Freaking Low Payload
Discussion in 'Towing & Hauling' started by CaptCraig, Jun 9, 2021.
  1. Jun 10, 2021 at 7:16 PM
    #61
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Yeah plan is maintain strictly and once I start having issues i'll do the thing that isn't allowed anymore lmao
    crewmaxlmt[QUOTED] likes this.
  2. Jun 10, 2021 at 9:10 PM
    #62
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    :facepalm:
    So you loaded something excessively heavy in the bed of your truck and it didn’t break?
    When you are hauling trailers this big with your entire family it isn’t the time to be “half assed”. This isn’t “I loaded a pallet of pavers in my truck and drove ten miles home from Home Depot”.
  3. Jun 11, 2021 at 7:28 AM
    #63
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    A honda ridgeline, chevy s10 and a ford windstar have a higher payload rating than a crewmax. You ever think the number is bullshit?
    Besides the soft leaf springs, everything about the truck is light duty 3/4 ton size. Old 3/4 ton trucks had a 8600 gvwr.
    OP should use his WD hitch, get airbags, and pull his camper.
    Hbjeff likes this.
  4. Jun 11, 2021 at 7:55 AM
    #64
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    Don't you think that Toyota would have benefited from putting a higher payload number on the Tundra if it really could? I understand that the truck may be able to hold the weight but for how long before something breaks? Shoot with my truck the steering would feel light with it being at the payload limit I can't imagine how it would feel with 3k pounds in the bed.
    GODZILLA and Cpl_Punishment like this.
  5. Jun 11, 2021 at 8:01 AM
    #65
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Tundra is pulling champion.
    Some exclusions apply.
  6. Jun 11, 2021 at 8:08 AM
    #66
    A-A-Ron
    Aaron
    Seattle
    I actually own a 3/4 ton truck. If you compare the components the Tundra is not even close. The Tundra is a heavy 1/2 ton truck, which leads to a smaller payload rating.
    I have given the OP a few pointers on how to make it safely work based on my experience and research. Feel free to read them and let me know if you disagree.
    The OP doesn’t need to use airbags but if he does you need to careful about using it with a WDH. Not setting it up properly will cancel out the weight distribution and sway control properties.
  7. Jun 11, 2021 at 8:12 AM
    #67
    Old 3/4 tons are just that…old tech that couldn’t pull a greased rope out of a goats ass.
    Please show me what is 3/4 ton sized on the tundra. (Waiting patiently for the 10.5” ring gear comment)
    The Tundra, like all other manufacturers have gone to the J2807 standard. Toyota had to lower their ratings due to this standard. The other manufacturers had to up their game to increase them. These trucks are tested…and any more payload or trailer weight made them fail the J2807 standard. It’s just that simple.
    I’m really hoping the 2022 Tundra is all that I have been hearing.
    15whtrd, GODZILLA and Cpl_Punishment like this.
  8. Jun 11, 2021 at 8:14 AM
    #68
    Following….
    I get my daily belly laughs from at least one of your posts. Thank you for that.
    Bammer, 15whtrd and hagrid[QUOTED] like this.
  9. Jun 11, 2021 at 8:26 AM
    #69
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm towing close to your weights and also over payload. You won't have any issues. Most are over payload and tow safely. Your under your GVWR. I've towed through the Rockies over and down the steepest grades. No issues or handling problems.
    Bigboitundra and jordoncloutier like this.
  10. Jun 11, 2021 at 8:48 AM
    #70
    Half Assed
    Heartland Florida
    Probably not. OP didnt even check the payload before he bought one. If Toyota made a 3/4 ton rated tundra it would be a huge flop.
    I own a HD 3/4 ton truck too. The tundra has more power and stops faster. About the only thing bigger on it is the rear section of the frame, the leaf packs, and the full floating axle.
    4 wheel disc brakes, 4 piston disc on the front that need a 17" wheel. Older light duty 3/4 ton trucks had semi float axles and a 10k tow rating. In my opinion the payload is underrated.
