Front end popping noise - brand new Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by zoomie1983, Dec 1, 2017.
  1. Dec 1, 2017 at 8:24 AM
    zoomie1983
    zoomie1983 [OP] New Member
    2017 Inferno Tundra SR5 TRD
    Weathertech Mats NoxLux Blackout Kit Future TRD Pro Grill and Hood Bulge Leveling Kit BFG AT KO2 Tires LED Headlights TRD Rear Sway Bar TRD Cold Air Intake Center Console Safe
    Hello all.. first post here. I searched but couldn't find anything regarding this.
    Bought my 2017 Inferno Tundra SR5 TRD DC back in October. I love it! Its been a long time saving and waiting and the day finally came. It has about 2000 miles on it now.. took a road trip down to Texas. But....
    even before this trip i noticed a very faint popping noise in the front end. I notice it when the truck is cold and going at a slow speed (less than 15-20mph). sounds like popcorn popping. I hear it when i come to a stop and then when i let off the brakes to accelerate. Again, just at slow speeds. I also hear it backing up and going forward and when making sharp turns. This has been going on since new. I don't hear it as much once the truck has been driven awhile, but its still very faint. After a couple thousand miles now, the sound is still there and seems a bit louder, but not much.
    Ive taken it back to the dealership twice and they can't seem to find anything wrong. They have greased and tightened everything. Taken off the skid plate up front and the sway bar and taken it for a test drive before and after. Still makes the noise. They have no clue. They also said they called toyota and they don't know either. Im pretty much at a dead end. They said to bring it back if it gets worse. Its super annoying to have a brand new truck doing this. Its not huge, but just disappointing.
    Any ideas or thoughts?
  2. Dec 1, 2017 at 8:26 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Is it only once, each time you start it up, right around the 15mph mark? If yes - thats the ABS running its check, and they all do it. Its especially noticeable if you lock your doors before you take off... since they autolock (in my truck) at the same speed as the ABS check and kind of drown it out.
    -Jim
    YsoSeRiouS! and joonbug like this.
  3. Dec 1, 2017 at 8:30 AM
    zoomie1983
    no.. its less than 15 and it is a continuous sound; mostly when I'm going pretty slow. it happens especially when turning.. almost like a bad cv joint, but obviously thats not it. it does it every day and I've kind of gotten used to it, but damn its annoying.
  4. Dec 1, 2017 at 8:37 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Did the dealership rotate the tires? If they put the front ones onto the back and the noise goes away, could be a tire issue.
  5. Dec 1, 2017 at 8:46 AM
    zoomie1983
    i don't believe so... when i take it back in, ill put it on the "try this" list.
  6. Dec 1, 2017 at 8:48 AM
    zoomie1983
    now that i think about it.. i have heard that noise and was wondering what that was. its definitely not it though.
  7. Dec 1, 2017 at 9:07 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Popping noises in these trucks can be the lower control arm / alignment cam bolt being under torqued.
    AgileTundra, 15whtrd and TheBeast like this.
  8. Dec 1, 2017 at 9:16 AM
    TheBeast The Beach
    does it sound like metal ? like a clunk sound ? passenger or driver side ?
  9. Dec 1, 2017 at 9:21 AM
    Upper control arms?
  10. Dec 1, 2017 at 10:14 AM
    Marty McFly
    Morty McBoonJug
    Maybe posting a video of the sound on here might help everyone. I crank the radio up as soon as I hope in the truck. I should prob listen to my truck more.
    TheBeast likes this.
  11. Dec 1, 2017 at 12:32 PM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    mine does this. low speeds when turning and going over bumps. def feels like front end. I keep telling myself its the RCI skidplate but i've been too lazy to take it off and check if the popping stops.
  12. Dec 2, 2017 at 4:15 AM
    zoomie1983
    I’ll see if I can record a quick video in the morning when it’s at its worst. That may help a bit. Thanks all.
  13. Dec 2, 2017 at 4:41 AM
    So why is it obvious that a CV joint not being bad? Because your truck is new?
    This is in the drivetrain somewhere.
    What we know:
    -turning at low speeds and low speeds forward and reverse.
    Tested:
    -skid plate off
    -greased u-joints/chassis.
    Problem still exists.
    Where to go from here:
    I would be the bane of the service managers existance. That truck would be in weekly until repaired or start looking into lemon Law/ new vehicle replacement. Look into getting a loner vehicle.
    What could it be?
