Front end hard drift to the rh after installing 20x9 on 35x12/50 tires
Discussion in '2.5 Gen Tundras (2014-2021)' started by SACACOCO, Apr 6, 2016.
Can caster and camber be affected by a set of 20/9 on 35x12/50 tires
  1. Maybe caster and camber
    0 vote(s)
    0.0%
  2. Not a tire pull
    1 vote(s)
    100.0%
Multiple votes are allowed.
  1. Apr 6, 2016 at 3:08 PM
    SACACOCO
    SACACOCO [OP] Front end hard drift to the
    EDGAR LOPEZ
    2015 TOYOTA TUNDRA 1794 4X2
    3 INCH LEVELING KIT ONLY INSTALLED KMC XD SERIES 20/9 HOSS WHEELS MOUNTED ON 35X12/50 FEDERAL COUGIAS
    20160406_132659.jpg 20160406_132724.jpg 20160406_132724.jpg 20160406_132659.jpg
    Grizzly660 likes this.
  2. Apr 6, 2016 at 3:16 PM
    Did you only switch tires, or did u touch anything suspension wise?
  3. Apr 6, 2016 at 8:07 PM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    Did they install the tires in the the right direction ?
  4. Apr 6, 2016 at 10:04 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    i was thinking if you did add that 3" leveling kit you definitely need an alignment and might just consider one just in case.
    i agree with this as well.
    btw op... your truck looks great!
  5. Apr 7, 2016 at 1:19 PM
    SACACOCO
    EDGAR LOPEZ
    Hey Sean thanks I have only added a level kit only in front and that was with the factory tires camber and alignment was resetted then and it was perfect but the minuted I installed the wheels and tires now this and tires have also been cross rotated I will be taking it to Tires country in Fortlauderdale who says this can be fixed is just I do not have a machine so u know how that goes was just wondering if any one had ran in to this before just a 3 Inch leveling kit
  6. Apr 7, 2016 at 1:22 PM
    SACACOCO
    EDGAR LOPEZ
    Yes tires are correctly installed direction wise thanks bigoltater
  7. Apr 7, 2016 at 1:44 PM
    SACACOCO
    EDGAR LOPEZ
    I have an off road shop In Fortlauderdale who strictly deals with this and will get it done thanks boys
  8. Apr 7, 2016 at 7:45 PM
    Ehunter
    Ehunter New Member
    2015 White Tundra XP
    32" Grill Led Bar Led Back up lights BR5 Front Bumper/ 24" light bar Warn 10,000# winch Tow Mirror OEM Brake Controller Bakflip G2 Bed Cover
    Had the same problem after the leveling kit was installed. Did a 3/2 and the dealer did the alignment and could never get it right. Took it to a Off-road shop and never had another problem. Put 35,000 miles on the same alignment with no issues..
  9. Apr 25, 2016 at 6:25 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Most likely the dealer was aligning the truck to factory specs. On my lift, I believe the camber is suppose to be 2 degrees off.
  10. Aug 14, 2016 at 7:02 AM
    Lee's rig
    Lee's rig Party naked
    Lee
    North nj
    2014 DC and 2014 single cab both 8' bed with 5.7
    To many
    Could the wheel be pushing the caliper?
