Front and Rear Differential Gasket Part Numbers
Discussion in '2.5 Gen Tundras (2014-2021)' started by Anthony605, Aug 30, 2023.
  1. Aug 30, 2023 at 12:50 PM
    Anthony605
    Anthony605 [OP] New Member
    Anthony
    2020 Limited Double Cab
    What are the part numbers for the front diff, rear diff, and transfer case gaskets? How many of each to do all three? Thanks!
  2. Aug 30, 2023 at 1:23 PM
    Anthony605
    Anthony
    Disregard! I found em!
  3. Nov 21, 2023 at 7:59 AM
    johng34
    johng34 New Member
    NH
    2020 Tundra Limited
    None
    Would have been nice if you posted the p/n for the rest of us..........
    Anima and Leo's first like this.
  4. Nov 21, 2023 at 8:20 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    at least for the diffs, skip the gaskets altogether and just use RTV.
    FrenchToasty likes this.
  5. Nov 21, 2023 at 8:29 AM
    Vepr80
    Vepr80 New Member
    SA Texas
    2012 CM TRD offroad
    Leo's first likes this.
  6. Nov 21, 2023 at 9:36 AM
    RI2021Platinum5.7
    RI2021Platinum5.7 New Member
  7. Nov 21, 2023 at 10:27 AM
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    Rear gasket 42181-36060, I usually use FIPG instead of the gasket.
  8. Nov 21, 2023 at 1:10 PM
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    This kit works for all per one job, for the front diff, rear diff, and transfer case? How many jobs do you get out of per this one kit?
  9. Nov 21, 2023 at 1:16 PM
    Vepr80
    Vepr80 New Member
    SA Texas
    2012 CM TRD offroad
    Two total for both diffs and the t-case
    FitsofRage88[QUOTED] likes this.
  10. Nov 21, 2023 at 1:18 PM
    FitsofRage88
    Hill Country, Texas
    Thanks man!…
    I was unclear as to how many kits i needed to purchase!…
  11. Nov 24, 2023 at 4:05 PM
    737fixer
    737fixer New Member
    Anima likes this.
  12. Feb 7, 2025 at 1:39 PM
    Anima
    Anima New Member
    2000 TRD Tundra V8 4x4
    Just wanted to confirm the part numbers on these will work for 2000-2003 Tundra @737fixer ? It doesn't look like @Anthony605 ever posted the part numbers.
    I found Veper80's "Rexka 12pcs Transfer & Differential Service Gasket Kit" on Amazon pretty easily. But Navigating the part numbers for Toyota is pretty challenging.
    Can anyone confirm the above part numbers are compatible with a 2000 Tundra SR5 4WD?
    Alternatively, if someone can confirm the Rexka kit is just as good I'll go with that and just re-use my plugs (unless it's recommended to get new drain plugs).
    Thanks guys!
    Stopping at BevMo for some Whistle Pig... Yeehaw!
