Front Camera for a 2016 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by buchanan, Sep 21, 2016.
  1. Sep 21, 2016 at 6:56 AM
    buchanan
    buchanan [OP] New Member
    BOBBY
    2016 TUNDRA XSP-X 5.7L 2 WHEEL DRIVE
    NONE SO FAR
    Wanting to install a front camera on my 2016 tundra. It has a backup camera already on it.
    Any suggestions of what kind and how to go about hooking it up to the display in the truck
    with maybe a switch to cut it off and on?
  2. Sep 21, 2016 at 7:25 AM
    lehminh
    lehminh New Member
    2016 Tundra SR5 CrewMax 5.7L 2WD Front Bench Seats
    If u want to connect it to your Entune you will need to get a video interface. Look on YouTube for to get an idea of how it works. I got mine from NavTv.com. Total was $220 with interface and camera. Had it installed at local audio shop. I'm not too handy :(
    Anyways works great! I use it for parking only since it's a big truck... I'm not good driver :(
    Good luck
  3. Sep 21, 2016 at 7:46 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    how do you turn the camera on? can you turn it on while you're driving?
  4. Sep 21, 2016 at 7:48 AM
    lehminh
    lehminh New Member
    Yes, you connect it to a toggle switch to turn on/off anytime. Some on YouTube have it setup as two way switch so they can turn forward or reverse camera on anytime.
  5. Sep 21, 2016 at 8:02 AM
    RussellVaughan
    Houston
    anychance you could provide part numbers for the camera and interface you used?
  6. Sep 21, 2016 at 8:04 AM
    lehminh
    lehminh New Member
    I'll get for u later when I'm at work. They are easy to talk to.
  7. Sep 21, 2016 at 8:09 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    I would love to have the rear on at anytime. If your sittin in a parking lot its a good safety measure for lurking criminals
    geno0506, racin and NewImprovedRon like this.
  8. Sep 21, 2016 at 8:10 AM
    chadjamesr
    chadjamesr New Member
    Chad
    Atlanta
    2016 Tundra Platinum 4x4 Crew Cab
    Fox 2.5 w/ DSC Remotes F&R Coach Builder +3 Shackles RW Wheels w/285/75/17 Terra Grappler G2 Interior and exterior changed to LED Retrofit headlights with DS2 4.0 Morimoto LED fog lights Morimoto 40" LED bar in front bumper Retrax PRO Tonneau cover RCI front skid plate Crystalline tint on all windows and windshield P&P Rock sliders and full skip plates
    I've thought about doing the same thing using this camera:
    https://www.amazon.com/iNewcow-Embe...&qid=1474470432&sr=8-1&keywords=toyota+camera
    It supposedly fits in the Toyota emblem on the front grill. When I researched it, once the camera has power and sends a signal to the Etune head unit, it will automatically change the screen to show the camera image. This is as far as I have gotten in the research. It sounds like you mount the camera, splice the camera wires into the reverse camera wires on the Etune, then wire a switch to power the front camera.
    If you try it, please post your results as it might be the push I need to do it on my own truck.
    040Tundra and NewImprovedRon like this.
  9. Sep 21, 2016 at 11:23 AM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    I LOVE the front camera idea...almost bought a F150 just for this feature....
    @lehminh Please share your part # and install instructions.
  10. Sep 21, 2016 at 11:29 AM
    TheBeast The Beach
    mine is aftermarket, hooked to rear view mirror. When I go into reverse ,the rear camera shows .When I start driving ,the front shows and I can turn it off with mirror on/off button. The only thing I don't like is the front camera is just glued to grille right now. I like the emblem idea.
  11. Sep 21, 2016 at 1:52 PM
    lehminh
    lehminh New Member
    Ntv-kit436
    Ntv-kit563
    See image. Busy morning, sorry for delay. If you want to install yourself their tech team will talk you through the install.
    Good luck
    polox40 likes this.
  12. Dec 6, 2016 at 9:01 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Wow! A 10 dollar diode??? I think I'm in the wrong business if there are people that will pay that kind of money for a 50-cent part!
    831Tun, Viper3G and NewImprovedRon like this.
  13. Dec 7, 2016 at 11:34 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I like the emblem grille camera but I have the Pro grille so I'd have nowhere to put this one.
  14. Dec 7, 2016 at 1:49 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    Maybe it's one of those MIL-SPEC parts :infantry:and/or nuclear hardened :muscleflexing:
  15. Jan 2, 2017 at 10:58 PM
    xando
    xando New Member
    Oregon
    Tundra TRD OFF ROAD 2015 crewmax/ silver metallic
    i have this one:
  16. Jan 2, 2017 at 11:04 PM
    xando
    xando New Member
    Oregon
    i used this button:
  17. Jan 3, 2017 at 2:44 AM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    Have you ever bought popcorn at the theater or a birthday card? You should see the markups on those things
  18. Nov 5, 2017 at 6:51 PM
    tundrarafter
    tundrarafter New Member
    ttk
    2016 TRD
    Anyone ever used one of these systems to connect a remote camera to the rear of a camp trailer. Wireless systems can have problems sending signal, so looks to me like a hardwired system might be best.
  19. Nov 6, 2017 at 8:43 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    And so began and the FRAC harness was born. Thanks Lou. Mine's is almost installed.
    TundraTex[QUOTED] likes this.
  20. Nov 6, 2017 at 9:19 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    TundraTex likes this.
  21. Nov 6, 2017 at 5:28 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Funny you should bring this up. I just acquired a camper trailer and am researching how I might integrate the rear camper cam with the FRAC harness.
