Front differential leak
Discussion in 'Suspension' started by Sdaniels, Dec 14, 2015.
  1. Dec 14, 2015 at 5:51 PM
    Sdaniels
    Sdaniels [OP] New Member
    Seth
    2014 tundra
    7 inch Pro Comp Stage 2 lift
    Okay guys, I just bought a 2014 Tundra with 25,000 miles. It already has a 7 inch Pro Comp Stage 2 lift, installed by a reputable shop.
    I noticed a couple days ago that the front diff has a slight leak. Doesn't really even drip on driveway but I don't like it. Thinking maybe shop either over torqued or under torqued case bolts. Hopefully case isn't cracked. I know Toyota ain't gonna fix it under warranty, so Im hoping the shop that did the install will. If not does anyone know how hard it would be to split cases and get new seal and fix myself? I know rear diff would be no problem, just never messed with front.
  2. Dec 14, 2015 at 5:54 PM
    Sdaniels
    Seth
    2014 tundra
    I forgot to mention there are 5 bolts that attach Pro Comp cross member diff bracket to differential. You have to take OE bolts out, attach bracket and replace bolts.
  3. Dec 14, 2015 at 6:08 PM
    Are u 100% sure it's the front diff?
  4. Dec 14, 2015 at 6:37 PM
    Sdaniels
    Seth
    2014 tundra
    Oh yeah. At first I thought it was motor oil, but definitely has that nasty gear oil smell. Seeping out of differential.
  5. Dec 15, 2015 at 5:58 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    mmmmmm the smell of gear oil and friction modifier
  6. Dec 15, 2015 at 6:01 AM
    Sdaniels
    Seth
    2014 tundra
    Hate that smell!
  7. Dec 15, 2015 at 6:17 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I pulled out my front diff clamshell on my Tacoma with 6" drop bracket lift. It was a pain in the ass to find the right position to drop it out. The drop bracket gets in the way. @Sean266 was there helping that day. Not sure on a tundra though but assume it's similar just a bit bigger diff.
  8. Dec 15, 2015 at 12:21 PM
    Sdaniels
    Seth
    2014 tundra
    Figured out what it is. Shop that installed lift reused two factory bolts that were too short. Should have used replacements supplied with lift. Were no threads at all grabbing. Got two new ones and will be putting them in shortly. Hopefully that does the trick.
  9. Dec 15, 2015 at 12:26 PM
    csuviper
    Broomfield, CO
    That is a goof. The kit should have come with longer ones if a new bracket is bolted in place.
  10. Dec 15, 2015 at 12:28 PM
    Sdaniels
    Seth
    2014 tundra
    Oh instructions said it did, they just didn't put them in. I pulled both top bolts out by hand
  11. Dec 15, 2015 at 12:59 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    And you said they were a reputable shop!?
    TruckLife900 likes this.
  12. Dec 15, 2015 at 1:02 PM
    Sdaniels
    Seth
    2014 tundra
    Suppose to be lol