    -is the sound from one side or the other? Front to back? Does this do it in 4wd?
    -rotational items it could be:
    Front/rear differential, u-joint, cv-joint, transfer case, transmission, wheel bearing.
    Since you said it definitely apparent during turns, is it worse turning left or right? The same?
    Turning makes me wonder about cv shafts or front differential. Turning and the sound going away would make me suspect the wheel bearing. Maybe something is not fully engaging/disengaging in the 4wd system.
    NR-J, joonbug and Slayer like this.
  14. Dec 2, 2017 at 5:20 AM
    Slayer
    Slayer Member
    Slayer
    Agreed...
    Be the biggest pain in the a$$ until it's taken care of
  15. Feb 3, 2018 at 8:31 AM
    ARES
    ARES ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
    Bringing back an old thread. Did issue ever get resolved? My 2018 does this exact same thing. Its like the very first turn out of my driveway it does this. Turning left or right same issue both up front. If I come to a complete stop and turn sharply it does it also.
  16. Feb 3, 2018 at 10:20 AM
    ChiefB
    ChiefB New Member
    My 2018 does the same thing. Any solutions identified?
  17. Feb 3, 2018 at 10:27 AM
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Mine does the same thing and I’m pretty sure it’s the body mounts. My 15 Tacoma also did it.
    It’s most noticeable in the cold and when turning while the vehicle flexes over a bump.
  18. Feb 6, 2018 at 4:55 PM
    Fernando
    Fernando New Member
    I got my brand new Tundra 4x4 2018. It will do the same. Brought back to the dealer and the service manager had drove with me. He said it's normal as the ABS initiates to check. My previous Tundra 2006 4x2 doesn't have this problem. It does bother me a bite when ever I take off.
    Any other solution for this would be very appreciated.
    ARES likes this.
  19. Feb 6, 2018 at 5:00 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    I would put it on jack stands and see if it replicate itself then. Uncertain how traction ctrl etc would behave with wheels suspended.
    IMO
    Fernando likes this.
  20. Feb 11, 2018 at 3:31 PM
    Maynard
    Maynard New Member
    Did you ever fix a fix? I having the exact popping noise you described on my 13 tundra.
  21. Feb 11, 2018 at 5:01 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Guys. It' normal. Bet it happens every time you start the truck and go forward within 30 feet.
  22. Feb 14, 2018 at 3:08 AM
    ARES
    God Bless America
    Yes everytime I come to a stop shut the truck off and run an errand it does it again so Im guessing this is normal just strange. These trucks have a lot of noises.
  23. Feb 14, 2018 at 6:52 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    My truck was doing the same when turning at slow speeds, 7" BDS lift. Sway bar links needed attention, changed my diff fluids helped a bit, replaced my steering rack bushings and the sound completely went away.
  24. Feb 14, 2018 at 8:22 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    #metoo
    lotsip likes this.
  25. Jun 5, 2018 at 10:20 AM
    2018_10dra
    2018_10dra New Member
    2018 Tundra TRD Limited
    Mine does the same thing 2018 Tundra Limited! How could this be normal if you're hearing something sounds like loose underneath on a brand new vehicle?
    lotsip likes this.
  26. Sep 25, 2018 at 1:48 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Old thread but has anyone resolve there popping noise..(not ABS check)
    lotsip likes this.
  27. Sep 25, 2018 at 2:14 PM
    Marty McFly
    Morty McBoonJug
    I know that for myself and another member on here. We both have PROs and had the same popping noise at slow speeds. It turned out to be the skid plate missing a spacer. Not sure what other packages have the trd skid plate but if you do have one, I’d check that.
  28. Sep 25, 2018 at 2:16 PM
    saybng
    Gary
    Ventura CA
    I removed my skid plate and still feel this popping on my steering wheel low speeds, stop and go traffic..happens randomly,,no idea what it is..
    Edit: I actually feel it on my steering wheel no noise at all as far as I can tell.
  29. Sep 25, 2018 at 2:19 PM
    Marty McFly
    Morty McBoonJug
    I just had my skid plate fixed last week. My truck sounds normal for once. That’s weird if it’s not the skid plate. I’d go back to the dealer
    saybng likes this.
  30. Oct 1, 2018 at 5:28 PM
    906UP
    906UP New Member
    Same issue here, took my skid plate down and put some foam rubber tape on the 2 areas that showed rub marks and the rear cross member, noise is gone!
    New_DoorDing likes this.