    Bigboitundra likes this.
  11. Jun 11, 2021 at 9:24 AM
    #71
    I'm not really sure how or why we are talking about "old" 3/4 tons and comparing them to a Tundra of today. Maybe we should be comparing a new HD gas and diesel truck of today against the 1st gen tundra. That is how ridiculous this sounds.
    So I am just going to ask, what light duty 3/4 ton in the past two decades has a semi-floating rear axle? I remember some Suburbans (as late as '91) with SF rear 14 bolt axles. If we are going back that far, the Tundra was just a fart in the wind.
    Hell, the only "older" truck I would even consider is a 2005-2006 GM HD truck with the 8.1L Vortec/Allison combo. That would only be a ranch truck at best. Even my 2016 GMC 3500 is outclassed by today's HD market, which is ok since I don't want to sell mine and pull an additional 45000.00 out of my investments to pay for one.
    GODZILLA, Cpl_Punishment and A-A-Ron like this.
  12. Jun 11, 2021 at 9:37 AM
    #72
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    The Tundra does have some large components for a half ton truck. You can really see this when comparing the curb weights with the big three. However, towing 10K with my old '06 F350 SRW is like towing 6K with wy Tundra. I do suspect most of that is attributed to the leaf packs and the rigidity of the rear frame.
    Tow what you want with your Tundra but a current 3/4 or 1 ton will blow it out of the water. This is coming from someone that loves the Tundra. There really is just no comparison to a HD truck.
  13. Jun 11, 2021 at 10:06 AM
    #73
    A-A-Ron
    Aaron
    Seattle
    Not sure how old your 3/4 ton is. The current HD components are way beyond what is in the current Tundra.
    I really enjoyed my Tundra and it did well towing. It is a huge difference towing with a current HD truck though.
  14. Jun 11, 2021 at 10:25 AM
    #74
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    @Piki deserves the credit for that one. Nonetheless I'm glad a couple folks here get my humor.
    Jaypown, 15whtrd, Terndrerrr and 2 others like this.
  15. Jun 11, 2021 at 10:37 AM
    #75
    Half Assed
    Heartland Florida
    Because I said older 3/4 ton trucks had a gvwr of 8600. Many had semi float axles. When compared to a 07+ tundra, the tundra is the same or better. GM is still putting semi floats in 3/4 ton 8600gvwr vans. I think they abandoned them in pickups in the early 2000s when they abandoned making light duty 3/4 tons. I think Dodge and Ford also stopped making light duty 3/4 ton trucks.
    My point is that I wouldn't worry about the going over what the sticker says. 1200 pound payload or whatever rediculous number they give for a crewmax. Would I replace a 3/4 ton truck with a Tundra or go tow a 3/4 ton sized camper with a tundra? No.
  16. Jun 11, 2021 at 1:28 PM
    #76
    CaptCraig
    CaptCraig [OP] New Member
    Craig
    2021 Tundra CrewMax 4x4
    The only odd things I noticed was a very feint intermittent squealing sound coming from the front & it seemed to want to slightly pull to the right. I figured it was the crosswind since it didn't seem to be as much of a problem on the way home.
  17. Jun 11, 2021 at 1:34 PM
    #77
    CaptCraig
    Craig
    Nice, we're hoping this gets us through our camping life with kids. Planning on downgrading once they all move out in the VERY distant future. So, probably sticking with what we got.
  18. Jun 11, 2021 at 2:38 PM
    #78
    Early 2000’s 3/4 ton gas powered axle right in my garage.
    D0941359-317A-431A-B37C-B560CC93E1B3.jpg 85BEF2E1-B599-40DD-8BC3-918FFA26E4AB.jpg
    When the others use aluminum body panels the weight drops pretty quick. Being heavy in most cases is good.
