FOX 2.5 DSC Installed
Discussion in 'Suspension' started by matictundra, Oct 15, 2021.
  1. Oct 15, 2021 at 7:46 AM
    matictundra
    matictundra [OP] New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Finally got the fronts last week. I got the rears a month ago. So I promptly installed them. I also updated to new JBA design bushing, can’t over grease them due to channel design. I over greased the old design, lol. The hardest part was taking off the UCA, the inner washers “coined” (stuck) on the bolt on both sides. It took 8 hrs each just to hammer the bolts out, you have about 2” if that to swing a hammer. I should have just cut them off and replaced them. I also replaced the UCA ball joints, I like the new boot design. I will use the old ball joints as spares. Finally, I installed the new wheel well splash guard from RAD, old ones were ripped and mounting holes are elongated.
  2. Oct 15, 2021 at 7:55 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Looks great!
    Any modifications done/needed for front and rear swaybar endlinks?
  3. Oct 15, 2021 at 8:01 AM
    a_double
    a_double New Member
    The suspension is looking mighty fine.
  4. Oct 15, 2021 at 9:00 AM
    Vizsla
    Vizsla ☠️☠️☠️
    Let me save you some trouble. Need to clearance the upper rear shock mount on both sides, the elbow for the reservoir hose hits and breaks off.
  5. Oct 15, 2021 at 9:05 AM
    a_double
    a_double New Member
    Can the fitting be turned down enough for clearance?
  6. Oct 15, 2021 at 10:04 AM
    matictundra
    Franco
    AZ
    That's optical illusion, it clears due to hex goes down but I did turn down the fitting some more after install. I also did the same for the fronts to make sure hoses clears the springs.
  7. Oct 15, 2021 at 10:09 AM
    matictundra
    Franco
    AZ
    No, it actually clears better than my old Bilstein 6112.
  8. Oct 15, 2021 at 12:29 PM
    ChargedToyo
    ChargedToyo New Member
    Mario
    2010 Grey
    Your 37s don’t touch the shock reservoirs? Are your tires 12.5 or 13.5?
  9. Oct 15, 2021 at 1:50 PM
    matictundra
    Franco
    AZ
    Nope, plenty of room. I have 12.5" but will clear 13.5" as well. The key is wheel offset, and I have +20mm.
    Bob_Wiley likes this.
  10. Oct 26, 2021 at 2:30 PM
    matictundra
    Franco
    AZ
    When I loaded up my bed with full spare, recovery and camping gears for T2S event last weekend, the fittings do come close. Still clears but too close for comfort. I followed your recommendation, I grounded the brackets for more clearance.
    Bob_Wiley, AggiePhil and a_double like this.
  11. Oct 26, 2021 at 2:37 PM
    Audiolust
    Audiolust New Member
    2010 Tundra Limited
    How are you liking the ride, literally getting ready to check out with the same shocks but am second guessing myself.
  12. Oct 26, 2021 at 2:38 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Taken it out to do some high speed runs, yet?
  13. Oct 26, 2021 at 2:39 PM
    matictundra
    Franco
    AZ
    Loving it so far. I have it fully opened for on road use.
    AggiePhil likes this.
  14. Nov 9, 2021 at 10:38 AM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Has this actually happened to people?
  15. Nov 9, 2021 at 3:31 PM
    DuneShoot
    DuneShoot New Member
    West Phoenix
    ‘21 Limited Cement
    Nice! I am installing mine this weekend, hope I don't have the UCA bolt issues you did.
    What height did you end up with over stock?
    What are you using for rear lift?
    I went with the 3" (1.75" of lift) Coach Builder shackles, hoping they are not to high.
    matictundra[OP] likes this.
  16. Nov 9, 2021 at 3:36 PM
    matictundra
    Franco
    AZ
    I got my original 3" front lift. I'm using 1.5" Toytec shackles for the rear. Get the bolts just in case and cut them off if you run into similar issue as mine.
  17. Nov 9, 2021 at 3:51 PM
    DuneShoot
    West Phoenix
    ‘21 Limited Cement
    Is it exactly 3" or somewhere around 2.75 up front?
    Do you remember the extended length of your shock?
    Listed at the chart at the bottom here: https://accutuneoffroad.com/oem-front-coilover-shock-setup/
    With the rear shackles do you sit level? I need some rake since I tow a small trailer.
    With the UCA bolts have 4500 miles on them I hope I am good.
  18. Nov 10, 2021 at 5:15 AM
    Ktate
    Ktate New Member
    2007 RCSB SR5 TRD 4x4
    May I ask what was the turnaround time with ordering the Coach Builder Shackles and receiving them?
  19. Nov 10, 2021 at 6:03 AM
    DuneShoot
    West Phoenix
    ‘21 Limited Cement
    About 3 weeks with no email or phone calls replies.
    Ktate likes this.
  20. Nov 10, 2021 at 6:17 AM
    Ktate
    Ktate New Member
    That’s what I feared…thanks..
  21. Nov 10, 2021 at 6:21 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Looks like your ready for LeMans rather than some bumps.
  22. Nov 10, 2021 at 10:05 AM
    matictundra
    Franco
    AZ
    :rofl::rofl::rofl:
  23. Nov 10, 2021 at 10:37 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Congrats.. Looks killer.. Top shelf shit!!! JBA's is solid and true.. Big fan....Well done Sir
