Freaking Low Payload
Discussion in 'Towing & Hauling' started by CaptCraig, Jun 9, 2021.
  1. Jun 11, 2021 at 8:32 PM
    #91
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The squeal sound shouldn't be related to towing but bring it up with the dealer and get it solved. When you truck pulls with the trailer on is it after you make a turn? I've seen some WD hitches that bind after a turn and cause a pull in the truck with the wheel off center.
  2. Jun 12, 2021 at 5:29 AM
    #92
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Fully agree. The 'payload police' is a real thing. Severe load imbalance is a much bigger concern than being 10% over the rather arbitrary limits.
    And yes I'll call them arbitrary since we'll never know how they were created. Take a look at the Ford payload charts some time and you'll see that they increase their allowances with even just an engine change.
    CaptCraig[OP] and 2mchfun like this.
  3. Jun 12, 2021 at 5:34 AM
    #93
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    I'd agree the payload on a Tundra is underrated. Mine lists a limit of 1310 lbs and I'm about to put a 1100 pound Four Wheel Camper in it, which plus me, my wife and our gear will be a bit over for sure. However, even Four Wheel Camper as a brand still makes them listed for Tundras. Obviously there's the legality of being over if we have an accident, but unfortunately I'm going to take the chance because I know in reality it can handle it just fine.
    Bigboitundra likes this.
  4. Jun 12, 2021 at 5:51 AM
    #94
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I think on the legal aspect you will be just fine. Your not going to be in any legal hot water being a couple hundred pound over payload and insurance will cover you if you have an accident. The reality is insurance companies cover clients for drunk driving, distracted driving and any other infractions and it's no different if you were towing over payload.
    2mchfun likes this.
  5. Jun 12, 2021 at 6:04 AM
    #95
    andnyleswillriot
    Breckenridge, CO
    True. Maybe I should just take the sticker that shows the payload capacity off, then how would they know anyway! Haha
    2mchfun and Ruggybuggy[QUOTED] like this.
  6. Jun 12, 2021 at 6:30 AM
    #96
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'm not following how just because you don't know how automotive engineering is done that means the limits must be arbitrary.
  7. Jun 12, 2021 at 6:43 AM
    #97
    This is true. Insurance companies have to cover you to policy limits. Then you are on your own. Ask me how I know.
  8. Jun 12, 2021 at 6:44 AM
    #98
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm not sure if it's true but I've heard that the GVWR and the front and rear axle ratings printed on the other door sticker should be used and that the payload number on the yellow sticker is more of a recommendation by the manufacturer.
  9. Jun 12, 2021 at 6:45 AM
    #99
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Do tell. I'm all ears when it comes to first hand experience.
  10. Jun 12, 2021 at 6:48 AM
    #100
    Short story:
    -wife in accident, at first deemed her fault, later proved it wasn’t.
    -coverage was 300k
    -medical bills alone was 580k
    -vehicles totaled 40k
    -insurance paid 300k and walked away.
  11. Jun 12, 2021 at 7:13 AM
    #101
    I agree that most of us have been over our capacity at some point in our lives. Some more often than not.
    For the people that don’t think much will happen…read this.
    https://www.tundras.com/threads/axle-bearing-destruction.83251/#post-2102672
    1500 lbs in bed, 6000 lbs+ trailer and a lifted truck (6”). Destroyed rear axle housing due to bearing failure.
    Axle ratings, GVWR, and TGVWR is what will get you in hot water if an accident happens.
    For instance, if your payload says XXXX, and your axle ratings are a bit higher go with that number. Unfortunately that rarely happens. On my truck I have to lower mine from 3808 lbs to 3600 due to extra weight. I need to re-weigh again to make sure due to having items in the bed.
    Terndrerrr likes this.
  12. Jun 12, 2021 at 7:59 AM
    #102
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Wow, that sounds awful. So you had to pay $320k out of pocket? Were you able to settle that amount down at all?
  13. Jun 12, 2021 at 8:02 AM
    #103
    2mchfun
    If you have a serious travel trailer accident there usually isn't much trailer left to actually calculate an accurate weight of the trailer. Tanks will likely be split open and all fluid weight is history.
    Piki likes this.
  14. Jun 12, 2021 at 8:18 AM
    #104
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    To me as long as you use some common sense you are fine. Like I said earlier anytime you load up your family and go to the lake or go hunting with some buddies, you are probably over the payload capacity, but I can also take a look at my truck and tell if it's over loaded or not. I'm not going to load a ton of bricks in my bed, but I'm also not scared to go over the payload by a couple hundred pounds either.
  15. Jun 12, 2021 at 8:47 AM
    #105
    Some was settled down on the other drivers expense….after a long legal battle that got more expensive than we wanted.
