Front brakes
Discussion in '1st Gen Tundras (2000-2006)' started by robabeatle, May 28, 2021.
  1. May 28, 2021 at 6:04 AM
    robabeatle
    robabeatle [OP] New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Dealing with pulsating brakes after:
    1. 10K miles ago I put on new rotors and pads. Generic Amazon replacement:
    https://www.amazon.com/gp/product/B009YM21GG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8
    note that these are the 13wl as I think the original owner replaced the 13we at some point
    At this time, I also adjusted for more rear brake bias, and took some slack out of the parking brake line. Braking was vastly improved.
    2. About a month ago, I notice a slight pulsating again when the brakes are nice and warm. I was scheduled for a timing belt change, so I had the shop bleed the brakes and check the rear drums, and they replaced the rear drums.
    Shop still experienced pulsating after the above and so machined the rotors. Ah, they did say the rotors were warped as well. (Again, only 10k miles, no towing, not a lot of weight or overly rough useage)
    Pulsating is diminished but still there. The shop said the next thing to do is replace the rotors and pads. <frustrated> So, I am wondering is the other likely culprit the calipers?
    Also, what are suggested, time tested rotors and pads. I'd rather spend a bit more and have great, long lasting braking.
    Thanks guys.
  2. May 28, 2021 at 6:13 AM
    Professional Hand Model
    Hand Protectors
    Not sure which Rotors a 4wd Place put on mine, but they are holding well after 20k miles. I even have the 13WE on them and switched last year to 13WL.
    After some reading, it seems some Cryo Treated Rotors are the best.
    Darkness and robabeatle[OP] like this.
  3. May 28, 2021 at 6:22 AM
    04DCTundraMan
    04DCTundraMan Crimedog McGriff
    Ryan
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    robabeatle[OP] likes this.
  4. May 28, 2021 at 6:23 AM
    tdrich7
    tdrich7 New Member
    2006 Tundra DC 4wd SR5
    I also have read great things about the cryo rotors. I hate any kind of pulsing when braking and having dealt with warped rotors in the past and reading that they are an issue with these trucks I went ahead and ordered a pair for my truck already along with new OEM pads and the powerstop calipers. May wait to run through my current setup a little bit more before installing (right now I only have a slight pulsing getting off exits on the highway), but I figured it was worth the extra cost to prevent this from ever being an issue. I am usually skeptical of claims like the ones made with the cryo rotors, but I did a bunch of searching and no one seemed to be calling BS on them - pretty much all positive reviews.
    I went with these because it was the cheapest cryo set I could find, but frozenrotors.com has a different, more expensive option also.
    https://rcagarage.com/shop/brakes-r...-front-left-rotor-special-order-126-44118csl/
  5. May 28, 2021 at 6:31 AM
    robabeatle
    AZ
    13wl and 13 we are just referring to the calipers and pad size correct? Nothing to do with the rotors.
    Darkness likes this.
  6. May 28, 2021 at 6:36 AM
    Hand Protectors
    You’ll probably be alright with reusing your newer pads. If it was me, I’d go New Full High Dolla pads and have a fresh start.
  7. May 28, 2021 at 6:40 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  8. May 28, 2021 at 6:51 AM
    tdrich7
    tdrich7 New Member
    That's with "free" shipping, but yeah these cryo rotors aren't cheap. The ones on the other site are more like $140-160 a piece. But no sense in running through rotors like I've heard a lot about reading through these forums. This is a test as much as anything, we'll see how they perform. I would probably go with a $50-60 rotor from Rock Auto if I didn't try these, and I could easily see the $100 difference all in worth it if these live up to their reputation. We'll see how they hold up though.
  9. May 28, 2021 at 9:15 AM
    robabeatle
    AZ
    At first, I thought of just using the current pads but then rethought along your line of thinking. If I am in there, might as well just cover all my bases.
    Tundratoofun likes this.
  10. May 28, 2021 at 9:27 AM
    robabeatle
    AZ
    Thank you to everyone for the help. I went with the stoptech cryo treated rotors and new "street" pads. Pretty costly but if it gets the job done, I will be happy.
  11. May 28, 2021 at 9:56 AM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    I haven't had to cross this bridge on my tundra yet, but I've had my best luck with cross drilled powerstop rotors. I've used them a couple of times with vehicles that ate rotors like candy mints and had good success.
  12. May 28, 2021 at 10:09 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    R1 Concepts cryo rotors are a great option too. Also check Maxbrake, had them on my 4runner and they were really nice.
