Front bumper and a deer
Discussion in '2.5 Gen Tundras (2014-2021)' started by SMK Shoe, Mar 17, 2018.
  1. Mar 17, 2018 at 5:45 AM
    SMK Shoe
    SMK Shoe [OP] Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Well, hit a deer this morning and tore up the passenger front end up pretty good. Doesn't look like any mechanicl damage but the bumper end is 1/2" from the tire. Are there any sensors in the bumper that would prevent me from pulling it back off the tire to drive it. Will be a few days before I can get it into a body shop and then awhile before parts are ordered and fixing begins. Can't sit here with a hurt truck. Old school I would take a sledgehammer and beat on it, but, with all the airbags, I dang sure don't want to set them off. I should be able to disconnect the negative battery cable and pry it forward. It doesn't rub going forward but in reverse I hear a lot of rubbing and not going to tear up a tire.
    Any recommendations would be helpful
    Y0TA PR0 likes this.
  2. Mar 17, 2018 at 7:53 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Sorry 'bout the damage. There aren't any sensors to worry about in the end cap.
  3. Mar 17, 2018 at 7:57 AM
    kcaustin66
    kcaustin66 New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    My has a parking sensor in in the metal end caps
  4. Mar 17, 2018 at 8:21 AM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
    Well, warm enough now outside to disconnect the neg cable and try to pry out on the bumper end. Since one has to be replaced and the front quarter more than likely, I may pay the extra and have them color match the end caps. Front end being tore apart should help cover $$$$. This SUX
  5. Mar 17, 2018 at 8:54 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    Hook up a tow chain to that end and pull it with your truck or another truck. DOT highway helper up here pulled mine out so I could get my truck home. Good luck. D
  6. Mar 17, 2018 at 9:13 AM
    My 07 had a similar "mishap" on the drivers side. Pulled up to a tree and strapped a Come Along to it and pulled the bumper out.
  7. Mar 17, 2018 at 11:47 AM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
    Well, got the bumper end pulled back about two inches from the tire. but there is also a dent in the quarter panel, fog light destroyed, all the plastic fender well parts messed up and some of the thinner cross member bent, and lower plastic cover that goes between the bumper ends destroyed.
    But, neighbor had a idea, fender flares would cover the dent in the quarter panel after a little work with a body hammer, cross members could be straightened out, plastic pieces replaced and a aftermarket bumper purchased and replace the damaged parts. I am pretty mechanically inclined, so I could save $$$ by doing the mods myself, and the insurance deductible is only 250$. So I may price out aftermarket parts and see what the insurance adjuster comes up with. will post pics in a few minutes
  8. Mar 17, 2018 at 11:55 AM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
  9. Mar 17, 2018 at 11:59 AM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
  10. Mar 17, 2018 at 11:59 AM
    77mmbass
    77mmbass MusicMan
    2014 Crewmax SR5 -Gear Hauler
    First cut off back straps and cut them into 2" thick pieces. Then wrap in bacon and toss on grill. Mashed taters and Asparagas will pair nicely along with your favorite cold beverage.
    The rest, grind up for breakfast sausage.
  11. Mar 17, 2018 at 12:00 PM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
  12. Mar 17, 2018 at 12:02 PM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
    If I could have found it. Was a pretty solid hit, so would expect a lot of the meat would be tainted with internal organs stuff.
  13. Mar 17, 2018 at 12:03 PM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
  14. Mar 17, 2018 at 12:04 PM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
  15. Mar 17, 2018 at 12:49 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    All depends on how much time and diy effort you want to put into it.
    So long as the metal of the end cap it is not broke, you can get a dead-blow hammer and fix the edges/tabs so the alignment is back true.
    as far as the front black bumper piece; you can fix that plastic with a soldering iron and some metal screening/mesh.
    In your last pic, I can see where the plastic mounts (that hold the square-bottom bolts for securing to the end caps) broke off. I broke those accidently on mine when trying to disassemble my bumper. The only way to get to these is to disassemble the whole bumper. I was able to repair them and reattach them with the soldering iron and metal mesh. Here's a couple vids on the parts I referenced and how to fix the plastic.
    https://www.youtube.com/watch?v=Q1ZIdvsBMvo
    Go to 1:10 to see the end cap mounting points, and 3:20 to see the black plastic mounting points. What you see at 3:20 is exactly what I did to mine.
    https://www.youtube.com/watch?v=Z29LRvbF7Kc
    Of course, all said, you can just buy a new end cap and front plastic piece and call it a day.
    tinman10101 likes this.
  16. Mar 17, 2018 at 1:05 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    Time for a big, beefy steel plate bumper!!
  17. Sep 6, 2018 at 11:18 AM
    Red Dragon
    Red Dragon New Member
    Pocatello, Idaho
    2015 Barcelona Red Limited TRD
    My wife & I hit a deer a few years ago with our Toyota Sienna going about 60 mph. We feel your pain!
    6D28998B-AEF7-43E9-AEF4-A994225FDD51.jpg 3894645B-F804-418B-925C-8C9B1706719A.jpg
    jewsNbrews likes this.
  18. Sep 6, 2018 at 11:22 AM
    Sorry to hear about the damage!
  19. Sep 6, 2018 at 6:22 PM
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    Did you at least get some deer jerky!!
  20. Sep 6, 2018 at 6:44 PM
    Berettafan
    Berettafan New Member
    2017 CM
    This was my deer hit. Big mf’r.
  21. Sep 6, 2018 at 8:32 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    No off-road bumper. $500 just got mine delivered
  22. Sep 6, 2018 at 9:58 PM
    Thattundradude
    Thattundradude New Member
    Platinum Tundra
    Lifted
    looks like you need a new door skin, or you might be able to just get the dent out
  23. Sep 6, 2018 at 10:20 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    That sucks. Been close but fortunately never hit one.
  24. Sep 6, 2018 at 11:01 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    Ko* off-road bumper
  25. Sep 7, 2018 at 12:57 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
  26. Sep 7, 2018 at 3:43 AM
    Wvmoonshiner
    Wvmoonshiner 2020 T4R Venture SE
    Chuck
    West Virginia
    2020 T4R Venture Midnight black
    Met a deer with my 16 Tundra a couple years ago
    D8533BC1-36A1-41EE-B19B-71F3739983AD.jpg B0CC6742-B500-4380-B166-C8892EA40405.jpg
  27. Sep 7, 2018 at 9:23 AM
    brayan975
    brayan975 El PINGU
    Brayan
    Miami
    2016 Black Tundra
    2 Inch Wheel spacers Red plastic dip emblem Red tailgate letters Rock Lights RGB pod lights Bull bar with LED bar
    RIP DEER :deadhorse:
  28. Dec 13, 2018 at 5:06 PM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
    Well, how many deer do you have to hit before they get out of your way. Just had another run into the pass side of my truck. Two in less than a year. What the hell. Never even claimed the first one. Just replaced with a aftermarket bumper and all good. Now a lot of body work that I can't do. been driving for 34+ years and never hit one till this year and now two. Pic's tomorrow.
  29. Dec 13, 2018 at 5:07 PM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
    If anyone needs some front bumper parts let me know. Stacked in the shed of shame.
