For those that have PRO COMP 6" lift, a question....
Discussion in 'Suspension' started by preacher35, Jul 21, 2019.
  1. Jul 21, 2019 at 3:50 PM
    preacher35
    preacher35 [OP] RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    My 2018 4x4 CM has a stage 1 Pro Comp 6" lift installed, and I am very happy with it. However, I have to work out the spare wheel/tire situation for it. I would like to utilize the factory 18" spare rim (with a 35" tire installed) but I know that the backspacing will be a huge problem. Can anybody tell me how thick of a wheel spacer would be required to make the factory spare work with said lift? I know that the installed factory OEM wheels have a 6.85" backspacing, but not sure if the spare is the same. And Pro Comp does not give recommended backspacing on their website or instructions. If any of you has any idea, I would greatly appreciate it. Oh, and I will make sure that you will not go to HELL!
    Preacher
    jeremyd likes this.
  2. Jul 21, 2019 at 4:00 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Instructions say 5.5 inch max. So you would need like 1.5 right?
  3. Aug 17, 2019 at 4:43 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    This was a conundrum for me, and I still haven’t executed the final solution. I’m running PC Stage II which essentially means the stock wheels (17”) will NOT fit on the front spindles.
    In the meantime...
    If I need to spare out the rear wheel, no issues, just looks funny for a bit.
    If I need to spare out the front? Well, that requires a double wheel swap. Would have to put the spare on a rear axle, then use THAT good tire to swap out the front.
    Not the bet solution, but doable for now
    Fingers crossed I won’t need it lol
  4. Aug 17, 2019 at 4:48 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Great question ! I'm also looking for just one spacer for my spare..
