Fortin Evo One Remote Start
Discussion in 'General Tundra Discussion' started by BlueBottle, Sep 1, 2017.
  1. Aug 11, 2018 at 7:50 PM
    #241
    BRTundra
    BRTundra New Member
    Tony
    Baton Rouge, LA.
    2017 Tundra Platinum 5.7L CM
    What do you guys do when you have to bring the tundra in for service at the dealership? Do leave it as is or unplug it somehow?
  2. Aug 12, 2018 at 2:42 PM
    #242
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    Leave it as is. Unless the dealership is fixing something dealing with wiring under the dash, they'd never even know it was installed.
    BRTundra[QUOTED] likes this.
  3. Aug 13, 2018 at 3:11 PM
    #243
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    exactly! Its also kind of cool to check on it and see door locked or unlocked and engine running... you get a good sense as to where your vehicle is regarding service order....
    AggiePhil likes this.
  4. Sep 22, 2018 at 5:22 AM
    #244
    ImmortallyInsane
    ImmortallyInsane New Member
    I joined this site to try and help others. I didn’t connect the key sense wire and when I remote shut off, the alarm goes off. You must use the key sense wire to utilize remote shut off. Works for both Fortin RF remote and OEM 3x. If yours isn’t hooked up, remote start it and wait a few minutes and remote stop. I bet the alarm goes off.
    2018TundraLimited likes this.
  5. Oct 27, 2018 at 8:52 PM
    #245
    nowayout
    nowayout New Member
    NY
    15 Dbl
    My head is spinning. So what kit and harness is needed for the plug and play on the Fortin evo One for a 17 Tundra with G key? I am trying to buy from the ebay guy but I cant figure out which one I need.
    Also researching it for the wife's 18 4runner making me even more confused.
  6. Oct 30, 2018 at 1:56 PM
    #246
    tubal
    tubal New Member
    SLC, UT
    '17 Tundra needs the TOY7 harness.
    nowayout[QUOTED] likes this.
  7. Nov 6, 2018 at 8:07 AM
    #247
    Pit_goral
    Pit_goral New Member
    Piotr
    Greeley, Colorado
    17 Tundra Limited TRD OFF ROAD
    Hi , I was installing evo one on my 17 tundra limited with oem alarm with break glass sensor and everything's works fine except when I lock a vehicle waiting couple minutes and re-enter using only a key there is no alarm sound like it was before. When i press panic button on alarm is working. Anyone has the same problem?
  8. Nov 18, 2018 at 2:24 PM
    #248
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    I'm having issues programming my fortin evo one. I get to the last step where you wait for it to flash blue (can bus programmed) but it never happens. anyone have any ideas on what might be wrong?
  9. Nov 19, 2018 at 11:44 PM
    #249
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    Try locking it while in the truck, wait a min. then open door from inside. Does the alarm sound?
  10. Nov 20, 2018 at 6:47 AM
    #250
    Pit_goral
    Piotr
    Greeley, Colorado
    Yes, everything is working fine right now. Thank you
    Scud likes this.
  11. Nov 23, 2018 at 5:25 PM
    #251
    blizz86
    blizz86 New Member
    Does anyone’s cruise control not work anymore after installing? Everything else functions perfectly .. any suggestions?
  12. Nov 25, 2018 at 7:42 PM
    #252
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Earlier today finished the install of the Evo One for my 2017. Bought it on ebay from a guy named warmcarnow for $169.00 than includes everything needed for the install. After watching a few videos I was able to install it in 30 minutes. Very easy install, removed the plastic cover from bottom of glove box and ran coat hanger to the driver side to pull the tpms cable and only had to tap in one wire other than that everything else plug and play. It starts up if I either hit the lock 3x or hold lock for 3 seconds. Surprising easy install would suggest anyone in the cold or hot regions to get one.
    DCslick, tinman10101 and nowayout like this.
  13. Nov 26, 2018 at 8:35 AM
    #253
    AFKC
    AFKC New Member
    I actually installed the one from ebay yesterday as well. I had a question so I texted the guy that sells them and he replied right away. So far no issue.
    nowayout and TXDrifter like this.