  19. Jun 11, 2021 at 2:49 PM
    #79
    crewmaxlmt
    scott
    I know that the F250HD's had a full floater all the way back in 1990. My '99 F250 Super Duty had a Sterling 10.25" full floater. Not sure about Dodge and Chevy though. They all did weird stuff with their lineups back then. Can you believe that Ford had a F250 with 7700 GVW and a F250HD with a 8800 GVW? Strange times for sure.
  20. Jun 11, 2021 at 2:57 PM
    #80
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The “light 3/4” trucks from the 90’s were def not hd trucks. I owned one.
    they had bigger rear axle and thicker frame rails, however the trans and all front suspension components were 1/2 ton units. The term “bigger” rear axle was misleading. Chevy used a semi floating 14 bolt, which was similar to our tundra axle. The standard half ton axle at the time was a weak as crap 10 bolt. So really the half tons used an inferior unit. The light 3/4 of 1994 was equal to todays half tons really
  21. Jun 11, 2021 at 2:59 PM
    #81
    2mchfun
    It all boils down to if something breaks, mfg don't want to have any liability. So the consumer gets the shaft.
  22. Jun 11, 2021 at 3:47 PM
    #82
    I wonder what the payload is for a Ford Model T and how that compares to Tundra? Now that would be amazing to see how much those wood spoked wheels would take….
  23. Jun 11, 2021 at 3:50 PM
    #83
    2mchfun
    Check out some old mining wagons. You will be shocked at how massive they were. I'd say about ten yards of ore capacity.
  24. Jun 11, 2021 at 4:42 PM
    #84
    Tileguy
    Tileguy New Member
    Birmingham, Alabama
    2011 Toyota Tundra
    I am in the tile installation business. Added Super Springs to the rear of my Tundra and often carry loads around 2K pounds. I have put almost 500K miles on my two Tundras without issue.
  25. Jun 11, 2021 at 4:52 PM
    #85
    2mchfun
    I carried that in a 79 Mazda also hundreds of thousands of miles.
  26. Jun 11, 2021 at 5:01 PM
    #86
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Liability LMAO!!! I been hit by two uninsured drivers in the last 5 months. Police don't even issue a citation. Insurance company doesn't care if they don't have insurance they don't go after them for personal assets. Tow any weight you want nobody gives a shit that insures or enforces the law. All these snowflakes. Oh I am over by 200lbs, Oh need smaller trailer, do what you want everyone else does. Zero repercussions. Let the flames begin....
  27. Jun 11, 2021 at 5:04 PM
    #87
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    Unfortunately most of us are probably over payload anytime we tow or haul. Put 4 good size guys and your hunting gear in the bed and you are at or over payload. Tow the trailer with a side by side on it and payload is way over.
  28. Jun 11, 2021 at 5:14 PM
    #88
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    More truck or less trailer is my official recommendation.
    However, if I had your trailer, I'd get everything loaded up and go to some certified scales. The numbers I'd pay attention to are the axle ratings. There is quite the discrepancy between GVWR and GAWR on our trucks. On my truck, it's 1000lbs difference. I would have no problem being over payload as long as I stayed under my GAWR. If I weren't comfortable with that, I'd take advantage of the INSANE Tundra resale value and trade it in on a GMC HD gasser. :headbang: I love my truck though. I'd probably just make it work.
  29. Jun 11, 2021 at 5:29 PM
    #89
    2mchfun
    You nailed it! I almost consumed payload just with suspension, armor, tires, tools, lights, etc. Hell, seat covers alone are almost 50 freaking pounds lol. Don't even talk to me about passengers and luggage. Tow in the dark, fewer eyes, less traffic, kids are asleep, less heat build up, etc.
  30. Jun 11, 2021 at 5:31 PM
    #90
    crewmaxlmt
    scott
    Remember, it is very expensive to tow an HD truck and trailer back to the dealership, and most service departments are not open on the weekend.
    Piki and jordoncloutier like this.