  16. Jun 12, 2021 at 10:59 AM
    #106
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Wow , those were some crazy medical bills , Reminds me how thankful I am for living up in Canada , thank goodness for free healthcare !
  17. Jun 12, 2021 at 11:10 AM
    #107
    2mchfun
    Not exactly free, but at least you are not out of pocket large sums at one time.
  18. Jun 12, 2021 at 11:21 AM
    #108
    CaptCraig
    CaptCraig [OP] New Member
    Craig
    2021 Tundra CrewMax 4x4
    Thank you for that link. Just got back from the scale & crunched the numbers. We just squeak under what everything it's rated at.
  19. Jun 12, 2021 at 11:24 AM
    #109
    Professional Hand Model
    Hand Protectors
    Loving the comedy going on with some of these comments.
    So far we have open admissions of Gross Negligence, Willful Negligence, and now here comes free healthcare willful and gross economic negligence.
    You know when people become unopened to reality when they are presented facts and still don’t change their minds. 2+2=5.
    Bammer, GODZILLA and ColoradoTJ like this.
  20. Jun 12, 2021 at 11:33 AM
    #110
    CaptCraig
    Craig
    Yeah, not helpful. But then again opinions are like a$$holes...
  21. Jun 12, 2021 at 11:45 AM
    #111
    Hand Protectors
    Of which, I am Supreme.
    I will say I admire your diligence in the matter of staying in spec.
  22. Jun 12, 2021 at 1:07 PM
    #112
    I think you’re wrong…=7.
    Right?:rofl:
  23. Jun 13, 2021 at 7:19 AM
    #113
    Finally after years of offering, a fellow Tundra owner is going to take me up on my offer to test tow my camper.
    Truck:
    2018 Tundra CM Limited 4x4
    TT:
    2013 Keystone 280RS
    Specs:
    https://www.nadaguides.com/RVs/2013/Keystone-RV/M-280-RS/6024222/Specs
    9CF01966-27AB-4F68-B124-7A70A8E38231.jpg 8AF2F354-D92C-4609-9076-D9C1345BFB46.jpg 593D5598-AD67-4301-B3D4-EC1C603ED2CD.jpg
    These people are good friends that are out camper shopping and the salesmen keep telling him the Tundra can pull 10k easy, tundra is an underrated 3/4 ton, etc etc etc. We have heard it all. The salesmen are not liable and just trying to make the sale.
    I stopped by their house yesterday to chat and was bombarded with questions.
    I talked them into the Tundra purchase and even their son purchased a CM Tundra for his family. Both now want campers and have been getting conflicting info.
    Base weight is 6500, but when I rolled mine over the scales it was closer to 7 or 7200 lbs empty.
    I’ll let you guys know what they think.
  24. Jun 13, 2021 at 8:20 AM
    #114
    Jamesausman
    Jamesausman New Member
    Phoenix
    2023 Limited OR
    I was in the dealer for service and checked out the Tundra on the sales floor. 975 lbs payload. 10,200 lbs towing capacity but minimum tongue weight of a 8000 lb trailer should be 800 lbs meaning if you alone weight more than 175lbs or so you’re payload is maxed. Forget the family and coolers.
    Cpl_Punishment likes this.
  25. Jun 13, 2021 at 11:09 AM
    #115
    BrakeDust
    Hill Country, TX
    No, because driver is already 'included' with the vehicle and doesn't factor into the payload rating. The advertised payload is your wife, kids, dog, generator etc - not you.
  26. Jun 13, 2021 at 11:28 AM
    #116
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    How can they legally do that when no drivers weigh the same?
  27. Jun 13, 2021 at 11:33 AM
    #117
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    they use an average adult weight. Which is probably 100lbs lighter than the average truck buyer in 2021 usa
  28. Jun 13, 2021 at 11:48 AM
    #118
    CBrider
    CBrider New Member
    Cary
    Eugene, OR
    2017 1794 Edition TRD Sunset Bronze Mica TRD exhaust
    Diamond Back Cover
    The J2807 standard assumes there is both a driver and passenger in the vehicle, each weighing 150 pounds and that the tow vehicle also include up to 70 pounds of aftermarket hitch equipment.
  29. Jun 13, 2021 at 11:52 AM
    #119
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    I believe the SAE rating system that is used includes 300lbs of people and 70lbs of added hitch (such as a WDH).
  30. Jun 13, 2021 at 11:52 AM
    #120
    Hand Protectors
    Kinda like the 1st Gen TV advertisements back in 2002 where they fit 4 guys in the Access Cab. They were each about 4’10” Tall and 98lbs. :boink::D
    Hbjeff[QUOTED] likes this.
