Frame Rust
Discussion in 'General Tundra Discussion' started by Morozumi99, Apr 21, 2020.
  1. Apr 21, 2020 at 7:20 PM
    Morozumi99
    Morozumi99 [OP] New Member
    Hi Everyone,
    I have a 2004 tundra. I’m afraid the frame is about to break due to rust and corrosion. I know there’s been various recalls for Toyota frame rust but I can’t find that my truck was recalled. When I bought it used, I was told it was under coated but not replaced. The truck is great otherwise but it wouldn’t be good publicity for Toyota if someone’s truck frame breaks in half at 70mph. Does anyone have definitive info or recommendations on this? Thanks
    OpieTaylor and StihlBuckin like this.
  2. Apr 21, 2020 at 7:25 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    The Toyota dealer
  3. Apr 21, 2020 at 7:29 PM
    Morozumi99
    Yes. But you know how they are. They don’t want to warranty anything. I’m wondering if anyone has personal experience or advice on how to get it taken care of.
  4. Apr 21, 2020 at 7:32 PM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    Be thorn in there side !
    Morozumi99[OP] likes this.
  5. Apr 21, 2020 at 7:39 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  6. Apr 21, 2020 at 7:41 PM
    OpieTaylor
    OpieTaylor New Member
    Hit on it with a ball-peen hammer, and look for soft spots. If you think it will fail if you jack on it quit driving your truck. Rust expands many times over, so the amount that falls off is nowhere near the amount of metal lost.
    I would think your just gonna have to take the bed off and sand and paint it yourself. I am sure a local body shop can help you remove the bed on the cheap if you can’t get help.
  7. Apr 21, 2020 at 7:41 PM
    Morozumi99
    Thanks Festerw
  8. Apr 21, 2020 at 7:46 PM
    Morozumi99
    OpieTaylor, I guess I should stop driving it then. It just sucks. Great truck otherwise. The rear diff recently rotted a hole and was dripping oil. Could’ve got a used rear axle assembly to install but I changed the rear diff fluid one last time and patched it.
  9. Apr 21, 2020 at 7:53 PM
    OpieTaylor
    I got a friend to use a MiG welder to weld up a whole on an oil pan on a Chevy 350 few years ago. Never had a problem with it. It’s more about what’s left when you stop the rust, than how hard a fix is.
    Morozumi99[OP] and StihlBuckin like this.
  10. Apr 21, 2020 at 7:59 PM
    Morozumi99
    Stihlbuckin thanks for the info. I’ll post pics tomorrow.
  11. Apr 21, 2020 at 8:05 PM
    OpieTaylor
