Footwell & Glovebox Light Locations Question
Discussion in '1st Gen Tundras (2000-2006)' started by Cybertek, Aug 22, 2021.
  1. Aug 22, 2021 at 6:17 PM
    Cybertek
    Cybertek [OP] 67 Tons of Romping, Stomping mean!
    William
    Pensacola, FL
    2006 Tundra Double Cab 2WD SR5
    None
    I would like to ask if anyone knows if there is a footwell light on the passenger side? I found the one on the driver's side without issues. I cannot find a passenger's side nor a glove box light. It would seem that both would have existed, but I need someone with 2006 Tundra Double Cab experience or the equivalent. Also if so do you know the LED bulb sizes, salute!
  2. Aug 22, 2021 at 6:47 PM
    Teutonics
    Teutonics New Member
    2005 DC SR5 4WD
    Glove box light is in the upper shell. Remove the glove box (2 screws at bottom) and then the liner/shell (3 screws along the top). Glove box light is mounted in the liner/shell. Size is a 37, same as the driver footwell.
  3. Aug 22, 2021 at 7:44 PM
    Cybertek
    William
    Pensacola, FL
    None
    Thank you so much, salute!
  4. Aug 22, 2021 at 8:49 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Also, the glove box light only works when the headlights are on. In case you are trying to test it.
  5. Aug 22, 2021 at 9:34 PM
    Cybertek
    William
    Pensacola, FL
    None
    Glad you told me that, I was scratching my head:) Salute!
  6. Aug 23, 2021 at 2:34 AM
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
    No passenger footwell light. You could easily add one in by tapping into the wires right before the driver's light socket, then run additional wire to a socket on the passenger's side that uses the same size bulb. Then comes the question of mounting the socket. Another option is wiring into the door light but those don't have the same timed shutoff.
    https://www.amazon.com/HUIQIAODS-Socket-Dashboard-Instrument-Cluster/dp/B07H49GYBX?crid=2APEMQSU95HYP&dchild=1&keywords=t5+bulb+socket+with+wire&qid=1622911309&sprefix=t5+bulb+socke%2Caps%2C236&sr=8-11
    https://www.amazon.com/3M-Scotchlok...KTS78YE9PCXQAJT3W&refRID=KKPKTS78YE9PCXQAJT3W
  7. Aug 23, 2021 at 2:39 AM
    des2mtn
    Tonto cover
    There's also a light inside the ash tray just so you know. Some members on here were surprised to learn that so figure I'd pass that along.
    You have to remove the radio bezel to get to it or take out the ash tray slide. I stabbed out the green lens for better light output.
    Teutonics likes this.
  8. Aug 23, 2021 at 7:24 AM
    Cybertek
    William
    Pensacola, FL
    None
    Thanks, folks, great information, I am learning so much, can't get over how helpful everyone is in this forum. About the ashtray light, do you know the bulb size or can recommend one to use. About the footwell, so my truck has no passenger-side footwell light, right? Why do you think Toyota did that, maybe passengers do not ride at night in Japan, just kidding, salute!
    On the other hand, if you ever need help working on a tank, I'm your guy, salute!
    NewImprovedRon and des2mtn like this.
  9. Aug 23, 2021 at 7:33 AM
    des2mtn
    Tonto cover
  10. Aug 23, 2021 at 11:50 AM
    Cybertek
    William
    Pensacola, FL
    None
    Thank you sir, just ordered a bunch, salute!
