Friggn bed squeak bullsh*t. Any fix?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stocky Balboa, Feb 27, 2020.
  1. Feb 27, 2020 at 4:37 AM
    Stocky Balboa
    Stocky Balboa [OP] New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Good Morning to all,
    My truck has a terrible creaking, squeak when going over speed bumps in a parking lot. Not bombing over bumps, I’m talking 1-2mph (idle) over them. It’s embarrassing and frustrating, sounds like a 30 year old trash truck. I’ve had trucks my whole life from work vehicles to other personal trucks and this is the worst.
    Any ideas what it is? a fix?
    ‘18 Limited Crewmax 29k miles
    Its had a creaking, squeak before these but:
    For what it’s worth, otherwise stock.
    -6112 in front
    -5160’s in rear
    -TRD rear sway bar
    Thanks - James
  2. Feb 27, 2020 at 4:48 AM
    15whtrd
    15whtrd Mr. Blonde
    Did you see the other thread where they were talking about being the bed mounts? Can you re-create the squeak just getting in the back of the truck? Make sure your bed bolts are tight, 62 ftlbs. Did you upgrade the shackles and bushings?
    Stocky Balboa[OP] likes this.
  3. Feb 27, 2020 at 4:48 AM
    Linuxmale
    Linuxmale 2018 Tundra 2003 Tj
    Sault Sainte Marie, MI
    2018 CREWMAX TRD Off Road ( a Canadian import )
    There’s a bed brace I saw someone mention. I have a 2018 CM and haven’t heard this yet but I think that’s what it’s for. I’ll see if I. An find the link.
    15whtrd and Stocky Balboa[OP] like this.
  4. Feb 27, 2020 at 4:49 AM
    Linuxmale
  5. Feb 27, 2020 at 4:49 AM
    TRDSteepSLOPE
    TRDSteepSLOPE New Member
    Kevin
    2019 Tundra CrewMax
    Just a thought but maybe it’s the sway bar? Obviously that sucks to remove but it’s manageable, likely the cheapest fix if it ends up being the issue.
  6. Feb 27, 2020 at 4:51 AM
    Stocky Balboa
    OC , CA
    I didn’t see that yet. Stock shackles and bushings. I will see if I can recreate the sound by getting in the bed.
  7. Feb 27, 2020 at 4:56 AM
    Stocky Balboa
    OC , CA
    Appreciate the feedback. I seem to remember it squeaked before I added the sway bar but I might have to start the process of elimination and remove it. Thank you.
  8. Feb 27, 2020 at 4:59 AM
    Stocky Balboa
    OC , CA
    Thank you. Mentions off-roading and sheet metal channel tearing but no creaking, squeak. Might be one in the same tho. Interesting...
  9. Feb 27, 2020 at 5:02 AM
  10. Feb 27, 2020 at 5:04 AM
    15whtrd
    15whtrd Mr. Blonde
  11. Feb 27, 2020 at 5:06 AM
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    Stocky Balboa[OP] and 15whtrd like this.
  12. Apr 9, 2020 at 2:18 PM
    Stocky Balboa
    OC , CA
    Update: Success! got around to taking off my TRD rear sway bar and the noise went away. Yes!!!
    I bought it second hand and when I installed it I torqued it correctly. I’m wondering if the bushings are worn, they look to be in good shape tho.
    Anyone use better aftermarket bushings?
    Not sure if I’ll put it back until I tow but I’m thrilled the bed noise is gone. Hope this helps the next person.
    AZBoatHauler likes this.
  13. Apr 9, 2020 at 3:03 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Did you try regreasing everything on the sway bar? It comes with grease for the bushings when new.
  14. Apr 10, 2020 at 8:20 AM
    Stocky Balboa
    OC , CA
    They seemed to have plenty of grease on them when I bought it off another fella. I didn’t add any grease at that time. Later, I did add some as I was trying to figure out where the noise was from, seemed to help but still made a racket.
    For now I’m ok going without the bar (it’s nice not to hear anything) but given all the free time I have I’ll clean it all up, re- grease and eventually try it again.
    I haven’t noticed much difference in rear sway without the bar yet, maybe the 5160’s are helping vs the stock 4600 or maybe I haven’t hit a turn fast enough haha.
    Thanks for the info.
    jtwags[QUOTED] likes this.
  15. Jan 31, 2022 at 2:40 PM
    BJOSF
    BJOSF New Member
    Hi Guys,
    Did this every get resolved? i have a 2021 Tundra 6.5 bed and am having super bad squeaking when on bumpy roads.
    Thanks!
  16. Jan 31, 2022 at 3:49 PM
    sparky412
    sparky412 New Member
    SW Pennsylvania
    22 SR5 OR CM 6.5 MGM
    My 2017 Tacoma off-road squeaked from the plastic shims in between the rear leaf springs pry them apart lubed them up squeaking was gone. Had to do this about twice a year
    batman900 and HulkSmurf14 like this.
  17. Jan 31, 2022 at 3:50 PM
    sparky412
    SW Pennsylvania
    If I were a betting person I would’ve never thought that’s where the noise was coming from but after research and personally doing the leaf packs the squeak was gone
    Rocko9999 and HulkSmurf14 like this.
