Fox Coil Over 2.5 with reservoirs ISSUE
Discussion in 'Suspension' started by benw, Jan 9, 2019.
  1. Jan 9, 2019 at 6:01 PM
    Vizsla
    Vizsla 2 = 2.5
    :wave:Yikes, get that truck to a competent shop, could be a bunch of things. The loose nut on the tie rod end speaks volumes. Here is what I can help with, the coils are the correct part number, Fox 0” - 3” coilovers are 3”+, no less(kinda bullshit). The passenger side will be a little under 3” lift, but it is too far down, needs at least 2 threads showing or the coil will be loose at full droop. You generally want about 6 more threads showing on the driver side to preserve the factory lean, or 9 if you want it level. Could be a bunch of things, low nitrogen, alignment cams not zeroed for ride height, bad coil spring, wrecked, maybe a combination of issues. Regardless, your stuck at 3” front lift with your coilovers, switch or lift the back.
    equin, SeanO86, Darkness and 6 others like this.
  2. Jan 9, 2019 at 6:38 PM
    Thanks bud. You know Fox setups! Thanks for the input on this problem.
    Darkness likes this.
  3. Jan 10, 2019 at 8:14 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I think you found the problem.. The passenger side coilover is loaded with more preload hence why it's higher than the driver side front. The driver side rear is lower because of the increased preload on the passenger side coilover.
  4. Jan 14, 2019 at 6:46 PM
    HONEYBADGER
    HONEYBADGER New Member
    Fox Coils Camburk Kinetik Uppers Stealth Customs Cooper AT3
    Had my Fox 2.5 reservoir with adjusters setup installed by Mikes Toys and the results are the same. Drivers side has plenty of threads showing, passenger side has none. No performance issues, but it does seem off. Called Fox they basically said get bent blamed the Tundra lean.
    equin, SeanO86 and ColoradoTJ like this.
  5. Jan 14, 2019 at 6:52 PM
    ......and that is exactly why I run Kings.
  6. Jan 15, 2019 at 4:54 PM
    Varmit
    Varmit New Member
    Bill
    Black tundra
    All
    The driver side of your truck I s heavier I've done this set up on trucks for years battery steering etc fuel tank Tacoma tundras all the. Same
  7. Jan 15, 2019 at 4:57 PM
    Varmit
    Varmit New Member
    Bill
    Black tundra
    All
    They are all made by swayaway icon king fox it's all the same except icon doesnt let you have access to the nitrogen liability lol
  8. Jan 16, 2019 at 10:23 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Fox is the shittiest when it comes to customer support. I've never had any other company give less shits about customer concerns or even safety.
    seth419 and ColoradoTJ like this.
  9. Jan 16, 2019 at 10:47 AM
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    When I had mine inI think I put the drivers side up about 1 to 1.5 threads, That looks ridiculous though and I mostly stare at rocks all day.
  10. Jan 16, 2019 at 11:27 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    ColoradoTJ likes this.
  11. Jan 18, 2019 at 1:02 PM
    benw
    benw [OP] New Member
    Fox is the worst and their customer service is terrible. I will be taking these off and trying to sell them, I will never buy FOX again.
  12. Jan 18, 2019 at 1:59 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    When I was shopping for the tundra, they didn't give me the time of day to answer my questions aside from "we make the shocks for Ford and Toyota, we know what we are doing". Found that to be a little arrogant IMO.
    I, previous to noted above, had very good luck with them in regards to support, from rebuild instructions to part drawings. But my last interaction put a sour taste in my mouth.
  13. Jan 18, 2019 at 2:01 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    What are you talking about?
    Vizsla, ColoradoTJ and TheBeast like this.
  14. Jan 18, 2019 at 2:05 PM
    TheBeast The Beach
    Vizsla and 14burrito[QUOTED] like this.
  15. Jan 18, 2019 at 2:05 PM
    TheBeast The Beach
    go with a vendor here: @M C M or @Toytec Lifts or @sdhq_offroad . All top notch in CS.
  16. Jan 19, 2019 at 10:24 AM
    waynescaggs
    waynescaggs No more of that .
    Wayne
    Idaho
    2019 tundra Crewmax Limited
    I won’t be buying anything from Fox , because of what I’ve read about there customer service .
  17. Jan 19, 2019 at 10:52 AM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Icon customer service excellent. They’ll answer any questions you have, and go into detail how suspension works etc.
  18. Jan 25, 2019 at 3:57 PM
    benw
    Just an update, took it to a much better shop and confirmed all part numbers matched and were the same but the diameters on the coils measured differently. Putting on a pair of 6112 and sending coils back to Fox and if I am lucky hopefully they will swap coils out for matching ones, then I will be selling the Fox setup. They tried to charge me $180 for new coils without them seeing it even though it was oneof their preferred dealers. Couldn't justify giving them any more money based on this experience.
    TheBeast and el topu like this.
  19. Jan 25, 2019 at 5:35 PM
    #49
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Sounds like an usual deal. Glad I’m with @sdhq_offroad brand new.
  20. Jan 25, 2019 at 7:14 PM
    #50
    monaco730
    16 Inferno Tundra
    Does this mean you bought fox CO's from SDHQ?
  21. Jan 25, 2019 at 7:16 PM
    #51
    4Runner
    4Runner New Member
    Columbia, SC
    Yes.
  22. Jan 25, 2019 at 7:19 PM
    #52
    monaco730
    16 Inferno Tundra
    Did you go with the 2.5 reservoir? And how do you like them?
    4Runner[QUOTED] likes this.
  23. Jan 25, 2019 at 7:22 PM
    #53
    4Runner
    4Runner New Member
    Columbia, SC
    I’m going to start a new thread. Don’t want to hijack this one.
    monaco730[QUOTED] likes this.
  24. Jan 25, 2019 at 8:49 PM
    #54
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    I have had both King and Icon respond to tech question emails within a day, most of the time king responds within an hour or two. Fox dosent respond at all.
    14burrito, Vizsla and Darkness like this.
  25. Jan 25, 2019 at 8:57 PM
    #55
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I swear Fox blocked my number and put spam filter on my emails
  26. Jan 25, 2019 at 8:59 PM
    #56
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I guess I'm the only one who gets correspondence from FOX. I LOVE my setup and I always get the best interaction with em. Then again I get good info from Icon as well. King not so much because I don't push that much of it.
    Bo-Hunter likes this.
  27. Jan 26, 2019 at 3:26 AM
    #57
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    I have had zero issues with Fox customer service both via e-mail and phone. They have always answered all my questions to my satisfaction.
  28. Feb 10, 2019 at 4:14 PM
    #58
    Jason's Lessons Learned
    Jason's Lessons Learned New Member
    Colorado Springs
    2016 Grey Tundra Platinum
    Leitner ACS Fox Shocks 2.5 Coilovers with Reservoir - Front Fox Shocks 2.0 Smooth Body with Reservoir - Rear Method Racing 18" Wheels 33" Nitto Ridge Grapplers
    I have these same shocks and haven't any performance issues with my set up. I'm also not a mechanic. I would have to double check the levels but I'm pretty sure mine are set all the way up right now on both sides.
  29. Feb 12, 2019 at 10:18 PM
    #59
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    Is this true & confirmed that Fox/Icon/King/ADS etc are all made by Sway-A-Way (now owned by aFePower)?
  30. Feb 12, 2019 at 10:25 PM
    #60
    14burrito
    2014 SR5 CM 4x4 5.7
    Hahahahahahahahahahahahaha
    LMFAO
