front cv axle play.... needle bearing issue?
Discussion in '2nd Gen Tundras (2007-2013)' started by VaStormTundra, Apr 12, 2019.
  1. Oct 11, 2019 at 7:52 AM
    el_taco
    el_taco New Member
    Damn, isnt the crush sleeve on the inside of the pinion?
    Would have take out the 3rd then?
  2. Nov 5, 2020 at 2:00 PM
    RachTundra
    RachTundra New Member
    2007 Tundra Crew
    None
    Hey VaStormTundra,
    Did replacing the ECGS Bushing in front drivers diff. Fix the woo woo woo sound and vibration.?
    chris1234 likes this.
  3. Nov 22, 2020 at 10:23 AM
    chris1234
    chris1234 New Member
    I am getting a Woo Woo Woo sound as well. It goes away when I put it in 4x4. Im trying to figure out what to replace first. Any ideas?
  4. Nov 22, 2020 at 11:53 AM
    RachTundra
    2007 Tundra Crew
    None
    Hey Chris1234,
    I have put new front wheel bearings in driver front cv shaft ... and that ecgs, Bushing in driver front ! Now tomorrow I’m putting in a junk yard front diff .. No one has really never said, but I’m gonna state that this is a 2007 Tundra Crew.. with 200k miles ....been making sound for 20k miles ! It’s also a 4:30 ratio.
  5. Nov 25, 2020 at 8:01 PM
    RachTundra
    2007 Tundra Crew
    None
    I should of stuck with my old front diff., with the ECGS bushing, cause it took care of 40% of problem.! Swapped out front diff. With a 2015 front diff. With 20k miles and should of replaced bushing in that one also.! Cause now I’m back to where I began. Probably will get a bushing for this one and call it good.
    Tridom and WVI like this.
  6. Feb 12, 2024 at 3:21 PM
    Tridom
    Tridom New Member
    Dominick
    Hampton Roads, VA
    2012 Tundra SR5 4.6L V8
    So... this stuff has me a little worried. Questions..
    Does a 2wd have the same bushing?
    How hard is it to replace?
    Never done a cv axle on a truck. Can it be done with a jack and jack stand? Do both sides need to be jacked?
    Do I need any special tools?
    I have the humming noise. Thinking about trying this. But wanna make sure I know what I'm faced with.
    I was an aircraft mechanic and they didn't have cv axles. LOL.
  7. Feb 12, 2024 at 4:52 PM
    Canman
    Canman New Member
    2007 Crewmax Limited
    I haven’t haven’t watched the vid, but I pulled the DS CV shaft last year while doing new upper and lower ball joints, new brake dust shields, new tierods, and a new steering rack. It was my first time working on a full-size pickup. I’m used to working on cars, and have pulled engines etc, but working on a 6,000 lb vehicle is a different animal. I have a 97 Lexus LX450 (think 80 series Land Cruiser), so I’m familiar with working on larger SUVs. So, what I want to say is that you need a 3 or 3.5 ton floor jack vs a 1.5 ton one. Yes, you could use the smaller 1.5 ton jack, but not really the right tool for job. Also, I decided not to use my flimsy 1.5 ton jack stands to support the Tundra while working on it. Instead I used a bunch of 8”x8” blocks to support the frame. I really need to get some heavy duty 3 ton stands.
    As far as special tools, IIRC you’ll need the correct size socket for the CV spindle nut, a tierod removal tool. I also use a MAPP gas torch to heat up stubborn bolts.
    Tridom likes this.
  8. Feb 12, 2024 at 5:23 PM
    Tridom
    Tridom New Member
    Dominick
    Hampton Roads, VA
    Fortunately I do have the proper jack and jack stands. Got tired of having to put a block on top the jack to get it to jack the truck high enough to even change a tire. And can't stand the jack that came with the truck.
    Good advice on the torch. I have one of those also. So guess I need to find out the socket size and get a tierod tool. Got a wealth of sockets up to 2" in standard and metric, so I may have the right one.
    Now if I could only buy some extra hours in a day.....
    Canman[QUOTED] likes this.
