Front end click noise?
Discussion in '2nd Gen Tundras (2007-2013)' started by Casaus26, Oct 14, 2020.
  1. Oct 14, 2020 at 4:18 PM
    Casaus26
    Casaus26 [OP] New Member
    Shawn
    2012 Toyota Tundra
    BDS 7-inch suspension, TRD intake & dual exhaust, Fuel-Hostage 22x12 on Nitto Mud Terrains 37x13.50’s, Tanneau cover and Rockford Fosgate Audio system with one 12” sub.....I also have the truck ceramic Opti-coated
    I have a question: I have a 7” BDS lifted 2012 Toyota Tundra on 22”s with 37X13.50’s. When I start or stop while turning, I hear this front end “click noise” I have taken it several places, including Toyota and the place that lifted the truck and had the lift tightened, there seems to be no answer to this question and the “click noise” continues, can anyone help???
  2. Oct 17, 2020 at 3:26 PM
    Gto7419
    Gto7419 New Member
    2010 Tundra
    Does the clicking increase or decrease in frequency in relation to your speed?
  3. Oct 17, 2020 at 3:48 PM
    Casaus26
    Shawn
    2012 Toyota Tundra
    It doesn’t happen when I’m driving, only when I’m stopping, backing up, or parking. Any thoughts?
  4. Oct 17, 2020 at 3:51 PM
    Gto7419
    Gto7419 New Member
    2010 Tundra
    Yeah, clicking during low speed maneuvers with the wheels turned is indicative of an axle issue. You can check this on jack stands. Keep a hand on the axle shaft with the steering wheel cracked. Rotate the tires and see what you feel.
  5. Oct 17, 2020 at 4:06 PM
    Kanobi13
    Kanobi13 New Member
    Have u gotten alignment?I had clicking noise as well after level after alignment stopped.
  6. Oct 17, 2020 at 4:15 PM
    Gto7419
    Gto7419 New Member
    2010 Tundra
    I'm not sure how an alignment could cause clicking. You may have had something loose...
  7. Oct 17, 2020 at 4:18 PM
    Kanobi13
    Kanobi13 New Member
    All they touched and went away i re torq all the bolts multiple times in search of it so going off process of elimination.
  8. Oct 17, 2020 at 4:19 PM
    Kanobi13
    Kanobi13 New Member
    I guees mine was more of a poping then
  9. Oct 17, 2020 at 5:16 PM
    Geo4x4
    Geo4x4 New Member
    2010 Rock warrior
    Is your tpms light on? I had a sensor break when they installed my tires and it would click at real slow speeds. Pretty much only at starts and stops.
  10. Oct 17, 2020 at 8:33 PM
    Casaus26
    Shawn
    2012 Toyota Tundra
    No, no lights or indicators on, it’s at the toyota dealership now, I told them about all the info you both have provided, let’s see what they come up with, thank you!!!!
