Front end parts help
Discussion in '1st Gen Tundras (2000-2006)' started by txagg, Jan 12, 2022.
  1. Feb 15, 2022 at 5:57 PM
    txagg
    txagg [OP] New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    The over 20 year old factory struts with 150k miles on them still worked and the bushings even looked okay:
  2. Feb 15, 2022 at 6:03 PM
    txagg
    Central Texas
    Stone cold stock
    My summary after the rebuild:
    - The spacer combo I used was perfect in my opinion. The truck now sits up much better in the front, but still has some rake as intended from the factory.
    - The main thing I noticed from the suspension was less body roll, there is an incredible difference in this department.
    - The steering turns much easier and there is no play now. It only takes one finger to turn, and on the highway it tracks better. We just eye balled the alignment, but will get that done in a week or so.
    I feel like she's ready for another 100k+ miles, and am very pleased with the results for the cost. Saved a ton doing it myself.
    Sirfive likes this.
  3. Feb 15, 2022 at 6:13 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    What components from MOOG were recently recalled
  4. Feb 15, 2022 at 6:53 PM
    txagg
    Central Texas
    Stone cold stock
    Ball joints. I went with OEM for mine. I will say, I was not happy with the Moog end links as the threads were machined very poorly. I was unable to use them, the nut would not even thread on them.
  5. Feb 16, 2022 at 3:26 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Hmmm, I just ordered a set of those. I may pop the box open and check them.
    txagg[QUOTED][OP] likes this.
  6. Feb 16, 2022 at 9:04 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Pics? Kinda curious; mine were fine when I picked up mine from Advanced Auto but that was several years back.
  7. Feb 16, 2022 at 3:01 PM
    txagg
    Central Texas
    Stone cold stock
    I can get some, left them over at my buddies place. The suppled nuts would thread on the OEM ends I took off. The nuts from either set would not thread onto the new end links. Sucked bad because I was on a time crunch and that was the last thing I needed to button up when I dropped the truck. Had to take them off and put the old ones back on.
  8. Feb 16, 2022 at 3:27 PM
    Jack McCarthy
    Bill
    North of Boston
    Well you could've drove without them, but that's in the past. If you're not completely turned off to Moog, I'd suggest just getting them locally so they can easily be swapped out for good ones. Hopefully, thats a one time occurrence.
  9. Feb 16, 2022 at 7:37 PM
    txagg
    Central Texas
    Stone cold stock
    That's what I was originally going to do, but the ones I took off it looked and felt good so just threw them back on. I was anxious to see the difference all the work I had done made.
  10. Feb 17, 2022 at 1:21 PM
    If the Moog are OE style, you could just rob the new bushings off of the Moogs and put them on the OE links.
    txagg[OP] likes this.
