front door window belt molding or seals
Discussion in '1st Gen Tundras (2000-2006)' started by healeyman, Aug 13, 2018.
  1. Aug 13, 2018 at 6:36 PM
    healeyman
    healeyman [OP] New Member
    Hello all.
    I have a 2002 Tundra extra cab limited 4x4.
    The window seals, the ones that rub on the glass, on the outside of the 2 front doors are peeling and falling apart. I have looked through the online Toyota websites but all they list is the ones for the 2 door cab and not the extended cab. Does anyone know the part numbers for these seals.
    Thanks,
    Pete
    Black Wolf likes this.
  2. Aug 13, 2018 at 6:41 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    @Roman
    NewImprovedRon likes this.
  3. Aug 13, 2018 at 6:41 PM
    Aurora CO
    Welcome from CO Pete!
  4. Aug 13, 2018 at 6:50 PM
    healeyman
    Hello Matt.
  5. Aug 13, 2018 at 6:51 PM
    Aurora CO
    Roman is our forum Toyota parts guru. Just click on @Roman and leave a PM!
    Xsnrg2006 and Roman like this.
  6. Aug 14, 2018 at 7:31 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  7. Aug 14, 2018 at 1:00 PM
    healeyman
    Roman,
    I ordered that part number and it is in my hand as I write this message and it is the wrong part. I removed it from the package and it is completely different. The only thing I can think of is that the part I have is labeled for the earlier model but it is a later model part. Because the part I have in hand doesn't look like the picture of the part number you sent me.
    Pete
  8. Aug 14, 2018 at 1:52 PM
    Roman
    Roman
    Franklin, TN
    It could be that the part was bagged wrong from Toyota. They use the same belt moldings on both front doors from 2000-06. The only one that is different is the double cab in 2004-06.
  9. Aug 14, 2018 at 2:45 PM
    healeyman
    Thanks Roman,
    Looks like the parts were bagged wrong as you suggested. Just ordered again after discussing the issue a second time with the parts guy.
    Pete
    Roman likes this.
  10. Aug 20, 2018 at 9:14 AM
    odom117
    odom117 New Member
    Carson
    2005 White Tundra LTD Double Cab
  11. Aug 20, 2018 at 9:20 AM
    Roman
    Roman
    Franklin, TN
  12. Aug 20, 2018 at 9:40 AM
    odom117
    odom117 New Member
    Carson
  13. Aug 20, 2018 at 9:42 AM
    Roman
    Roman
    Franklin, TN
    No sir. The double cab uses different belt molding for the front doors.
    Xsnrg2006 likes this.
  14. Aug 20, 2018 at 9:51 AM
    odom117
    odom117 New Member
    Carson
    Ah, my bad for misunderstanding. So do you have a part link for the two front doors on a double cab?
    Thanks for your help again
  15. Aug 20, 2018 at 10:04 AM
    Roman
    Roman
    Franklin, TN
  16. Aug 20, 2018 at 10:48 PM
    healeyman
    Roman,
    Thank you for the help regarding the whether strip molding on the front doors. I re-ordered the ones you suggested and they arrived today. They were the correct ones and took approx 2 minutes to install them. My truck now looks as good as new. I purchased this truck from a fellow workmate that bought the truck new in 2002. It is a Limited Model 4X4 with all options available. I bought it 5 years ago and have tried to keep it in the same condition as it was when I got it. In 2013 it had 80k miles on it and had been kept in a garage all of its life. When it was a work it was always parked in the shade so the paint and interior still look almost new apart from normal wear. The truck now has just over 120K miles on it and stills looks great. I paid $10k for it and have had many offers from Toyota owners to buy it but I have refused them all. When I take it in to the dealer for it's routine maintenance the dealer constantly asks me if I want to sell it, NO WAY!!. I'm retired now and this will probably be my last truck. Even my children ask who will inherit it. If I go first then it will be my wife's truck as she loves it as much as I do.
    Thank you again for the advice on the parts.
