Front frame clip compatibility
Discussion in '1st Gen Tundras (2000-2006)' started by Tucker Too, May 22, 2020.
  1. May 22, 2020 at 5:30 AM
    Tucker Too
    Tucker Too [OP] New Member
    I am wondering if the front frame section from a 2000 TRD 4wd access cab is the same as the front section of a 2006 TRD crew cab. I have both trucks and the 2000 has a new frame, the 2006 has rot on the front section. will everything mount correctly if I section them together at the factory welds behind the front cab mounts? The measurements are the same so far but I'm concerned about everything fitting such as body/engine mounts.
  2. May 22, 2020 at 6:14 AM
    Professional Hand Model
    Hand Protectors
  3. May 22, 2020 at 6:31 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
  4. May 23, 2020 at 1:05 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    youd probably be better off selling the new frame to pay for a clean used frame on the double... the frames should fit fine.. but if the doubles frame has rot it will only be a matter of time for it to spread to the front again
  5. Sep 19, 2022 at 1:07 PM
    ClappedOutTundra
    ClappedOutTundra New Member
    2006 Tundra
