Front end issues
Discussion in '1st Gen Tundras (2000-2006)' started by MickeyC, Sep 11, 2018.
  1. Sep 11, 2018 at 9:05 PM
    MickeyC
    MickeyC [OP] New Member
    2006 tundra 2wd
    i have a 06 2wd and I’m having a popping noise in my front end while driving. It pops when I accelerate from being stopped and also when I make turns. I’ve had the lower ball joints replaced due to a recall and have had the lower control arms replaced also and the popping noise is still happening. Has anyone else encountered this problem, if so can you help me out so I’m not spending a ton of money chasing the problem. Thanks
  2. Sep 11, 2018 at 9:08 PM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    TC LT w/ king 2.5 C/O and bypass, ADS bypass rear, Toytech shackles, TRD dual exhaust dumped, KM3 37s on Method standard +18. N_Fab front bumper, Westin rear w/ hitch relocate, RCI skids, Desert Eagle tranny skid, All Pro sliders, ARB dual compressor, 5.29 gears and ARB rear locker
    Welcome. Sorry I can't help with your question. Have you checked the swaybar?
  3. Sep 11, 2018 at 9:23 PM
    Tierhog
    Tierhog New Member
    California
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories
    Worn shock bushings?
    Sway bar/Links?
    Failed CV axle or ball joints (lifted generally accelerates wear)?
    Tie rod ends?
    Upper control arm bushings?
    Frame/body bushings/bolts
    Lug nuts tight?
  4. Sep 12, 2018 at 2:01 PM
    MickeyC
    2006 tundra 2wd
    I have not checked the sway bar yet. I did take it to my local Toyota dealer and they told me it was the lower control arms. I used my local garage to replace them for $600 since the dealer wanted $1600 to replace them. That wasn’t the problem so that’s why I reached out to see if anyone else has had this problem. I appreciate yalls help and will go from here on trying to figure out what the issue is. Btw the truck is all stock, never done any mods to it since I bought it new.
  5. Sep 12, 2018 at 3:19 PM
    Tierhog
    Tierhog New Member
    California
    Understandable.. it’s tough to diagnose as any othe above listed issues will cause the symptoms. You have to physically inspect each item to find the discrepancy. Since the approach is to simply replace and move on (granted it’s the mechanics choice not yours) it will prove costly.
    I guess the only positive is you’ll have a new front end.
  6. Sep 12, 2018 at 3:34 PM
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    Try spraying lithium grease or something similar on different joints, bushings etc. until the squeak goes away.
  7. Sep 12, 2018 at 9:14 PM
    MickeyC
    2006 tundra 2wd
    I appreciate all the helps guys. As soon as I figure out what’s making the popping noise in the front end I’ll post on here so maybe it will help someone else. Yes, maybe after it’s all said and done, I will have a rebuilt front end.
  8. Sep 12, 2018 at 9:35 PM
    SR5 AZUL
    SR5 AZUL TRD
    2015 Blue Ribbon Tundra SR5 Trd off road crewmax 4x4
    WELCOME
  9. Sep 13, 2018 at 6:59 AM
    TX-TRD1stGEN
    TX-TRD1stGEN ...
    Seth
    South East Texas
    2000 Tundra 4x4
    Disconnect the sway bars and take it for a test drive to see if it goes away.