    Pete
    Roman and NewImprovedRon like this.
  17. Aug 21, 2018 at 8:35 AM
    Roman
    Roman
    Franklin, TN
    Glad I could help. :)
  18. Sep 13, 2018 at 1:41 PM
    troutslayer
    troutslayer New Member
    2002 Tundra SR5
    Roman: I just purchased a 2002 SR5 Tundra Extended cab and the window sill trim is all peeled off. Could you give me the correct part number that I need so I get it right the first time? Sent you a PM also. TIA. John
  19. Sep 13, 2018 at 1:47 PM
    Roman
    Roman
    Franklin, TN
    It would be these^ two for the front belt moldings.
  20. Jul 19, 2019 at 10:11 AM
    smitht1481
    smitht1481 New Member
    Roman, I have 2006 Double Cab and I am trying to identify a part. Not sure what to call it so I'll try to describe. Seems to maybe be part of the belt molding for the rear door but did not come with my replacement molding and cannot find this thing. It is the "L" shaped cap or plug that covers the gap between the rear portion of the belt molding, where it meets the molding that goes up the side of the window. Mine ripped apart when changing the belt molding last year. Any help is greatly appreciated.
  21. Jul 19, 2019 at 11:55 AM
    Roman
    Roman
    Franklin, TN
    PM sent.
  22. Aug 16, 2019 at 6:57 PM
    Xsnrg2006
    Xsnrg2006 Smiley the Tundra
    Dale
    SoFla
    2006 Limited Crew Cab
    Just ordered the 4 pieces front and back, individually, $382 Delivered.
    I added VIN with order just so there is no confusion on part #s. Always shop
    around but it is great to have Roman as a Go To Parts Sorcerer!!!
    I had to get to my Windshield Ext Pillar trims, so stripped and cleaned the upper weatherproof seal that runs from top back all the way forward and down the W.S. pillars, as this must be removed to access the screws for W.S. Pillar Ext Trim. Gotta pull the rubber block to really get in there to clean out. And it was nasty the whole way...
    So yanked out the R.R. belt dressing to get familiar with as well as try to remove the back track ext window molding to reattach the peeling off rubberized cover peeling off. Only broke one clip on Belt, but stopped even trying to pull/replace the rear one. Felt like it would only bust it up and I didn't order one of THOSE yet!
    Talk about digging deeper, I am like 5'6" in.
    subiamer likes this.
  23. Aug 23, 2019 at 6:28 AM
    Cfour
    Cfour New Member
    2007 Grey TRD
    Headlights, wheels/tires, stereo, spray-in bedliner, step boards, misc items
    Sorry to hijack your thread, but I am also looking for front door window seals for my 2007 double cab. The back door seals still look good, but the drivers side is separated. @Roman, can you please send me the part numbers and price details for my rig? Thank you!!!
  24. Aug 23, 2019 at 6:41 AM
    Roman
    Roman
    Franklin, TN
    Sure, you're talking about the belt moldings, right? If so:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-belt-molding-681600c020
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-belt-molding-682100c020
  25. Aug 23, 2019 at 6:55 AM
    Cfour
    Cfour New Member
    2007 Grey TRD
    Yes! Ordered, payment sent. Thanks again Roman !!!!
    Roman likes this.
  26. Aug 23, 2019 at 10:07 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    artsr2002 and Xsnrg2006 like this.
  27. Aug 24, 2019 at 12:05 PM
    Roman
    Roman
    Franklin, TN
    Don't understand it myself either.
  28. Sep 2, 2019 at 8:47 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Guys I'm newb around here. Are these the trim molding that cleans the glass as it rolls up and down? My 2006 DC SR5, the drivers side glass is getting scratched up I think by sand or dirt trapped on the trim. I tried cleaning it but its hard and probably needs to be replaced.
  29. Sep 9, 2019 at 12:47 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yep. That’s them
  30. Sep 9, 2019 at 12:49 PM
    Roman
    Roman
    Franklin, TN
    Casper421 likes this.
