Front axle play
Discussion in 'General Tundra Discussion' started by juan40tundra, Apr 22, 2025.
  1. Apr 22, 2025 at 10:17 AM
    juan40tundra
    juan40tundra [OP] New Member
    Juan
    2018 Toyota Tundra TSS 4wd
    none
    to all
    I noticed some play by where the axle connects to the differential (Left side). I wanted to see anyone had the same issue in the past.
    Took my truck to the dealership due to my alignment always been off, and they ended up replacing the right axle. However, the left axle has lots of play.
    Should I consider to bring the truck back?
  2. Apr 22, 2025 at 10:22 AM
    blenton
    blenton New Member
    Corndog123 and ColoradoTJ like this.
  3. Apr 22, 2025 at 11:27 AM
    juan40tundra
    Juan
    none
    is it the same on a 2018 model?
  4. Apr 22, 2025 at 12:56 PM
    blenton
    blenton New Member
    Yes. 07-21 are the same.
    Corndog123 likes this.
  5. Apr 23, 2025 at 5:54 AM
    juan40tundra
    Juan
    none
    Perfect
    another question
    How much play should be on those axles where it connects to the differential,
    I see that my left axle can go up and down easily about .200" to .300" of travel
  6. Apr 23, 2025 at 6:30 AM
    Just a bit over 1/4" is a lot of play.
    2mchfun and Corndog123 like this.
  7. May 9, 2025 at 5:34 AM
    2mchfun
    How does the axle impact the alignment? Wheel or hub bearing, yeah, but axle as in CV axle was replaced to correct alignment?
  8. May 9, 2025 at 6:04 AM
    blenton
    blenton New Member
    I read the OP’s post as ‘while the truck was there for an alignment, they replaced the right side axle as a separate matter’. But maybe I misunderstood, in which case I would also question it.
    2mchfun[QUOTED] likes this.
  9. May 9, 2025 at 6:17 AM
    juan40tundra
    Juan
    none
    Axle play vibration is detrimental to the bolts causing them to rotate with time. This is due to a prolong drive which increase the exposure of the lower control arm hardware to vibration
  10. May 9, 2025 at 6:37 AM
    2mchfun
    I mostly remain a skeptic as I would think that if there is that much vibration one would fix it long before it cranked the cam tab bolts loose.
  11. May 9, 2025 at 6:53 AM
    juan40tundra
    Juan
    none
    Bolts dont get loose enough to come out of the housing, but it gets loose enough to make the camber and toe to move which end up messing up the alignment
  12. May 9, 2025 at 8:39 AM
    2mchfun
    So now I'm supposed to believe that tie rod length is also being affected by worn CV joints causing extreme vibration? Damn, guess the truck travels much like a pogo stick then.:bikewhoops:
  13. May 9, 2025 at 10:36 AM
    blenton
    blenton New Member
    Don’t overlook the damage bad muffler bearings can do to a motor, either. I had a buddy that had to completely redo the specs for his inline on the rotary girder due to some bad muffler bearings. Thing was nuts.
  14. May 9, 2025 at 12:35 PM
    juan40tundra
    Juan
    none
    I started by replacing the wheel bearing and wheel hubs. That did not remove the vibration, consequently to that, I replaced inner and outer tie rods, and stabilizer links. Follow to that, replaced both lower controls arms, which made the front end to be a bit more firm, but the vibration continued. Took the truck to the dealership and they replaced the right axle under warranty, however, the vibration and alignment still an issue. Ended up finding out the vibration is coming from the left axle due a needle bearing to be worn out. ECGS offer a good deal to replace the bearing with CNC bushing that resolves the vibration instantly.
  15. May 9, 2025 at 1:06 PM
    2mchfun
    Glad you finally figured it out!
