Front end popping noise on my '05
Discussion in 'General Tundra Discussion' started by eward4, Mar 5, 2018.
  1. Mar 5, 2018 at 7:23 AM
    eward4
    eward4 [OP] New Member
    This just started about a week ago. My '05 is making a popping/knocking noise when accelerating through 1st and 2nd gear then it quits. This happens while driving straight. Turning doesn't seem to cause it like a bad CV axel. I'm about to take it in for a diagnosis but thought I'd check here first. The truck has 270k miles with everything in the front end original. Thanks in advance for any ideas!
  2. Mar 5, 2018 at 1:23 PM
    eward4
    Well, after trying to get a better idea where the noise is coming from it now sounds like it could be towards the middle or rear of the truck. I rolled my windows down to try to get a better listen. It seems to do it right between 5 and 10 MPH and only seems to do it while it's in gear. I put it in neutral a few times approaching stoplights and it didn't do it but would when in gear. The rear end has new bearings. I'm stumped.
  3. Mar 5, 2018 at 3:35 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Have you checked the carrier bearing and u joints for play?
  4. Mar 5, 2018 at 3:42 PM
    eward4
    I haven't. I'll take a look at them tomorrow.
  5. Mar 7, 2018 at 12:46 PM
    eward4
    There's about 1/2" of play in the center support bearing and I have a feeling this may be the problem. It's the original with 270k miles on it. I put a go pro under the truck while driving it but I'm still having a hard time pinpointing the clunking noise. Should there be any play at all in the center support bearing?
  6. Mar 7, 2018 at 1:20 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    It should move a little a half inch sounds about right. If the rubber is dry rotted though it couldn't hurt to replace it anyway.
    One other thought the slip yoke may need to be cleaned up and greased.
    eward4[OP] likes this.
