Free Tundra horse power?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ZPMAN, Jun 2, 2018.
  1. Jun 2, 2018 at 4:33 AM
    ZPMAN
    ZPMAN [OP] 2nd place is the 1st looser
    Minnesota
    During my Bully Dog install i noticed that my gas pedal wasn't getting full travel because of not only of the carprt but also the the interference from the Husky floor matts. From the pictures i was able to clearly see at least over 1/8" of the travel was not being used. Would appreciate it if someone with bettor knowledge of the system could correct me please.
    No pressure on pedal.
    Pressure on pedal with Husky liners.
    Pressure on pedal with carpet.
    Stimulation of Husky liners.
    Pedal depressed fully.
    Free HP?
    When i reinstalled the pedal i put a few washers on the studs to bring the out a little. The correct way would to be make up a spacer plate for full contact of pedal bracket to firewall, and possibly a little shave under the pedal itself.
    Reminds me of the old saying STAND ON IT!
    T500, MatthewPTguy and Black Wolf like this.
  2. Jun 2, 2018 at 6:11 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    :transformer::transformer: You may be on to something here!!!!!
    T500 and ZPMAN[OP] like this.
  3. Jun 2, 2018 at 6:16 AM
    ZPMAN
    Minnesota
    I hope so, someone with a little more electrical back ground could maybe put a meter on the unit.
  4. Jun 2, 2018 at 7:52 AM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    It has been a belief of mine for some time that the engineers at Toyota have been working on gas pedal linkage to increase fuel efficiency.
    JH5370 and ZPMAN[OP] like this.
  5. Jun 2, 2018 at 8:02 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Thinking Husky is just trying to get you better mileage........
    ColoradoTJ and ZPMAN[OP] like this.
  6. Jun 2, 2018 at 9:02 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Well, does it feel like it has more power now?
  7. Jun 2, 2018 at 9:10 AM
    ZPMAN
    Minnesota
    Hard to say with the SC on now lol , i dont know if the throttle body will operate with just the key on, that would be a great way to check if it did.
  8. Jun 2, 2018 at 9:14 AM
    ZPMAN
    Minnesota
    Maybe a toyota mechanic will pipe in so i can stop thinking about black helicopters. :ohsnap:
  9. Jun 2, 2018 at 9:40 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  10. Jun 21, 2018 at 10:53 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I lost this thread after reading it for some reason so I started another to show my husky liner mod. What I'm thinking now is grinding the arch off the back of the pedal to allow more travel. But I'm sure there has to be a way to see if the pedal position sensor reads 100% when fully pressed. If it does then no need to mod.20180615_154920.jpg
  11. Jun 22, 2018 at 3:46 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    This theory will need to be confirmed on the dyno.:thumbsup:
    ZPMAN[OP] likes this.
  12. Jun 22, 2018 at 5:29 AM
    Since the Tundra is designed with a computer controlled actuator at the throttle body (drive by wire), I’m thinking not.
    Unless the pedal isn’t getting full range with the floor mat....
    T-Rex266 likes this.
  13. Jun 22, 2018 at 6:00 AM
    Midmo_tundra
    Midmo_tundra New Member
    Missouri
    Following, I have always wondered the same thing.
  14. Jun 22, 2018 at 6:08 AM
    Nit2wn
    Nit2wn New Member
    James
    Alabama
    2013 Crewmax TRD 4wd
    I would think a tech computer could tell. When we test Mercedes at work, there's a part of it that shows pedal angle at full throttle, then kick down[completely floored], then idle. If for some reason the pedal is bad or wiring damaged, it goes into limp which means idle.
  15. Jun 22, 2018 at 7:03 AM
    daylorb
    daylorb New Member
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    On many PDK Porsche's, the kick-down is actually a button on the floor that changes gears at certain RPM's. Sport mode increases throttle response which basically means you have to push less to get the same gas flow as pushing more in non-sport. Neither of those actually increase horsepower, but faster throttle response can result in faster acceleration.
    I'd be surprised if Toyota was limited by the travel, but this mod certainly cannot hurt so why not! If the butt dyno says it is faster - it is faster!
    TRD Pro Rookie likes this.
  16. Jun 22, 2018 at 9:49 AM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Agree! My butt dyno says I now have a 10 second truck.
  17. Jun 22, 2018 at 10:10 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I would wholeheartedly agree with you. My Mom has an 05 4Runner and my wife has a 16. Same powertrain in both yet the throttle response in the 05 makes it feel like a totally different car.
  18. Jun 22, 2018 at 10:17 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    It is interesting and I would also like to see if there really is a difference. But, that being said, other than just an interesting experiment, I don't really see the need for this. I have owned my truck for about 10,000 miles and out of that probably not more than 1 mile total have I floored it. I rarely go over 4,000 rpm because that is plenty, and that is where it sounds the best; anything over that it starts screaming.
