Front body mount chop BMC
Discussion in 'General Tundra Discussion' started by Wikid, Aug 16, 2015.
  1. Aug 16, 2015 at 3:06 PM
    Wikid
    Wikid [OP] New Member
    Don
    Toyota Tundra Crewmax Platinum
    On order
    This is on my 15 Tundra
    I'm not sure if this will carry over to the 07-13 , but here it goes
    I currently am running Rock Warrior with 35's and they clear everything with stock suspension. I had to bend in the skid plate a bit and when I had the factory front bumper.I needed to pull the inner front plastic.
    The body mount cleared but it was close. No rubbing, but I knew I would be running 1.25 wheel spacers and for sure it was going to rub
    Here are some pics as it was.
    First pic is the only reason I was able to do this project when its north of 110 Degrees :)
    As you can see, its close . This is the passenger side
    Wheel off body mount before surgery
    After surgery . I trimmed back the pinch seam and corner cut the plastic. My Fender Flares are out for paint along with the door handles, and the wheel spacers are on order.
    After I am sure everything clears, I will weld a plate , form it to the body mount grind it and paint it . It looks like it will clear, but its better to leave it open until The trial fit next week
    Wheel on after surgery Lots more room :)
    I'll take a shot of it after I finish it.
    Probably about 1 hour to do the entire project
    J&ATundra, BashFab, Bob and 1 other person like this.
  2. Aug 16, 2015 at 3:17 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    You sir are a much bigger man than me. I couldn't even imagine doing that to my 15. Good job!
    Wikid[OP] likes this.
  3. Aug 16, 2015 at 5:19 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Are you going to weld plates back on or spray paint the bare metal? I've got mine chopped and spray painted temporarily, but I bought some pre bent and cut plates I'll be welding back on. Bought them from relentless fabrication on this forum.
    Seth likes this.
  4. Aug 16, 2015 at 6:09 PM
    Looks good!
  5. Aug 16, 2015 at 6:33 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I'll add this to the DIY/Mod thread. Add the welding of plates when you get that complete.
  6. Aug 16, 2015 at 6:35 PM
    Wikid
    Don
    On order
    Yessir, I definitely will
    Thanks
  7. Aug 16, 2015 at 6:38 PM
    Wikid
    Don
    On order
    I didn't realize you could buy prebent plates. Probably different cut than I did anyway. I actually did a BMC of an FJ Cruiser right before I did the Tundra. I had lots of practice doing those, so I really won't struggle making plates for it either. Nice to know someone is making them though
    TruckyTruck[QUOTED] likes this.
  8. Aug 16, 2015 at 7:21 PM
    TruckyTruck
    Gary
    25 bucks, not sure if the added strength is needed, but I'm going to weld them in for a completed look anyway. Yeah it's pretty cool you can get them.
  9. Aug 16, 2015 at 8:16 PM
    csuviper
    Broomfield, CO
  10. Aug 16, 2015 at 8:17 PM
    csuviper
    Broomfield, CO
  11. Sep 4, 2019 at 8:01 PM
    Walton
    Walton New Member
    Appleton, Wi
    2010 5.7L FFV LTD CrewMax
    Could anyone give me the rough dimensions of the plates? I'm going to order some stock and cut them out myself.
  12. Sep 4, 2019 at 9:55 PM
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    No one would ever know unless they knew what they're looking at if its done correctly! I like to add dimples to my filler plates when I do BMC's for folks
  13. Sep 13, 2020 at 8:44 AM
    rochmpr
    rochmpr New Member
    Krister
    Walnut Grove, CA
    2020 CrewMax
    Lifted, sliders, 35 X 12.5's, Evo Corse and more stuff coming
    One thing I would add to make cutting and welding easier and cleaner is to remove the nuts off all of the body mounts and jack up the cab and remove the bushing at this location. It also saves from melting the bushing when welding. You will also. Eed to loosen the ABS wires at the front suspension or you will risk stretching them.
