Fortin Evo One Remote Start
Discussion in 'General Tundra Discussion' started by BlueBottle, Sep 1, 2017.
  1. Mar 14, 2018 at 9:29 AM
    #211
    Mitsuboost30
    Mitsuboost30 New Member
    18 Cement SR5 TRD Off Road 4x4 Crew Max
    Where are you seeing that it was working and now its not? Links? Videos?
    Thanks
  2. Mar 14, 2018 at 9:56 AM
    #212
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    a month ago, it was showing on the Fortin website as an option, then they took it down and it only shows TOY2 as the only installation option. go to fortin.com and check it out, by all means if you can make it work, let us know.
  3. Mar 14, 2018 at 10:54 AM
    #213
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    They guy in the video posted in previous messages is using TOY7 but he explained what to do and fix the problem when unlocking door a wire is required to be cut
  4. Mar 14, 2018 at 10:55 AM
    #214
    Mitsuboost30
    Awesome!
    Thanks
  5. Mar 14, 2018 at 11:00 AM
    #215
    iHacker
    iHacker SW TRD PRO
    Mario
    TOY2 didn’t have the t-harness he’s showing in video for the OBDII port that’s why I recognize the TOY7
  6. Mar 14, 2018 at 11:03 AM
    #216
    iHacker
    iHacker SW TRD PRO
    Mario
    When I did mine TOY7 didn’t exist so used TOY2 and I had to use a pair or t-taps in OBDII port and cut like 4 wires, I like the new TOY7 maybe go to repair my wires and go for the TOY7
  7. Mar 14, 2018 at 11:07 AM
    #217
    Dmas
    Dmas New Member
    FTL, FL
    Not really, that’s a harness that the 12v people develop for his installation, that’s why is so expensive.
  8. Mar 14, 2018 at 11:10 AM
    #218
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Makes two of us.
    iHacker[QUOTED] likes this.
  9. Mar 14, 2018 at 11:15 AM
    #219
    Mitsuboost30
    Well ordered the Toy7 and the Evo so we will see for sure next week.
    I will report back.
  10. Mar 14, 2018 at 11:21 AM
    #220
    Dmas
    Dmas New Member
    FTL, FL
    Great, look forward to hear back from you !!!
  11. Mar 18, 2018 at 8:07 PM
    #221
    RKTundra
    RKTundra New Member
    Royce
    2015 CM Tundra
    Just did my install of the EVO-1 with the TOY-7 Harness on my 2015, just had to tap the key signal wire because of the factory alarm.
    Took about an hour and a half total, and that's only because I ziptied all the cables nicely inside the dash. This harness makes it pretty much idiot proof.
    Got mine from Anderson Electronics on Ebay. https://www.ebay.com/ulk/itm/352289233157
    Highly reccomend this guy. It arrived in 3 days all programmed, zero issues. I could have got it cheaper and flashed myself but for the little more money its worth it.
    He is out of Harnesses for now but you can get them on Amazon.
    Watt maker and iHacker like this.
  12. Mar 19, 2018 at 8:52 AM
    #222
    blizz86
    blizz86 New Member
    Anyhave having small issues with interior lighting when the you start the truck with the remote start? I remoted started this past weekend, and a few hours after driving the dash lights shut off (headlights stayed on) and i had to turn off my headlights and turn them back on to get my dash lights back on, and the dome lights didnt work.
    I noticed it do it one more time when i started the truck using remote start, but everything works 100% when i manually turn on my truck..
  13. Mar 19, 2018 at 9:15 AM
    #223
    RKTundra
    RKTundra New Member
    Royce
    2015 CM Tundra
    A little different issue, the bed light goes on now when I remote start the truck even though I have it set to off. I prefer not to have it light up, must be something with how the Evo backfeeds the parking light circuit?
  14. Mar 19, 2018 at 8:08 PM
    #224
    Mitsuboost30
    Well gents the Toy 7 will not work on the 18s.
    The harness in the 12v solutions video is their own harness not the standard Toy7.
    The Toy 7 harness I recieved from ebay has a different connector than the 18.
    https://www.ebay.com/ulk/itm/142708721406
    pmcgeorge1964 and Watt maker like this.
  15. Mar 20, 2018 at 4:20 AM
    #225
    RKTundra
    RKTundra New Member
    Royce
    2015 CM Tundra
    Well, if you can't use the TOY7 and you use the TOY2, you could buy this
    https://www.ebay.com/ulk/itm/302368163665
    And splice in the OBD2 wires, that way you eliminate 2 wires that you splice into the factory harness, and give yourself an extra OBD2 connection for a bluetooth code reader or other scan gauge setup.
