Fridge Circuit Board Repair
Discussion in 'Home Improvement' started by crabbymcnab, May 30, 2019.
  1. May 30, 2019 at 6:35 PM
    crabbymcnab
    crabbymcnab [OP] New Member
    2016 Inferno SR5
    We have a kenmore elite fridge/freezer that quit working. Sudden onset of no cooling and no condenser/motor function. Luckily all the elk, deer and beef was in the upright. We did lose 8 dozen eggs. We have to plan better for next time.
    Took the back panel off and found this doohickey that exploded. You can see the burn marks in the pic. I don’t know how to read schematics but I guess it has to do with cooling and freezing.
    My question is, without a tech coming out, how do I know something else didn’t cause the thing to fry? I don’t want to spend $275 for a board to have it blow again due to another problem. The wife looked and no appointments until the 7th and the service fee is $300+. So we would already be $600+ plus however long to get the part. Thoughts?
  2. May 30, 2019 at 7:06 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    About all that I can add is that little bad boy is an Integrated Circuit (by the fact that next to it, it says IC11). Either way you're going to have to get a new board or a new fridge. The IC could have shorted, or something else on the board shorted and the IC sacrificed itself. Be sure to ask what the warranty on the board is, I guess.
    Black Wolf likes this.
  3. May 30, 2019 at 7:11 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Had a board replaced a while back on an LG fridge. Technician said most likely a power surge. recomended inline surge protector at outlet. installed one and still running since.
    Wynnded likes this.
  4. May 30, 2019 at 7:21 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Well, there's a reason it can cost a lot of money to have a technician remove and replace or troubleshoot electronics. Do you have a tech manual or any testing equipment?
  5. May 31, 2019 at 6:45 AM
    crabbymcnab
    2016 Inferno SR5
    We have a tech coming Wednesday with a new board. He’s going to check the rest of the fridge to make sure other systems haven’t failed. There may have been a power outage a few days ago that the surge protector didn’t protect against. Very reasonably priced and worth it over me trouble shooting and throwing parts at it.
    Trooper2 and Wynnded like this.
  6. May 31, 2019 at 9:57 AM
    crabbymcnab
    2016 Inferno SR5
    Fridge is 7. Spoke to the tech, $335 for a diagnostic and a replacement board.
  7. May 31, 2019 at 10:03 AM
    Borgs
    Borgs New Member
    PA
    I did this for a frig a few years ago and just the same for a dishwasher. Insanely priced to have fixed. These things are junk, and seem to have a 5-year life span anymore. Pretty much like disposable razor blades. Fortunately they seem to be cheap enough that it doesn’t kill you when an appliance dies.
    NewImprovedRon likes this.
  8. May 31, 2019 at 10:45 AM
    Trooper2
    JR
    Seems reasonable.
    If not already have, get something like this for all of your appliances.
  9. May 31, 2019 at 5:20 PM
    crabbymcnab
    2016 Inferno SR5
    That’s what sucks, I have something similar already!
  10. May 31, 2019 at 5:22 PM
    Trooper2
    JR
    Probably just component failure on board then.
