Front bumper removal write up
Discussion in '2.5 Gen Tundras (2014-2021)' started by 16TRD, Nov 11, 2017.
  1. Nov 11, 2017 at 11:52 PM
    16TRD
    16TRD [OP] New Member
    Norcal
    2016 White crewmax
    I know there are some how tos out there. More pics cant hurt for those hesistant about tackling it.
    Remove the 4 10mm bolt and clip on top of grill. Pull the top up off where it was screwed in.
    Reach under the grill and slide hand across. You can feel 3 spots where there are tabs. Pull away from truck and remove grill.
    Remove the two tabs and two 10mm screws in the wheelwell for the garnesh below the headlighight. Pull away from the truck.
    The splash guard has two 10mm screws and pop up tab in the frame. Be careful and use a small flat head to pop off the tab as its easy to break. I broke mine.
    Underneath there are also two 10mm and 12mm screws.
    Once off you have access to the fog light. Unplug it. After it's unplugged you can remove it by using a small flat head screw driver and pop down from the top and it will come out.
    On the bottom of the center valence are three 10mm bolts. On top where you remove the headlight garnish are two silver 12mm bolts on both sides. Once done the bumper comes off as once whole piece.
    Remove the 10mm bolts holding the end caps to the metal brace that holds it all together.
    Don't forget the orientation of this piece used to screw the splash guard to under the endcap.
    Now drive around getting weird looks without front bumper while you wait on your caps to get painted/powder coated.
    J&ATundra, equin, edwin729 and 2 others like this.
  2. Nov 12, 2017 at 12:27 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    nice! thanks for sharing!
    Kwikfish and 16TRD[OP] like this.
  3. Nov 12, 2017 at 12:29 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    look @Sean266....now you can take your front bumper off....easy step by step instructions
    T-Rex266, BlueBottle and 040Tundra like this.
  4. Nov 12, 2017 at 7:58 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Thanks!
  5. Nov 12, 2017 at 2:20 PM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    I legit did this today and was searching for a guide... I got started right before you published it so I never saw it. I just sort of figured it out. But I ended up removing the splash guard and it was a pain to get back on.
    props for doing this to help out others!
    16TRD[OP] likes this.
  6. Nov 12, 2017 at 2:29 PM
    Johnathand
    Johnathand New Member
    Johnathan
    16 Platinum
    Did this myself. No write up or guide. Ended up with like 7 extra bolts
    bhuff92 and Unlimited like this.
  7. Mar 7, 2018 at 7:20 AM
    AlexWV
    AlexWV Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    I got my oil changed and they didn't put back in the bolts that connect the valance to the skid plate. Now I think I know what I need to replace them. Thanks.
  8. Mar 7, 2018 at 10:08 AM
    16TRD
    Norcal
    2016 White crewmax
    It always happens. At least it's not your suspension with extra bolts
  9. Mar 7, 2018 at 11:00 AM
    Johnathand
    Johnathan
    16 Platinum
    Hahaha... very true.
  10. Jan 16, 2019 at 9:22 AM
    pannelld
    pannelld New Member
    Dustin
    Toyota Tundra 2014
    20 inch fuels on 33" Toyo Trail Grapplers
    subd for this weekend. ill be doing this in a couple days
  11. Sep 20, 2020 at 9:29 PM
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    This is exactly what I needed
  12. Feb 4, 2022 at 7:14 PM
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    Just replaced my fogs and realized how far off the passenger chrome bumper corner is. The top is pushed forward at least an inch which is throwing off the fog light pattern. Bought the truck like this and at first i thought it was just a cosmetic anomaly from some minor damage to the chrome corner.
    Anyone have more images of how these chrome parts attach to the bumper? I pulled the grill and trim piece below the headlight today but had limited time and put it back together before i could find the culprit.
    Picture shows how far off the passenger is compared to the driver side.
    I'm also assuming the parking sensors need to be unplugged when dropping the bumper...anything else im missing?
