Front License Plate Screw Holes
Discussion in '2.5 Gen Tundras (2014-2021)' started by awq735, Jul 2, 2020.
  1. Jul 2, 2020 at 4:52 PM
    awq735
    awq735 [OP] New Member
    Anthony
    Ohio
    2019 Tundra Sport, MGM
    Does anyone have any suggestions of how to make the front bumper license plate screw holes less noticeable? Ohio recently did away with the front plate requirement and I just removed mine.
  2. Jul 2, 2020 at 4:54 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Aftermarket bumper time!
    BravoDeltaRomeo likes this.
  3. Jul 2, 2020 at 5:04 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Maybe using the small ones to plug it.
    NewImprovedRon likes this.
  4. Jul 2, 2020 at 5:07 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Silicone and some touch up paint.
    They are not to noticeable as is, I had to zoom in the find them
  5. Jul 2, 2020 at 5:21 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  6. Jul 2, 2020 at 5:26 PM
    awq735
    Anthony
    Ohio
    I like the way you think, but not in the budget!
  7. Jul 2, 2020 at 5:28 PM
    awq735
    Anthony
    Ohio
    I do have some touch up paint so I might try to add one of these and then just paint them!
  8. Jul 2, 2020 at 5:30 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Ah, I just realized you had the color matched insert... I think my wife's old Explorer was white, so I primed and painted those and it worked well.
  9. Jul 2, 2020 at 5:32 PM
    biebs96
    PA
    I plugged up mine on 2010 and that was actually more noticeable then me just leaving the two of them empty on my 2017.
  10. Jul 2, 2020 at 5:44 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Maybe add something like this, fake winch....
    awq735[OP] likes this.
  11. Jul 3, 2020 at 3:29 PM
    awq735
    Anthony
    Ohio
    Explor20200703_164555.jpg 20200703_164553.jpg 20200703_170330.jpg 20200703_170333.jpg er was white, so I primed and painted those and it worked
    Found these in my garage today from my past truck.
    It will work for now. Either way I can remove them with no issues later if I dont like them!
    Jbehredt likes this.
  12. Jul 3, 2020 at 4:00 PM
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Harbor Freight has a small soldering iron (call it a plastic welder) which you could use some of the plastic rods to fill the holes. Tape outside surface and fill from inside...will create a pretty smooth finish which could be lightly sanded with some very high grit sandpaper.
