Front dif
Discussion in '2.5 Gen Tundras (2014-2021)' started by Yota18, May 19, 2018.
  1. May 19, 2018 at 3:49 AM
    Yota18
    Yota18 [OP] Inferno Club
    Upstate New York (the real NY)
    18’ 5.7 TRD Off-Road
    Stock
    maybe a dumb question but do our front diffs spin even when 4x isn’t engaged? Asking because I’m planning on regearing and was wondering about break in. If I’m only wheeling around in 2wheel are the front diffs getting broken in too or would that require some 4x action?
  2. May 19, 2018 at 7:42 AM
    Levidale08
    Levidale08 New Member
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    Homemade bed rack with extra spare with Rhino rack,two jerry cans mounted in the bed
    Yes they do. It doesn’t require any break in.
  3. May 19, 2018 at 9:22 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Both CVs will spin but the passenger side ADD tube will be unlocked and the transfer case not engaged. The drivers side moving will carry some inertia that the R&P will slightly spin. However I would encourage you to get at least 100 dirt miles in 4x4 in.
    And yes, any new R&P will require a break in process if you want the gears to last and not start humming.
  4. Jun 1, 2018 at 6:11 AM
    Yota18
    Stock
    I just saw this I was about to bump it, never got an alert or missed it for this thread. So the front diff still spin but slow and not under a load? Thanks for the info appreciate it!
    landphil likes this.
  5. Jul 4, 2018 at 1:53 PM
    jberry813
    Lake Tahoe
    Correct. Which really won't break in the gears. The pinion needs to be loaded for it to start wearing the gears in.
  6. Jul 4, 2018 at 3:33 PM
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    I miss the old manual hubs.
    Granted it could be a pain at times engaging and disengaging the hubs on a spur of the moment and you had to lock them in every month for a few miles to keep them lubed.
    But you could put it in low range without engaging the front hubs for serious pull.
    But keeping them engaged all the time just seems wrong.
    texasrho83 likes this.
  7. Jul 4, 2018 at 3:41 PM
    HighDesertSurfer
    HighDesertSurfer Surf The Dirt
    New Mexico
    2018 SuperWhite DC TRD OR
    Leer shell
    In other words " Hit the dirt!" :)
    :mudding:
  8. Jul 4, 2018 at 3:54 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    It's too bad that transfer cases don't have a "front wheel drive only" selection so you could work the front drive parts independently. For those that rarely go off-road and use their 4WD, this would be a convenient option.
  9. Jul 4, 2018 at 4:25 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I did this in a Chevy I had that threw the rear driveshaft. Hobbled home on the front driveshaft and made it just fine
