Frame reinforcement for Winch?
Discussion in 'Recovery & Gear' started by NR-J, Aug 29, 2019.
  1. Aug 29, 2019 at 2:59 PM
    NR-J
    NR-J [OP] New Member
    Justin
    2015 white tundra
    I’m going to be mounting a winch and new bumper soon. I know on the FJ cruiser plates needed to be welded over the front crumple zones on the frame to avoid ripping the front end off when winching.
    Is this something that’s needed on the Tundra?
  2. Aug 31, 2019 at 6:01 PM
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    Icon 2.5 cdc front and rear. MCM UCA's, RXT rear leafs , wheelers bump stops, Icon hydrolic Bump stops, Icon six speed 17x8.5 w/35x12.5R17 Nitto Ridge grapplers, A.R.E. CX,, Smittybilt Gen2 12k synthetic on SSBuilt Front bumper, factor 55 fair lead, factor 55 flat link-E, SSBuilt high clearance rear with S2Pro, BD squadron pro fogs and side lights, BD 40" Onx6 behind the grill on SDHQ mount, BD XL80's on SDHQ a pillar/ hood mounts. Switch pros 9100, SDHQ panel mount and SDHQ under hood mount. Pro Grill, SDHQ ABS guards, P&P Sliders, Full RCI skids. Kenwood TM-V71a, Dual GPS antenna, Rago dash mount, WE Boost inreach
    Just a decent mount like a well made bumper or a concealed mount that bolts to the frame will do the trick. Scroll and search around on here there’s lots of guys with winches mounted
    Pinay likes this.
  3. Oct 9, 2019 at 3:49 PM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    getting a sdhq hidden bumper an winch put on as it write this!!!
    Cthulhu and theraven like this.
  4. Oct 9, 2019 at 4:57 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    What bumper and is it designed for a winch to be added?
  5. Oct 9, 2019 at 5:34 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    I'm adding the sdhq "hidden bumper" an the warn 95960 winch
    15whtrd likes this.
  6. Oct 10, 2019 at 2:52 PM
    NR-J
    Justin
    2015 white tundra
    I’ll be installing the new Victory 4x4 bumper with winch mount.
    I’m not worried about the bumper/mount strength itself, I’m concerned with the Tundra frame ripping at a crumple zone if it has any. The FJ, Taco, and 4 Runner will all rip a front end right off with regular winching due to the crumple zones. I had to weld reinforcement plates over them so we could use it for work all the time.
    equin likes this.
  7. Oct 10, 2019 at 2:58 PM
    Sonicbluerider
    Dennis
    2019 Tundra
  8. Oct 16, 2019 at 1:52 PM
    dfwluis
    dfwluis New Member
    Luis
    DFW
    Tundra
    Genesis Dual battery kit. SSO Slimeline Bumper/W 12k winch. ARB Compressor. F/R ARB Lockers. Custom cradle for rear 12k winch.
    I went with SSO slim line. It’s a bit more than SDHQ but it’s also a bit beefier. But you do have to cut the plastic center part of the bumper to install it.
    Cornilsa, plumber802 and Tundyfundy like this.
  9. May 15, 2020 at 4:04 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I know this is a relatively older thread, but I know what you mean about your concern with the frame’s strength and ability to handle winch forces, especially if having to winch from an angle. I don’t know the answer to that and am wondering if others who’ve used their winch have any experience to add.
    I have no winch experience other than watching a few others use them on other vehicles. But I have more limited experience drilling, grinding, cutting and MIG welding on a few various frames, including welding on plates to strengthen the rear of a Tacoma frame. The thickest one I’ve worked on so far was a ‘93 fullsize Bronco. It was a pain to drill through with my cheap tools compared to other frames. But it still managed to bend right at the front crumple zone behind the frame horn when pulling out another fullsize badly stuck in the mud. So maybe someone with some Tundra winching experience can chime in? I’m also considering upgrading to a winch and bumper and would like to know more on our Tundra’s limitations in that respect and frame-strengthening steps, if any, that have been or should be taken.
  10. May 15, 2020 at 4:15 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    I have a camburg CTE bumper with a warn zeon 10k winch on my truck and have used the winch a bunch at different angles, never had any issues, even with doing a 2:1 with a snatch block for more pulling power. But my bumper has some heavy duty mounts and bolts to the frame with 12 bolts
    Black Wolf and equin[QUOTED] like this.
  11. May 15, 2020 at 4:33 PM
    equin
    Ed
    DFW, TX
    Excellent feedback and thanks for chiming in! Definitely good to know our frames can handle the stress. How do you like your Camburg bumper and winch? How was the install? I assume you had to drill some mounting holes in the frame?
    TG705[QUOTED] likes this.
  12. May 15, 2020 at 5:24 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    No problem! I absolutely love the bumper, it was a really thought out design, install was quick and easy with a buddy helping and everything lined up perfectly. Love the winch too! I didn’t have to drill or cut anything for the bumper, it attaches to the frame using the 8 studs, 4 on each side, then ties into the 4 tow hook bolts on bottom.
    equin[QUOTED] likes this.
  13. May 15, 2020 at 5:28 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    Hear are some pics of it
    equin and dcsleeper408 like this.
  14. May 15, 2020 at 6:33 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
  15. May 15, 2020 at 8:11 PM
    equin
    Ed
    DFW, TX
    Wow, that bumper is nice! Camburg has always been high quality, too. I noticed you have a 2nd gen Tundra. I wonder if they fit 3rd gens?
  16. May 15, 2020 at 8:14 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    Thanks! And yes they do!
