Front and Rear Differential Oil Change
Discussion in '2.5 Gen Tundras (2014-2021)' started by Part_time, Oct 12, 2019.
  1. Nov 18, 2019 at 6:53 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
  2. Aug 30, 2022 at 10:43 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    2 Tacomas and now Tundra. I have never changed washers and never have had a leak. I changed the transfer case fluid on my Tacoma at 50k and it looked like it came out of the bottle. I have not changed it on Tundra at 5 years and 75k. I may change it next year. As far as loctite goes I don't see a problem with blue but unnecessary.
  3. Feb 18, 2023 at 2:13 PM
    _steezysr5
    _steezysr5 New Member
    Instagram _steezyse Eibach pro lift stage 1 3.5/1.5 Rough country shims/block Methods nv305 double black 18x9 +25 Bfg ko2 35 12.5 Alpharex pro series headlights/taillights Lasfit ls plus series led Armordillo Hood Grille Insert with Led Lights Bakflip mx4 tri fold tonneau cover 5 inch iboard running board Pedal commander RCI Transmission and catalytic converter shield Nameplate overlays 5% tint all around Titan wheel spacer 1 inch Weather mats by 3dmatsusa Rydonair 7 inch Gplus third brake light Paint-matched hood bulge, grille surround, front and rear bumper overlays from Ecoological (midnight black metallic) Mbrp dual rear exit exhaust (mimics trd exhaust sound) yet to install, currently just a muffler delete
    I’m doing this and just at 4quarts already dripping out. I have 2019 4.6 rwd. I’m aware manual says 4.9quarts so I proceed to put another quart in and there’s so much oil is coming out I put the fill plug back in and about quarter to thirds of a quart spilled before I put the plug back and now I need some answers because this confuses me. Thoughts?
  4. Feb 18, 2023 at 2:31 PM
    AZBoatHauler
    So.Arizona
    You’re overthinking. Make sure the truck is level, fill it, plug it, drive it. If you didn’t jack up the axle tube opposite the drain it may not have all drained.
    RustyShackle323 likes this.
  5. Feb 18, 2023 at 2:45 PM
    _steezysr5
    Not at all I’m on leveled ground. I let it drained over 20 mins till almost nothing coming out. When filling just at 4qt it started to drip. Like I mentioned I still went ahead and added the 5th quart while applying pressure on the fill hole so nothing drips out till I finished adding the last quart.. oil started coming out. I measured the fluid that came out only 4qt plus a third of a quart of clean oil that I fought when finished filliping the 5th quart
  6. Feb 18, 2023 at 2:57 PM
    _steezysr5
  7. Feb 18, 2023 at 3:13 PM
    _steezysr5
    Didn’t lift the truck^. Is it possible to burn gear oil? only 4qt came out. I’m at 49k. Gonna go for drive find a level ground and check again.if nothing comes out the fill hole I’m a third of a quart low.
  8. Feb 18, 2023 at 5:21 PM
    AZBoatHauler
    So.Arizona
    If it’s to the check/fill plug, it’s full. It doesn’t really matter how much was put in.
    Xcumminsguy, MedCityMoto and Buckaroo like this.
  9. Feb 18, 2023 at 8:03 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Your level of OCD is similar to mine. Lol. Love it
    fuzzamungus likes this.
  10. Feb 18, 2023 at 9:53 PM
    _steezysr5
    The capacity for the 4.6 tundras is 4.9qt. I get that if it starts to come out it's full, that is the way to tell. but why did only 4qt come out in the first place? and when filling new oil at 4qt it already steadily drips like how it should. You're saying that it's okay to only add 4qt of fluid to a 5qt capacity dif? That doesn't seem correct. Has anyone else experienced this on their 4.6 tundras? this is what confuses me because I have the 4.9qt capacity dif and not the 5.7 tundras that have the 3.9qt capacity. The truck runs fine no noise or anything unusual tho I didn't get to check levels earlier so I will tomorrow.
  11. Feb 19, 2023 at 12:50 AM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    I have stopped messing with Toyota fluids before 100k miles. It always looked new to me and felt like a waste. Awesome engineering.
  12. Feb 19, 2023 at 12:54 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    You dont change you oil til 100k?
    Rocko9999 likes this.
  13. Feb 19, 2023 at 3:42 AM
    FO LO
    FO LO New Member
    Hell no but I think my 5.7 could do it if it had to.