  14. Nov 30, 2018 at 10:54 AM
    #254
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    Another vote for the eBay guy. my came programmed and works greats so far on my 2015.
  15. Nov 30, 2018 at 3:37 PM
    #255
    nowayout
    nowayout New Member
    NY
    15 Dbl
    Is anyone running the drone module on these?
  16. Dec 2, 2018 at 9:20 AM
    #256
    CamR
    CamR 19 Tundra Limited
    Al
    Fayetteville, Ga
    Does anyone know if this evo one will work in the 2019 model Tundra? I’ve seen on their website it only shows to 2018. The tech on their hotline said they haven’t had a2019 model to try it on yet. Has anybody out there tried?
  17. Dec 6, 2018 at 4:42 PM
    #257
    Adam New Member
    So i ordered one of these from Warmcarnow site and haven't heard anything yet from them. It was ordered on Nov 27th. Did the package just show up randomly at your door? I am concerned that I haven't gotten a conformation email, but have the charge on my AMX. I tried calling but got no answer... It is after business hours there though.
  18. Dec 6, 2018 at 5:53 PM
    #258
    TXDrifter
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Hmm.. I received and email when he charged my card and also an email when it shipped. All together took 4 days from order date to my front door. I think I am only one state below him so maybe while it arrived so quickly.
    Adam[QUOTED] likes this.
  19. Dec 7, 2018 at 2:38 AM
    #259
    Adam New Member
    Thanks. I will try to give him a call today and see what is up. I figure that he probably got swamped with orders. My holiday shopping has not gone well this year.
    TXDrifter likes this.
  20. Dec 7, 2018 at 6:02 AM
    #260
    DCslick
    DCslick New Member
    2015 Radiant Red Tundra TRD 4x4
    I was emailed when my remote start shipped from Warmcarnow. Also he was very responsive when I had a couple of install questions. He didn't answer when I called but after my message he returned my call pretty quickly.
  21. Dec 7, 2018 at 3:11 PM
    #261
    Adam New Member
    I have tried calling a dozen times. There isn't any answer. After it rings for a minute, there is a beep like an answering machine, but no message. I cant even get a hold of the place to cancel if i wanted to. Anyone got another number other than (518) 393-7777? I am going to call one more time tomorrow to get a hold of them and then calling my CC company to kill the charge.
    Best buy has a 4095S starter with the 3000ft 2 way remote with free install for the same price. I would love to do this myself, but not hearing anything from this guy is not giving me warm and fuzzies.
  22. Dec 7, 2018 at 3:28 PM
    #262
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    PM'd
  23. Dec 7, 2018 at 3:53 PM
    #263
    Adam New Member
    Welp, I found an email for him and finally got a response. I can't say it was one of someone that was like "hey man sorry it took so long but I got it for you" I wouldn't recommend.
  24. Dec 8, 2018 at 5:15 AM
    #264
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    12voltsolutions remote start installed!!
    FINAL UPDATE (13 Dec): 12 V customer service is friggin top notch!!
    They just sent out a new unit—didn’t even ask me. Got here in 36 hrs. 13 min install. Works as advertised!! Will be sending back the old unit and hopefully they can figure out where that thing went haywire. A small product hiccup, but excellent customer service and a willingness to do right by the customer. These guys get the highest grades!!
    Couldn’t have come at a better time. It’s been 1* F these past few mornings.
    EDIT UPDATE: Finally got a hold of Veronica Tuesday. Techs still not sure, so they sent out a whole new setup. Guess we’ll make this Take 2 on Friday?? At least it’ll be a very quick removal and install since the truck dash is still in pieces. Lol
    First: customer service (via phone) is excellent. Veronica was awesome.
    Second: Physical install was a breeeeeeze. All the harnesses were quick snap, plug n play. Just one wire from one harness needed to be joined to a separate wire on a different harness (all provided btw). I chose to solder, but the kit comes with connectors as well.