  16. Mar 20, 2018 at 5:11 AM
    #226
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    Installed the 12volt.solutions version on my ‘18 last night, with the phone app. Easy, straight forward and works perfectly. Took about an hour to install, that’s tear down as well. 20 minutes to program both. That’s reading and comprehension of steps to be safe first. And another hour to cleanup wires, zip tie, and put it back together so it is completely stealth. Works perfect, and very happy! Since it is a fortin one unit, I need to investigate an RF Auto Unlock fob.
    borntostun and Watt maker like this.
  17. Apr 6, 2018 at 8:01 AM
    #227
    What the!?
    What the!? New Member
    2017 Pro
    Finished the install of the Evo-One yesterday with the TOY7 harness. It is 100% plug and play. Didn’t have to cut anything on my 2017 Pro.
    I was a little intimidated at first. I haven’t installed a car stereo in 20 years but the harness and videos made it super simple.
    Total time was about an hour from start to finish. Anyone can do this. Just take your time and watch the video as you go.
    I bought mine from the same eBay seller as the OP.
    Gotta love the University of YouTube!
  18. Apr 10, 2018 at 12:03 PM
    #228
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    What video did you watch? You didn't have to do anything with keysense? Do you have factory alarm?
  19. Apr 10, 2018 at 3:44 PM
    #229
    What the!?
    2017 Pro
    It was a 3 part YouTube video for the Fortin. It should be the first thing that pops up when you search for “Tundra Fortin.”
    Regarding keysense, I didn’t splice into the wire. I even asked the vendor if I should and he said I needed to splice into it in order for it to work. Well, I didn’t and it’s working fine so I’m not sure exactly what to think of it.
    Yes, I have the factory alarm also.
    I thought I had done something wrong because I had so many wires not plugged into anything but I realized those are just in case I wanted to add to the system.
    Also, like an earlier post, I don’t have to push the lock three times in order to start it. I just leave the lock pushed in until it beeps back and then will start it.
    So the process is,
    -Push Lock until car starts
    -press unlock once to unlock door
    -go inside driver’s side
    -put key in ignition, turn twice (not three or you’ll grind it)
    -tap on brake. Dash lights will change and you’ll be able to drive off.
    Hope this helps.
  20. Apr 10, 2018 at 8:35 PM
    #230
    lewi3069
    lewi3069 New Member
    Thanks for the informative reply!
  21. Apr 12, 2018 at 2:15 PM
    #231
    lewi3069
    lewi3069 New Member
    One more question as I'm installing Saturday. From what I've read the TPMS harness is on the passenger side behind the glovebox. I assume you run the tharness to the other side. Any hangup there or special way to route the wire?
  22. Apr 12, 2018 at 2:39 PM
    #232
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I used a hanger as there is just a small space to get the wire accross. Those wires are hard to strip also. Best to solder it.
    iHacker and Watt maker like this.
  23. Apr 12, 2018 at 4:18 PM
    #233
    What the!?
    2017 Pro
    I plugged the TPMS harness in and then ran the wire using a hanger like BlueBottle over to the driver side. No hang ups. There was plenty of room behind the center console against the carpet. The TPMS is a little charcoal colored square. If you look from underneath on the passenger side, it’s closer to the vent side. You can see it in part two of the Fortin video at 7:02.
    I watched that YouTube while I was doing and it helped out a lot.
    Good luck. Hope this helps.
    iHacker likes this.
  24. Apr 19, 2018 at 9:35 AM
    #234
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Does your truck turn off when you open the door?
  25. Apr 19, 2018 at 9:58 AM
    #235
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    With this remote starter, truck should not turn off when you open the door.
  26. May 3, 2018 at 5:16 PM
    #236
    Markcristi
    Markcristi New Member
    Anybody try the push button start with remote start kit fom Advanced Keys?
    Looks like an option
  27. May 4, 2018 at 4:03 PM
    #237
    lewi3069
    lewi3069 New Member
    It does not turn off.
  28. Jun 20, 2018 at 4:39 PM
    #238
    TuffTundra
    TuffTundra New Member
    Missouri
    2016 MGM SR5
    4" Rough Country Lift - Fuel Assault 20x10 - Nitto Ridge Grapplers 33x12.5x20 - 2018 LED Headlights - LED Lights all around - No Chrome - Tinted Windows & Tail Lights
  29. Jun 21, 2018 at 7:30 AM
    #239
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    This company is making their own harness. One of the connector sets is a 30 pin connector that his plugs into. They also charge $175 more than other companies for the same thing using their custom harness for the 2018. Here is the 12volt.solutions harness. It's quite different from the THAR-TY50 harness for older models.
  30. Aug 10, 2018 at 7:54 AM
    #240
    Master_tundra
    Master_tundra New Member
    2017 MGM limited
    I have 2017 Limited with an alarm and having some issues programming.