  14. Feb 19, 2023 at 4:15 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Don’t forget the Lexus plugs
  15. Feb 20, 2023 at 11:37 AM
    _steezysr5
    Checked the fluid level and as I expected about another half quart came out. This indicates I have 3.9quarts capacity not 4.9. Unless 4.9quart is only needed when completely dissembling the dif? Still weird to me 4.9quarts should have came out when I drained the fluid but only 4 did. Anyway truck seem to run fine and all this is new to me. I just wanted to make sure I didn’t miss anything. Also, I used valvoline 75-90
    WILLINH likes this.
  16. Feb 20, 2023 at 3:29 PM
    Joe333x
    Joe333x Member
    Boston
    But every fluid in the truck besides the coolant and brake fluid is an oil. ATF, steering, diff, transfer are all oils, so why change one but not the others? Also brake fluid absorbs water and will corrode parts in your calipers causing seized brakes, and waiting to long to change your coolant allows it to become acidic. The only fluid Toyota actually says is okay until 100k is the coolant but then it says to do it at 50k after that so obviously it really should be at 50k anyways.
    Wallygator and WFD473 like this.
  17. Feb 20, 2023 at 3:53 PM
    Wallygator
    Just did both diffs myself and used Amsoil 75W90 in the EZ packs simply because I wanted to try them out. I had my doubts at first but now will never change the diffs any other way. The EZ packs are so convenient I wish they had them for the transfer case, but that is some golden child blood diamond laced shit of an oil only a few make.
    Anyway I replace the washers every time. YMMV.
    Mater and WFD473 like this.
  18. Feb 20, 2023 at 3:57 PM
    Joe333x
    Joe333x Member
    Boston
    Not gunna lie, I dont like the new squeeze packs, I actually pour the fluid into an old plastic quart container and pump it in, plus now you need a separate container to put old fluid in, same issue with those new boxes of oil you can buy that have a bag in it.
    Wallygator[QUOTED] likes this.
  19. Feb 20, 2023 at 4:08 PM
    #49
    Wallygator
    Really? I thought they were great over using the pump, which is what I have used for years. I'm not understanding what you mean about a "separate container to put old fluid in"? I drain the old fluid into a drain pan container and then put the old fluid into a 5 gallon bucket. When that is full I take it to the recycler.
    Mater and JLS in WA like this.
  20. Feb 20, 2023 at 4:11 PM
    #50
    AZBoatHauler
    So.Arizona
    Save yourself a trip to the recycler. :spy:
  21. Feb 20, 2023 at 4:15 PM
    #51
    Wallygator
    Nice! Do you have one?
  22. Feb 20, 2023 at 4:16 PM
    #52
    AZBoatHauler
    So.Arizona
    My buddy I do the boat racing stuff does - it’s really nice in the pits. Needless to say he takes all my old oil.
  23. Feb 20, 2023 at 4:18 PM
    #53
    Wallygator
    Funny, it doesn't mention anything about motor oil. :D
  24. Feb 20, 2023 at 4:20 PM
    #54
    AZBoatHauler
    So.Arizona
    Funny story, last year at SDBA Nationals someone (not in our group) decided to use some of Marty Logan’s oil (9x world champ) in one of the burners - they didn’t take into account he runs blown alcohol and his oil was packed with super flammable fuel. Couple people lost their chairs that night…
  25. Feb 20, 2023 at 4:23 PM
    #55
    Joe333x
    Joe333x Member
    Boston
    Around me you can just take the old jugs filled with the old oil back to Walmart at the service desk but it needs to be in a container and I dont think a plastic bag counts. Luckily I usually have a partial empty turkey fry oil container I can use for small jobs like differentials.
  26. Feb 20, 2023 at 4:26 PM
    #56
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Does he need any more old oil?
  27. Feb 20, 2023 at 4:26 PM
    #57
    AZBoatHauler
    So.Arizona
    Always. Working for on filling a 55gal barrel.
  28. Feb 20, 2023 at 4:27 PM
    #58
    AZBoatHauler
    So.Arizona
    And you can finally see the boathouse.
  29. Feb 20, 2023 at 4:27 PM
    #59
    FrenchToasty
    Mo
    Bone stock
    Sweet, I’ve got at least 7 gallons to add to it!
  30. Feb 20, 2023 at 4:28 PM
    #60
    AZBoatHauler
    So.Arizona
