Front End Jack Point
Discussion in '2.5 Gen Tundras (2014-2021)' started by rustynail11, Sep 11, 2019.
  1. Sep 11, 2019 at 4:09 PM
    rustynail11
    rustynail11 [OP] New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Need an assist here. Changing out my brake pads. Did the rear no problem got the truck lifted is the pumpkin as my jack point.
    Moved to the front and get it high enough of the ground to lift the tires placing the jack on the cross member or the frame. I am using a 7 ton floor jack. My jack stands have disappeared so I am just using the jack for support to do a quick pad change. I know it isn't the safest but it is all I got right now.
    Can I use the LCA as a jack point to get the tires up to change the brake pads?
  2. Sep 11, 2019 at 4:10 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Buy new jackstands
  3. Sep 11, 2019 at 4:12 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Yeah Scott, I agree with Mark. At least buy one jack stand and the jack and stand under it. You sure don't want any mistakes...
  4. Sep 11, 2019 at 4:19 PM
    rustynail11
    Scott
    Neighbor just came over with some 3 ton jack stands are those beefy enough? If so where do I place the jack and where do the jack stands go ?
    Sorry for dumb questions but first time lifting this thing off the ground. Used to my Wrangler which was small, light and solid front axle making it much easier
  5. Sep 11, 2019 at 11:19 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I put the jack on the crossmember where the LCA meets the frame.
    Jack stands on the frame under the front doors.
    15whtrd likes this.
  6. Sep 12, 2019 at 10:43 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    What's an "LCA"?
  7. Sep 12, 2019 at 10:45 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Lower control arm
    15whtrd likes this.
  8. Sep 12, 2019 at 10:47 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    Ah-so, thanks!
    kenomouth64[QUOTED] likes this.
  9. Sep 12, 2019 at 10:57 AM
    15whtrd
    15whtrd Mr. Blonde
    Every time I put my truck up on jackstands, I’ve used the frame and pumpkin as jack points. I put the jack as far forward as I can leaving room to put a jackstand in front of it.
