Front and Rear Differential Oil Change
Discussion in '2.5 Gen Tundras (2014-2021)' started by Part_time, Oct 12, 2019.
  1. Feb 20, 2023 at 4:44 PM
    #61
    _steezysr5
    _steezysr5 New Member
    Instagram _steezyse Eibach pro lift stage 1 3.5/1.5 Rough country shims/block Methods nv305 double black 18x9 +25 Bfg ko2 35 12.5 Alpharex pro series headlights/taillights Lasfit ls plus series led Armordillo Hood Grille Insert with Led Lights Bakflip mx4 tri fold tonneau cover 5 inch iboard running board Pedal commander RCI Transmission and catalytic converter shield Nameplate overlays 5% tint all around Titan wheel spacer 1 inch Weather mats by 3dmatsusa Rydonair 7 inch Gplus third brake light Paint-matched hood bulge, grille surround, front and rear bumper overlays from Ecoological (midnight black metallic) Mbrp dual rear exit exhaust (mimics trd exhaust sound) yet to install, currently just a muffler delete
    I couldn't get over it so I looked at the manual again and then realized. I was reading the front differential for the 4.6 which I don't have. I feel stupid now lol. That answers everything it's 4qt for the rear dif, I'm done.
  2. Feb 20, 2023 at 5:12 PM
    #62
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Lol good to know, for future reference, pretty much every differential, or transfer case on anything, is fill til it comes out and put the plug back in, no way would someone be expected to forced more fluid in while its trying to seep out and then shove the filler cap back on, my guess is that would increase the chances of clogging a breather tube.
  3. Feb 20, 2023 at 6:49 PM
    #63
    _steezysr5
    That also crossed my mind but I was caught up with "5 quarts" I thought I was doing it a good regardless of when the fluid was already coming out. The whole time I'm talking to the dif like "you need 1 more quart" lol smh
    FrenchToasty likes this.
  4. Feb 28, 2024 at 7:14 PM
    #64
    Riospeed
    Riospeed New Member
    Josh
    2011 Tundra Limited 4x4
  5. Feb 28, 2024 at 7:17 PM
    #65
    blenton
    blenton New Member
    Riospeed[QUOTED] likes this.
  6. Feb 28, 2024 at 7:20 PM
    #66
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    I did…..no it’s not the correct weight. My gas mileage went down about 1mpg.
  7. Feb 28, 2024 at 8:09 PM
    #67
    blenton
    blenton New Member
    For a 2011? What are you purporting to be tteh correct weight? We're not talking t-case fancy pants straight 83.245Weight for '14+...
  8. Feb 29, 2024 at 3:27 AM
    #68
    yakeng
  9. Mar 5, 2024 at 8:18 PM
    #69
    offsetplayer2
    offsetplayer2 New Member
    Woods and Fields, NC
    2018 Inferno CM 4WD
    Manual states a standard for normal use as a basic truck with nothing in it or towing in the environment it was tested during R/D……….for mpg and EPA of course. We “should” all know a truck is to be used as a truck. More you tow, might want to consider different fluid as long as it meets the specs. Colder or warmer states? Check it out. Even the manual calls for different engine oil if you dig through it for certain temps. 75/90 won’t bother it one bit for pavement queens or towing here and there with a camper. Some folks here switch to 75/140 who tow daily. Why? Because they understand gears and fluid. If it meets the specs, it meets the specs. The numbers are for those who use it in different environments and situations. It’s your job to do the research for your environment and situation.
    I switched my rear today at 81k. Yes I used new plug gaskets. They’re cheap enough. If I spend $50, just guessing, on oil, then I can spend a few more dollars on new crush washers. It’s cheap and easy. Drain, clean, new plug gaskets, refill to torque spec. Which is about 36 lb/ft on rear.
    Do your research and stop saying “manual states 4.9 quart. Only 4 came out so I force another quart” lol BS. People up here are telling you the answers you seek. Listen to them. And I don’t mean me. Good luck.
  10. Mar 10, 2024 at 10:14 AM
    #70
    tundras00
    tundras00 New Member
    What is this called? Outta come in handy when they pull off the cyber pandemic old Schwab was talking about.
  11. Mar 10, 2024 at 10:39 AM
    #71
    AZBoatHauler
    So.Arizona
    Smudge pot.
    https://smudgepotdirect.com/