  13. May 28, 2021 at 10:15 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    My brakes are pulsating as well. I have good pad left but this is original with 50k on them. Seems stock held up good. Should I just get another set of these
  14. May 28, 2021 at 10:44 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Cryo costs a lot but I have been running a pair of cryo rotors since 2012 or so. Never had then turned, never had brake pedal pulsing. Even when I switched pads I didn't have them turned. They are slotted, I didn't want slotted but that was the only cryo option, a place I had called asking about turning said they won't do slotted rotors.
    If it is your rotors you typically also get a wobble in the steering when the pulsating happens. If that isn't happening it might not be rotors.
    robabeatle[OP] and tdrich7 like this.
  15. May 28, 2021 at 11:26 AM
    robabeatle
    AZ
    There is steering wheel wobble.
    Darkness[QUOTED] likes this.
  16. May 28, 2021 at 11:47 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  17. May 28, 2021 at 11:49 AM
    Rodtheviking
    Vancouver, WA
    Sequoia
    robabeatle[OP] and Darkness like this.
  18. May 28, 2021 at 11:51 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  19. May 28, 2021 at 12:00 PM
    tdrich7
    tdrich7 New Member
    With shipping that's only $60 less than the cryo rotors, although the free shipping trick definitely makes those a deal. I guess it depends on whether or not you think the cryo process actually does anything. If OEM rotors last 1/2 as long as cryo then even with free shipping you've paid more and had to put new rotors on. If there's no difference then OEM is the way to go. Anecdotal evidence like what Darkness said makes me think the cryo actually works but I'm interested to see for myself, although I guess I don't have much to compare to at this point.
  20. May 28, 2021 at 12:04 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @tdrich7 right before I paid the big bucks for cryo I had got a pair of the top of the line auto zone rotors. They lasted 6 months and started wobbling. As many miles as I have put on my cryo rotors I think I'm ahead, even with OEM I would probably have gone through 2 sets by now.
    tdrich7 and robabeatle[OP] like this.
  21. May 28, 2021 at 12:05 PM
    robabeatle
    AZ
    I'll be guinea pig.
  22. May 28, 2021 at 12:05 PM
    Hand Protectors
    I drove on Original OEM Warped Rotors from 2004 until 2018. It was normal to high speed wobble and/or tug tug tug at slow stops. I think the 4wd Place put on some basics rotors from china iirc. When/if these warp I’ll go Cryo with Toyota Pads (TRD) as they come with the Silencer Shims.
    des2mtn and robabeatle[OP] like this.
  23. May 31, 2021 at 10:36 AM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I bought a “kit” on Amazon for front brakes. Rotors and pads. They lasted about a month.
    Wobble, wobble. It was past the time to return so I lived with it. I ordered Bosch rotors and
    Brand name pads ( forgot the brand) no more wobble, junk rotors went to trash
  24. Jun 1, 2021 at 7:44 AM
    I've had a set of $40 Raybestos or Centric rotors (whatever Rockauto had in the daily driver section on the front for 50k miles now. No wobble. Been through 3 driver's side calipers though for sticky pistons.
  25. Jun 4, 2021 at 2:07 PM
    robabeatle
    AZ
    Cryo rotors and new pads arrived. Looking to get this swap done tomorrow.
  26. Jun 4, 2021 at 2:26 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    If you need any help let me know; I’ve got a entire tube of the sil glyde if you haven’t already got some
  27. Jun 4, 2021 at 3:15 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I tried them, I think I got part of a bad batch. They stopped well but they screamed all the time. I have been running their red pads on my daily and no complaints there. Hope the yellows go well for you.
  28. Jun 4, 2021 at 4:21 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    bmf4069, des2mtn and robabeatle[OP] like this.
  29. Jun 4, 2021 at 4:34 PM
    robabeatle
    AZ
    ^lol
    Decided to get er done today. Easy the second time through. While pressing the pistons back a little brake fluid came out of the reservoir.
    Problem?
    8171A668-E7A6-41CD-A0D7-2A601E330C11.jpg Out of the driveway and back in: they work but the brake action is spongy. Will give a shake down in a few hours.
    bmf4069 likes this.
  30. Jun 4, 2021 at 4:38 PM
    Hand Protectors
    Ugh. You are suppose to open the Bleeder prior to when pressing the piston back. Otherwise, you’ll potentially mess up the ABS Mojo with back pressure.
