a given locker will fit a range of gear sizes on a a vehicle it was designed for.
    If you have a 30 minutes to kill, this is a good video to watch about lockers, but not specific to your question.
    https://www.youtube.com/watch?v=x40WGUtdaLI
    CS_AR, 5N0W808 and Voss[QUOTED][OP] like this.
  6. Apr 6, 2021 at 8:35 AM
    Voss
    2003 AC TRD 4x4
    Thank you
    speedtre[QUOTED] likes this.
  7. Apr 6, 2021 at 1:59 PM
    Voss
    2003 AC TRD 4x4
    Buy once, cry once is what you all have taught me. Eaton front locker on the way. Thinking I'll combine it with an Eaton Truetrac in the rear like the video suggests and might as well regear while I'm at it.
    Thanks @tyler-brown for bringing Eaton to my attention and thank you everyone for always chiming in and pointing me in the right direction.
    I wrote off the autolocker after reading about how the ADD system works. Seemed to me it would cause issues down the road even if I could deal with the noted steering problems.
    $$$ being spent but I've had to "send it" a few times in the past, this all should help avoid potential breakdowns out in the middle of nowhere.
    CS_AR, KarmaKannon and KNABORES like this.
  8. Apr 6, 2021 at 2:39 PM
    tyler-brown
    tyler-brown New Member
    Canada, B.C.
    2001 AC Tundra V8 LTD 4x4
    5" tuff country lift 2.5" Eibach front coil overs SPC upper control arms 33x12.5's JBA long tubes Jba mid pipes Jba full exhaust & muffler Dirty deeds 12 hole injectors Front hitch receiver
  9. Apr 6, 2021 at 3:17 PM
    Voss
    2003 AC TRD 4x4
    That one is $30 cheaper than the one I bought from 4wheelparts.
    tyler-brown[QUOTED] likes this.
  10. Apr 6, 2021 at 3:24 PM
    Voss
    2003 AC TRD 4x4
    Their gears I found for $981 @ SummitRacing vs the $1,080 on their site just fyi
  11. Apr 6, 2021 at 5:10 PM
    tyler-brown
    Canada, B.C.
    Awesome! thanks for the info and putting in the leg work! ha
  12. Apr 7, 2021 at 5:04 PM
    Voss
    2003 AC TRD 4x4
    Ok the front Eaton locker, Nitro 4.56 gears and a Nitro Helix™ 8.4" Helical Gear LSD are on their way. Found a gear shop near by with a ton of good(4.6 overall) google reviews who said they'd install everything for $700ish if I took them the parts and the pumpkins. Big expense but for what I have planned for this truck, it's going to be well worth it.
  13. Apr 7, 2021 at 7:06 PM
    tyler-brown
    Canada, B.C.
    That's awesome man! You got pretty much what I wanted! The gear set, and front locker. Except i already have the LSD rear.
    Congrats!
    Sounds like you'll have yours done before me. Have to report back how the 4.56s are
    Voss[OP] likes this.
  14. Apr 7, 2021 at 7:16 PM
    Voss
    2003 AC TRD 4x4
    Will do bud. I have a LSD now but at 200k miles, I can’t see it being very effective at this point. The one I got says it doesn’t wear out and was told it’s better than Eaton Trurtrac. I figure might as well go for a new one while the gears are being replaced.
    oh, might want to take a look at justdifferntials. they didn’t charge me sales tax! I’m in Cali so 10% savings right there.
  15. Aug 21, 2021 at 7:28 PM
    tyler-brown
    Canada, B.C.
    So...any update? Recommendations? Things you wish you'd done different/could or would change?
  16. Aug 22, 2021 at 10:08 AM
    Voss
    2003 AC TRD 4x4
    Haven’t driven much lately and haven’t had a chance to test out the new LSD or Locker but happy with the regear so far.
    Darkness likes this.
  17. Nov 23, 2021 at 5:59 AM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    6 month review? There's some sales that may pressure me.
    Darkness and FrenchToasty like this.
  18. Nov 23, 2021 at 8:08 AM
    Voss
    2003 AC TRD 4x4
    I would give the past 6 months of life 0 stars… I haven’t had a chance to test them out really. Off-road just a handful of times and never needed the lockers.[/QUOTE]
  19. Nov 23, 2021 at 8:30 AM
    #49
    Casper421
    In the woods
    06 DC
    @Voss How do the 4.56’s feel?
  20. Nov 23, 2021 at 8:34 AM
    #50
    Voss
    2003 AC TRD 4x4
    Very happy with them. Would do it again in a heart beat.
    CS_AR and Casper421[QUOTED] like this.
  21. Nov 23, 2021 at 8:39 AM
    #51
    Casper421
    In the woods
    06 DC
    You’re on 33’s with minimal added weight right? Did 4.88’s cross your mind at all?
  22. Nov 23, 2021 at 8:45 AM
    #52
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Right, my truck isn’t getting any lighter…..
  23. Nov 23, 2021 at 8:47 AM
    #53
    Voss
    2003 AC TRD 4x4
    33’s, full skids with sliders and a bed rack for RTT in the works. I went with 4.56 based on info I got here. On long trips where I drive 80+mph I figured 4.88’s would have high RPMs. With the 4.56 I’m under 3k RPM between 80-90mph and mid to low 2k RPM around 75mph so it’s worked out well for me.
    Edit to elaborate on the 4.56, there is a high incline section of the 5north freeway when driving north from LA. Very steep incline where trucks manage 30-40mph id assume cause they seem like they are parked.
    I wasn’t loaded when I went up that section and averaged 70mph at around 2,100rpm. Never having to downshift to maintain speed or accelerate. That was the moment I felt the 4.56 were perfect for what I needed.
    FirstGenVol, bmf4069, Sunnier and 3 others like this.
  24. Nov 23, 2021 at 8:56 AM
    #54
    Casper421
    In the woods
    06 DC
    Same with Big booty Judy! She might be adding another 1k pounds next year. ;)
  25. Nov 23, 2021 at 8:57 AM
    #55
    Casper421
    In the woods
    06 DC
    Sounds good! I went with 4.88’s after considering 4.56’s for years. Hope I made the right call.
  26. Nov 23, 2021 at 8:58 AM
    #56
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Noticable fuel milage hit with 4.56s? Id expect some, but not too much, 4.7 likes to spin.
  27. Nov 23, 2021 at 8:59 AM
    #57
    FrenchToasty
    Mo
    Bone stock
    Shouldn’t it get better mileage?
  28. Nov 23, 2021 at 9:05 AM
    #58
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I recovered some mpg. A hit compared to a stock truck, maybe. Compared to a truck on 33s, the 4.56 improved economy vs the 3.91gears I had.
    Now, that was an unintended benefit and I don't claim it will do the same for everybody, nor is the cost of gearing going to pay itself off. I did it for the torque only.
  29. Nov 23, 2021 at 9:06 AM
    #59
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Maybe with bigger tires in city driving. I was thinking more along the lines of highway milage where taller is better.
  30. Nov 23, 2021 at 9:11 AM
    #60
    Voss
    2003 AC TRD 4x4
    Mpg improved. Hit 17mpg a few times with freeway driving and 13-14 city. But after the headers went in(and this may only be because I’ve been a little heavy footed enjoying myself lately) freeway down to 15 with city around 12.
    5N0W808 and Darkness like this.