    Impressions with the whole system....
    Ugh, where to begin.
    First: Can bus/unit would not program the key. (Yep, G key). Key FOB would unlock truck, but not lock...and not start.
    This is where the customer service came to play.
    Reseated all connectors. No change
    Unplugged and re-plugged all connectors and did a hard reset on the unit. Hey!!! Now we’re getting somewhere!! . Truck locked and started as advertised! (BTW, it didn’t matter if I hit lock 3x or if I held the lock button down for 3 seconds.). Unfortunately, the truck only ran for a few seconds then died.
    It gets more interesting.
    I could command it to start again, but all it would do is turn over—-wont run.
    I could manually get in and crank the truck, and after 5-6 sec of cranking it would start and run...but when I turned the truck off manually, the truck would continue running. At one point, I literally pulled the key from the ignition and walked away...truck running like a champ!! Lol
    I had to hit the lock button FOB 3x to get the truck to quit. Then it wouldn’t start again.
    12VS was awesome with troubleshooting, but even their techs were scratching heads yesterday. I have since received no reply, and don’t expect to hear anything until Monday. . In the meantime, I Disconnected the unit (leaving all The harnesses attached) and went about my business per usual...dash panels all torn out, etc etc.
    Anyone else having these types of issues?? I figure it has to be either the remote unit ECU or the harness that’s out of whack.
    Fishman57 likes this.
  25. Dec 12, 2018 at 7:49 AM
    #265
    Crews44
    Crews44 New Member
    Southern NJ
    2025 Platinum TRD MGM CM 3” TRD lift
    I am in same boat with this guy. Ordered for wife’s highlander. No confirmation email or anything and credit card is billed. Very close to disputing charge.
  26. Dec 12, 2018 at 8:56 AM
    #266
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    I can attest to the 12 VS customer service. It's great. I also emailed them a couple of times well after their advertised office hours and got responses back within 1/2 hour.
    My installation time was really quick also. Their online video was a great help.
    I haven't experienced the issues that you mention. The only minor issue that I have is that when I use the 12 VS starter, and then get in my Tundra and put the key in the ignition, the seat and steering wheel don't automatically adjust like when I start my Tundra with the key. This isn't a big issue for me because all I need to do is hit the memory button on the door.
    My 2019 CM has the h-key. I always have to hit the button 3 times. The 3-second rule doesn't work for me.
  27. Dec 12, 2018 at 9:30 AM
    #267
    Crews44
    Crews44 New Member
    Southern NJ
    Good to hear...I just ordered the one for my wife over the phone from Mike at 12 Volt Solutions. Free shipping being sent today... I have AMEX taking car of the other order for me....
    Fishman57[QUOTED] likes this.
  28. Dec 12, 2018 at 10:18 AM
    #268
    G10dra
    G10dra Not a New Member
    ****************DO NOT BUY FROM WARMCARNOW.COM****************
    I came here to inform everyone about this guy from warmcarnow.com but it seem like he is already treanding here. There is very little or no communication from him about your order. I had to email him to find out about the status of my order then only he replied.
    I also had problems with the extended remote that I ordered from him that he sells as a add on package but nope, no help or replies or any support from him. Its been almost a month since I purchased the starter from him and still havent heard from him. I had to call Fortin for assistance.
    Buy at your risk.
    West Texas Tundra and nowayout like this.
  29. Dec 12, 2018 at 11:04 AM
    #269
    dieselkeane
    dieselkeane New Member
    2014 White Tundra
    I connected the Fortin Evo in my 2014, has anyone added on the phone app device? What one did you use and is it just plug and play?
  30. Dec 12, 2018 at 11:10 AM
    #270
    DCslick
    DCslick New Member
    Interesting, I purchased from warmcarnow through eBay. I received the remote within 4 days and installed it over Thanksgiving. I text a couple of questions to Warmcarnow while installing and received a response within minutes. When I didn't get a chance to respond back to warmcarnow he even called me to make sure it was all working correctly.
    Pit_goral and TXDrifter like this.
