Freaking Low Payload
Discussion in 'Towing & Hauling' started by CaptCraig, Jun 9, 2021.
  1. Jun 13, 2021 at 8:00 PM
    #151
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    It’s by far my favorite truck.
  2. Jun 13, 2021 at 8:05 PM
    #152
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Can you tell us the problems you've had?, just curious.
  3. Jun 13, 2021 at 8:10 PM
    #153
    One of my favorite Trucks of all time.
  4. Jun 13, 2021 at 8:11 PM
    #154
    ScenicRoute
    With the Ford the biggest problem so far is the transmission. Bring back the 6 speed. Unloaded its fine. Loaded it sucks. You wanna talk about some high trans temps when a transmission decides it doesn’t want to lock the torque converter and then it does want to lock it and back and forth. Oh and drive usually means go forward right? I’ve lost track how many times you put it in drive and give it throttle and it goes backwards. So now it’s drive. Foot hard on the brake with some throttle…tries to go forward…good ok let’s go.
    TILLY[QUOTED] and Cpl_Punishment like this.
  5. Jun 13, 2021 at 8:19 PM
    #155
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm sure there are thousands of accidents where the individual is over payload but the majority are not ending up in civil court. Circumstance would have to be gross negligence like towing way over the GVWR and followed up with speeding and drunk driving. My point being the court system would be over loaded if TT owners were being dragged into a civil lawsuit for being a couple hundred pounds over GVWR.
    ....but what do I know but I did sleep at a Holiday in last night.
    We need lawyer to comment on civil suit litigation.
  6. Jun 13, 2021 at 8:24 PM
    #156
    @roypark
    @TundraLaw
  7. Jun 13, 2021 at 8:49 PM
    #157
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    This truck tries to go BACKWARD when you’re in DRIVE??? Lolololol
    Cpl_Punishment likes this.
  8. Jun 13, 2021 at 9:32 PM
    #158
    Most RV and towing accidents don’t involve other vehicles (from the majority that I have seen), so ending up in criminal/civil court doesn’t happen a lot.
    The friends that I will be allowing to tow my camper have done a metric buttload of research and did talk about some accidents involving not being able to stop and rear ending a vehicle. There was more damage done to the tow vehicle and camper.
  9. Jun 13, 2021 at 9:40 PM
    #159
    Do you have the new 10 speed? I haven’t heard a whole lot of good things about it in the diesel/7.3/or GM built 10 speed “wannabe” Allison. I have heard of three local guys having major issues with the GM built 10 speed before 35k miles.
    This does not give me a warm and fuzzy.
    Today a friend had a new Ram with under 30k miles go into limp mode due to exhaust DPF issues.
    When I leave CO and no longer need to drive over 10500 ft of elevation with 15+k lbs, I can totally see myself getting a gasser again. Hell, the Tundra is at the top of the list if the towing isn’t half of what it is now.
    Terndrerrr and Cpl_Punishment like this.
  10. Jun 13, 2021 at 10:04 PM
    #160
    ScenicRoute
    Oh it succeeds at this endeavor.
  11. Jun 13, 2021 at 10:19 PM
    #161
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    I’m not sure how heavy I would be willing to go on my HD gasser. I’m at about 7,500lbs loaded along with some extra stuff in the bed. Does fine on the hills if I have momentum but if I get stuck behind someone it isn’t easy accelerating up a hill. Not sure if I would be happy towing a 10k+ fifth wheel with it. Although I wonder how much it might help to regear from 3.73 to 4.30.
  12. Jun 13, 2021 at 11:49 PM
    #162
    10-12k is no-mans land…so it seems. Here in CO, it would be a closer to 10K for sure or maybe even less. At my house the elevation is 7550’. So the gas powered guys would drop 91.2 crank HP from the get go.
    A re-gear would help some when towing, but you would take a hit empty in the fuel mileage department. Fuel economy is not my first concern anyway to be honest. I purchased a truck to do work and make my life easier and do it safely.
    I was at a silver wedding anniversary party this weekend for one of the wife’s co-workers that I have never met. They are from Corpus Christy, Texas. He has a 2016 GMC 2500 Denali and tows a large 5th wheel. I assumed he had a diesel. We started talking about how his truck would drag down pretty bad on the hills here in CO and how disappointed he was in the power. So I put my foot in the mouth and said “aren’t you glad you didn’t have a gasser? Then you would really have something to complain about!” He responded….”well that is the gas motor.” Lol. Oops.
    All depends what you are towing. These two pics are about the same weight within 1000 lbs (TT 8200 / GN and tractor 9200 lbs) One tows a hell of a lot easier than the other.
    69CFB914-EA28-49EB-A464-98557BE61F3D.jpg 64B02053-6C1D-4206-8DA7-6E2EF6210AAA.jpg
  13. Jun 14, 2021 at 3:08 AM
    #163
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    BX23S is boulder moving champion.
  14. Jun 14, 2021 at 3:25 AM
    #164
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    This is interesting, I have 2020 F350 7.3 , 3.73 gear 10 speed an I haven't had any issues going on over 8k miles now. I love it. Makes towing so much less painfull then the Tundra 6 speed constantly having the engine winding out trying get anywhere, having to run in S4 ect . I'm not in the rocky's here but I haven't had any issues at all towing my 7-8k lb TT in the white mountains.. I have read that the new 10 speeds had some issues though from other folks, seems a bit hit or miss . Guess I got lucky so far..
  15. Jun 14, 2021 at 3:45 AM
    #165
    ScenicRoute
    White Mountains? We must be neighbors!
    Johnders2586[QUOTED] likes this.
  16. Jun 14, 2021 at 8:29 AM
    #166
    Jaxyaks
    Jaxyaks New Member
    I think they have a recall on that transmission on some of the years, yours may not be one of them. From the description of the recall its pretty extensive and requires them to open the transmission up to fix.
    I was looking at the 7.3 earlier this year as well. I am trying to avoid big 3 issues and depreciation if I can help it.
  17. Jun 14, 2021 at 8:34 AM
    #167
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    Depreciation is not an issue with 3/4 ton and 1 ton trucks. I'm a multiline adjuster and can tell you from experience that they hold their value pretty darn good, now on a 1/2 big three truck its a different story
    ColoradoTJ likes this.
  18. Jun 14, 2021 at 8:38 AM
    #168
    Jaxyaks
    Jaxyaks New Member
    That is not my experience with 3/4 ton or 1 ton gas trucks, Diesels I would agree with you, but diesels come with their own set of issues that I really don't want to deal with unless the truck is making me money. Everything is holding its value now, go back a few years ago and look at HD gassers. Ram in particular compared to Toyota...any Toyota... If you run identical packages on Ram 1500/2500 gasser the depreciation on the 1500 is actually less
  19. Jun 14, 2021 at 8:45 AM
    #169
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Good luck with that.
  20. Jun 14, 2021 at 8:48 AM
    #170
    Jaxyaks
    Jaxyaks New Member
    Right!....I'm gonna make something work with the Tundra, I have taken a bath before with a domestic truck and I won't do that again. I'm just waiting to see what the new tundra specs are before I decide on new Gen or old Gen. I haven't decided yet if I am going to trade the Tacoma I have now on it or just keep it and have both. I can make arguments for both ways.
  21. Jun 14, 2021 at 8:56 AM
    #171
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Hopefully the new Tundra will address the payload issue so some of us don't have to go with a crap domestic. It's a big pill to swallow buying a unreliable but more towing capable domestic over the Tundra.
  22. Jun 14, 2021 at 9:07 AM
    #172
    2mchfun
    You can address payload with the current Tundra. Trailer design or modifications can do a whole bunch of stuff to tongue weight and trailer weight. Take a 30' steel Trailer and compare it to a 30' aluminum trailer for example. Take a 4' tongue and compare it to a 5.5' tongue, there are lots of options.
    Terndrerrr likes this.
  23. Jun 14, 2021 at 9:43 AM
    #173
    2mchfun
    5 grand and fixed. Much cheaper than buying that 3/4 Ton. Not to mention, you can keep the truck you like and still pull more than enough trailer for your glamping expeditions if that's your thing.Screenshot_20210614-113804.jpg
  24. Jun 14, 2021 at 10:10 AM
    #174
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Can you please provide more info on this "snubber"? That is simply interesting to me.
  25. Jun 14, 2021 at 10:16 AM
    #175
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Wonder what that thing is like to back up?
    A-A-Ron and WBW like this.
  26. Jun 14, 2021 at 10:19 AM
    #176
    WBW
    WBW Resident lurker
    Bruce
    I would think it is similar to backing doubles/triples. I know I'm not very good at it at all. The back trailer is all over the place when backing!
  27. Jun 14, 2021 at 10:19 AM
    #177
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    If it's like the one I saw you can lock the articulated portion. And its motorized so you can position a trailer without the vehicle.
  28. Jun 14, 2021 at 11:08 AM
    #178
    ScenicRoute
    That looks fun to back up!
  29. Jun 14, 2021 at 11:37 AM
    #179
    2mchfun
    Google trailer toad and go from there
  30. Jun 14, 2021 at 12:57 PM
    #180
    2mchfun
    Straighten it out, drop the pins to lock it, back up like normal. If me, I would still load 500-800 lbs on the truck rear axle to maintain good traction. Let's face it pushing or pulling any kind of weight with poor traction could lead to problems and the whole idea is to mitigate the problems.
    GODZILLA likes this.
